Just got my windsor
Quoted: 22 Post(s)
Just got my windsor
Hey everyone just got my new Windsor the hour plus in. It's great so far but at some point I would like to upgrade some parts. I believe I will upgrade the wheelset first. I would like to build a lighter wheelset but i need some recommendations on lighter parts. I have a budget of about $300 for the wheelset. The Bike already has formula hubs on it so I should just Upgrade the spokes and rims I guess. Also looking for a lighter crankset.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Your cog is slipping.
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,983 Times
Now onto an actual question that I am looking for answer from you for: Why are those lighter parts going to be better?
Quoted: 22 Post(s)
No I can't lace a wheel but have a good friend that can. Correct me if I'm wrong but less rotational weight will help me climbing hills. I mountain bike the majority of the time and when I upgaded my wheelset to a lighter one I could climb hills much easier
Veteran Racer
Liked 764 Times
Wrong. Rotational inertia matters only when you are accelerating, such as speeding up from a stop. So wheel weight is no more important than other component weights when climbing. Also, your own weight is far more important than bike weight, since it is the majority of the total weight. It always cracks me up when I see some obese out of shape person riding an uberlight weightweenie bike.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Veteran Racer
Liked 764 Times
You are more likely to notice the reduced wind resistance of the Mavic Ellipse than the differences in weight. But like I said, if you want a nice lighweight wheelset that doesn't break the bank, just get the Wabis.
Fresh Garbage
I would change the brake levers because BD brilliantly spec'd long-pull lever for regular short-pull road brakes. Genius!
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Just ride it as is and see how it goes. Just fine is my guess.
Quoted: 22 Post(s)
One more thing I had looked at the regular windsor hour but they were out in my size so I just ordered the plus instead thinking they were the same frame. Now that I've looked at them again I realize the head tube is higher on the plus than the other what is suppose to be the advantage of this?
Bikes: Bianchi San Jose
I don't know about advantage or disadvantage, but it's slight more comfortable and less aerodynamic to be higher up like that.
That said, I don't know that difference is going to be that significant, seeing as how you can just bend your arms to get lower... Not familiar with the Windsors, though...
The Windsor the Hour Plus looks heavier to me. Is this the case? Any idea what your bike weighs?
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Liked 6 Times
Quoted: 22 Post(s)
Well I weighed it using the bathroom scale method and it came out to 25lbs. Today is my first at off from work so I am going to take it out about 15 miles or so and see how it does.
I'm considering getting a fuji track, which is the same frame as the no plus Windsor the Hour but with a little bit better components.
It cost $440 + tax though. Maybe I can work out a deal with the Local Bike Shop though...
Quoted: 22 Post(s)
Well sorry to say the bike did poorly over the longer ride. Even after iIhad tightened everything. The bottom bracket creaked asas well as the headset. The frame is great but the components suck! I'm going to return it and just stick with the road conversion I built. If I were you I would go with the Fuji if it as better components
pro in someone's theory
Bikes: FTP
Quoted: 72 Post(s)
Or possibly you suck at wrenching? Are the chainring bolts tight? When you say you "tightened everything" that means that you removed and regreased all the components right? Especially the cranks and bottom bracket? Bikes Direct is not exactly known for doing an excellent job setting up a bike before mailing it. When you say the "components suck" what exactly are you referring to? You said you wanted to spend money on "components" so why have you changed your mind?
