Early 90s Ti mountain bike to gravel grinder?
Thinking about converting my old Sandvik Ti mtn bike to gravel bike. This bike has seen some years of hard service on the north shore of Vancouver. I've pounded on this bike. So it owes me nothing, but it time to sweep the dust off and repurpose. The frame is old school mtn bike geometry, originally designed by the guys at Cove cycles. I've slightly ovalized the head tube through abuse, and it will need some thoughts and prayers (heat) to get the bottom bracket out. It was last changed in 2003 when bike was retired to the garage of "I'll never sell you, but other shiny objects in favour". Now wife has gravel bike, and this frame is worthy of fresh look. It has V brake mounts in rear. I've got a rigid IRO CroMo fork that is suspension adjusted that I can put on front with a disc. Frame and fork will take a 700c wheel with more than enough clearances. It has square taper Race Face Forged cranks, 24, 36 46, some old 8speed xtr bits and the worlds heaviest handlbars. I do have an old BontragerTi flatbar kicking about. Also has an Thompson seat post. So some good stuff to work with a least it was good stuff from the mid 90s.
Some questions for you guys.
1 Should I, or put back it in the rack of one day I will get it fixed up?
2 Drop bars or Flatbar?
3 new groupset or stick with the old 8 speed and keep the cranks and xtr bits on a flatbar?
4 would the rideability change much if I went with a modern carbon fork with no suspension adjustment? The frame was designed for 3-4" or suspension.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
What you mentioned (700C wheels fit, possible disc brake compatible) sounds like a great basis at the very least.
You can go completely crazy and spend a lot of money on it if you love the bike but I would suggest taking it to a bike shop or a frame builder to take a look at that ovalized head tube. That sounds like it might be a problem.
Some inspiration:
- Vintage MTB To Upright Bar / Urban Bike Conversions - C&V Subforum
- Show Your Vintage MTB Drop Bar Conversions - C&V Subforum
P.s. Get your post count up to 10 through interacting on the forum here. Then start a thread in either the Classic & Vintage or Mountain biking subforums.
EDIT: If you want an affordable group set suggestion, take a look at Microshift's Advent X 10-speed groupset.
Quoted: 576 Post(s)
Liked 1,001 Times
I'd start with stripping the frame down bare to asses its overall condition, especially the head tube before committing to any type of overhaul.
Likes For DorkDisk:
Sounds like a great project to me
Agree with what has been stated so far to get the frame checked. Only other obstacle of converting to 700 might be getting the rim brakes to line up correctly.
Frame should be fine. Might go through bearings in head set quicker though. I've riden lots on this bike with the headtube as it is.
Likes For Quiverofbikes:
Quoted: 427 Post(s)
Liked 339 Times
Normally converting a flat bar frame to a drop bar does not work out well because flat bar frames have pretty long top tubes for a given size and you want to put the drop bars right on top of the steerer tube to be in proper position, but an older MTB frame might work a little better than a newer one to convert. Still, I think safer to stay with a flat bar for best fit. I do worry about the ovalized steerer though... I'd go 9 speed Sora with a sub compact 2x crank to keep the costs down and still have a versatile bike. 9 Speed means you can mix road and MTB parts and all are compatible so you can use a 36 tooth cassette and long cage rear derailleur, etc.
Bikes: 1984 Peugot "triatholon"
I'd say do it. I picked up a mid 90's Ti Voodoo frame 2nd hand about 5 years ago and have been giving it plenty of love since - as a single speed, as a geared trail shredder, but for the last few years a bikepack rig and a kid cart. It's set up as a mullet with the rigid carbon fork. The frame is confidence inspiring as it never shows as much as a scratch in response to all the abuse it has received.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
ProMax makes some bmx v-brakes that have superlong pad adjustment slots. I've used them to go from 26" to 650b, they'd probably make 700s.
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
Do the math on the front end fork change. 4" difference is massive. You will have a totally different feeling bike because the head tube angle and trail will be wildly different than what it was designed around.
If you want to spend a bunch of money to lipstick up the frame, then use the tire size the frame was designed for and get quality wide tires. Then use a fork that has the same A-C measurement as the bike was designed around. Lastly, set the bars up so the hoods are at/close to the flat bar grips.
Getting 700c wheels for it is a kludge. Using a fork with 4" difference on A-C is a kludge. And this doesnt even address the fact that the head tube is oval...how does one garage DIY a titanium head tube back into roundness?
I already have the fork that has a similar axle -crown number to the original design. I had it set up as commuter bike. It is still a fun bike to ride and puts a smile on my face.
Oval head tube is fixed by throwing money at one of my local guys, Dekerf or Brodie. But it isn't that bad..... yet. Might just ride into ground, and hang on wall. The water battle cages rivets are toasted after decades of use too. No dents, and no cracked welds which was a problem on these frames from the riding they got on the north shore.
The top tube of mtn bike 59cm and my road bike is 57cm with a 100mm stem and 100mm reach bars. I'd need to keep in same ball park, so a 90mm stem and 80mm reach bars gets me close.
As I rummage through parts bin, I realize how much worn out crap I have. If nothing else it has helped me purge the bins.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
can you make it fit with a drop bar? if it fits well with a flat bar, adding a drop bar will add several inches to the overall reach. if you can make it fit by using a shorter stem without getting silly, that could work.
Quoted: 1461 Post(s)
Liked 1,480 Times
Is it really possible to run 700c wheels on a 26" MTB frame with a rim brake? Seems like several inches of difference, no? And assuming you can solve the brake alignment challenge, you'd end up with a much higher BB and toe overlap.
Does anyone have photos of such a conversion? I've always loved 90's MTB bikes.
I'm more playing about it with it. I have most of the bits to make it happen. Right now it is set up with a 70mm 25° rise stem, however it origanlly came with a 130mm stem and I rode that for years too.
Rear brake is the biggest challenge if i went to 700c and drop bar. I can bodge something to fit im sure. Who uses rear brakes anyways. Lol Ride dont slide, and don't hurt the dirt or so says the race face headsets.
Quoted: 427 Post(s)
Liked 339 Times
Well, I would not do this, but good luck. If you want to compare current stem to the replacement options here is a tool we ise for conversions at our shop. You can compare before and after bar positions when you change a stem to figure out how much rise and reach have changed:
Stem Comparison Tool | yojimg.net
It is a very useful tool for such things.
Thanks for the link. Love the graphical display of angles. Wish I had bothered to learn coding better when I was in engbeering school, but there was a keg to be tapped.
This video from Spindatt may give you some ideas
I cant post pics or links yet.
on pinkbike there is the same frame built up with 700c flat bar set up. Search Hummer under gravel/cx in buysell. He had DeKerf weld on the rear disc mounts. I think it looks pretty good. Hmm i think I'm going to spend a few hours seeing if I can make it work as a Franken bike with a part from every different bike part manufacturer i can pull out of my box. A six pack of beer and several cuss words later I may get it riding after long weekend.
Quoted: 427 Post(s)
Liked 339 Times
It is a quite useful tool for such things and for people that want to raise bars but keep same reach. etc. We use it occasionally; it takes out a lot of guesswork from holding up a different stem and going hmmmm with one eye closed.
