Greenzone Folder
Bikes: 2015 Cannondale CAADX, 1994 Nishiki Performance Equipe
Quoted: 7 Post(s)
Greenzone Folder
Hello,
I have just purchased a used greenzone folder. The crank is wobbly as hell and was wondering what I need to do in order to repair this. I am guessing a new BB and crankset? If so, where can I get quality parts?
Cheers
Cheers
Quoted: 380 Post(s)
Liked 106 Times
Pictures and who made the bike would help. Anything else would just be speculation on my part as far as help. Why?? Is it a one piece, 2 piece or 3 piece crankset and BB set up. Roger
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
You can get square taper cranks anywhere. I am not certain you need to replace the BB, but it would be a nice upgrade on that kind of bike.
Thanks,
Yan
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
Bikes: Giant Defy, 1977 LeJeune #1 French Team Bike, Geoffrey Butler custom, Specialized Stumpjumper, Gary Fisher SuperCaliber, Bianchi Volpe, Melon Slice folding bike, Genesis folding bike, etc.
Given that this bike is just a week old, I would consider returning it, or at least reaching out to GreenZone, as inexpensive parts should not mean defective. Of course, you might want to get it to a mechanic as it may just be an assembly issue... something did not get tightened / adjusted properly. If it is defective, GreenZone would probably send you replacement parts. Also, I wouldn't buy new parts until I was clear about the problem. Is it a BB issue, crank issue, frame issue? (there could even be mis-threading on the cups which would prevent proper adjustment of any BB) - any # of possibilities. Dealing with this warranty issue now will also give you an idea of what GreenZone customer service will be like should you be unlucky enough to have other problems down the road.
I recently bought a Genesis and the rear axle was bent... I contacted the distributer and they were happy to send out a new wheel after I documented the problem. They even volunteered extra headset bearings as the headset was way overtightened and turned in a ratcheting manner. It was a pleasure doing business with their technical support folks. They were polite, forthcoming and accommodating... and seemed genuinely pleased to get my feedback and insights. So before you spend money, I'd get it working as the manufacturer intended before choosing where i want to put my upgrade dollars.
Oops... missed the word "used." Still I would get it to a bike mechanic before speculating what the problem is. Contacting GreenZone is still a viable approach as they could provide specs that would let you know what replacement part options are available to you.
Quoted: 7 Post(s)
I took it and said the BB was shot. The crank wobbles and hits the frame. Thank you all for the replies!
