saddle mod advice
saddle mod advice
i am still not very happy with the saddle angle on my birdy bike even when I move everything forward and add extra washers at the back suspension. Here is a dump idea please tell me what you think ?
Basically i will cut the tube and drill through for two bolts so that i can move the tube to the front. i can add the metal ring around the two tubes if need to. The M2Racer Power Module would be perfect but i can't find it for sale anywhere as the company closed long time ago
Quoted: 151 Post(s)
Liked 10 Times
probably what you need is a stem insert that has 0 forward stem length.
no it is not about the reach it is about the seat angle is it way too far back. my handle bar is a butterfly i can move it at any distance i wish
I dont have that seat post ... plain 7/8 top type offers the option of mounting the saddle clip ahead of the seatpost.. Or to the rear ..
you may seek out someone with aluminum welding experience to modify or fabricate a replacement .
Bike Friday is advantaged by having several frame sizes , most/all others just one .. yours seems that.
yes butterfly bar, horizontal, will be a shorter reach.. as shown vertical just up/down
here is the image overlay. see what i mean about the seat angle ?. the welder is asking like $100. i think i will go ahead with my mod and will see. since i can buy another birdybike seattube if i mess up
Quoted: 151 Post(s)
Liked 10 Times
i'm providing you with images for ideas.
you can visualize cutting the seatpost then bolting it back together but, you cant conceptualize how to modify the 33.9 seatpost to accept a 27.2 seat post?
anyway, maybe this is all you need. you'll have to experiment.
thanks for your input smallwheeler. I think my question should be with the way i just about to do by cutting the tube and bolt them together would it still be safe and hold the weight ?
Quoted: 113 Post(s)
Liked 8 Times
As s/w intimated, it would be much easier/safer to install a negative setback post in the Birdy tube.. As the 35mm Birdy seatpost is open at the top, a simple sleeve and clamp would be all that is needed to modify .. your idea of bolting two round tubes together is not good (IMO) .. normal riding would attempt to shear/twist the bolts.. making the bolts bigger to offset the levering/twisting will weaken the tube more.. the engineer types might comment to say it would work and I'm wrong .. I'd go the easy, safe route that could be undone easily..
Quoted: 151 Post(s)
Liked 10 Times
i could be wrong, but to be clear, i think what you need is a seatpost with setback that has a pivoting clamp. you can rotate the seatpost 180º. that will give you 3-4cm of forward reach.
birdy seatpost with setback:
NB Problem Solvers
you can take apart that saddle clamping hardware and / or saw off the end of the tubing square
or maybe even just turn it over the other end is probably cut off square
shim the ID of your seat post tube to take a common sized seat post as there is being shown .. ^^above^^
Or have a tube, the same size, made and welded up to get the pushed ahead saddle mount you desire ..
Father was a machinist .. so making rather than internet shopping seems better..
welding on a 7/8" diameter tube Horizontal on top and buying one of Brompton's excellent Penta clip saddle clips
which is stepless, secure and works in 360 degrees will have your saddle positioned above the horizontal tube.
Then the saddle set back adjustment range can be user chosen..
Idea, modeled after Brompton's own Saddle adapter pin..
Which offers the horizontal tube when fitted to a post, which also has a 7/8" top diameter
As most tube seat posts do.
thanks for all the input. i won't cut the tube as it seems like a dumb idea. I would either go with the Rspeed which sell on ebay or will talk to my brother in law about bending the tube a bit since he is working for a steel tube company
LET'S ROLL
If you mod the seat post in any way; you may not be able to push it all the way
down. Negating one of the attributes of a folder, compact size for storage/parking.
From your pic; looks like you can still move the saddle forward. You can also try
another seat that has longer rails; Selle SMP is one.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 847 Times
I was just about to create a thread asking about a more forward riding position on one of my bikes (Puma Nevis, it's a pedal forward bike, but it's too far back and causes me knee pain). Now I'll just start Google'ing and find a more forward position seat post. The bike is well worth it - it's built like a tank!
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times
Dahon had a 2 piece seatpost that had an internal diameter of 27.7.
Speed Uno
Dawes Kingpin 2speed
Speed Uno
Quoted: 321 Post(s)
Liked 7 Times
I see the seatpost is not actually a Birdy original. The original has a setback-setforward possible mounting, making a huge difference. Check out SW's pic of a more modern birdy's seatpost.
Bikes: Birdy Red 8 speed, Birdy Blue 21 Speed, Birdy Monocoque 24 Speed, 2002 Devinci Desperado, 1996 Rocky Mountain Hammer Race
When they changed to the monocoque, they made the seatpost more upright and introduced a seatpost that is a bit longer and is closed on top by an offset clamp. With the offset set back, you can achieve a similar position to the original Birdy at maximum height. If you want the seat further forward, you can turn the seatpost so that the offset is forward. In both positions, you have a better range of seat tilt angle.
The seatposts are interchangeable in fact the offset post that came with my monocoque is a better fit in my older Birdies than the original posts are. It also has height markings which is very handy.
I think that if you buy one of the new posts, it may solve all of your problems.
If you look here "Models", they show the new style post facing forwards and back. They also show an old style seatpost on the folded grey monocoque beside the Birdy Orange 9 speed.
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
I found a good selection of telescopic seatposts for a konga on ebay. I managed to get a suspension seat post fitted to my mezzo cheaply by simply using a 25.4 inner diameter standard length seatpost insert.
Presumably something could be achieved in the same manner to achive layback.
