Can I put 700/35 tires on Aksium's?
ETPHONEHOME
Bikes: Diamondback Outlook low end. but I love it.
I recently picked up an Aksium 2007 wheelset. (Upgrade for me, at least)
I want to put on 35 tires, but on the mavic site, they recommend, at least for the 2008 model, only 19-32.
So, what say you?
Thanks!
So, what say you?
Thanks!
Quoted: 12191 Post(s)
Liked 1,495 Times
I'd say stick with what Mavic says. Which tire exactly? Some companies run small and some large. You might get away with a Conti or Panaracer 35.
There should be no problem. I'm using 37 mm studded tires with Mavic Cosmos rims. The recommended tire width for Cosmos is also 19-32 mm.
I've used the studded tires for two winters now without problems.
Pwnerer
