Looking for a utilitarian front rack set-up
I currently have a Bontrager BackRack Deluxe rack with a pair of Banjo Brothers Waterproof panniers. Altogether this set-up cost just a bit over $150 but has been ultra-dependable, serving me well over the past five years, numerous centuries, and daily commuting through all four seasons, and looks to keep going for many more years to come. I definitely think I got the best bang for my buck set-up possible.
Now I'm looking to get a front rack to compliment it. I'd like to be able to start carrying more and start to distribute the weight over my bike a little more evently so I don't fishtail as much when weighted down. I'm just not sure where to start. I don't need anything super advanced, just durable and reliable, ideally not super expensive either. I've always been a bit wary about the idea of moving weight on to the front of my bike for fear how it will effect handling. It looks like some front racks are designed as "low riders" so as to not affect handling as much. Do I need special panniers for a front rack? Or could I get away with just getting more Banjo Brothers waterproof panniers?
For the rack I only have the following requirements: 26" wheel frame, no special eyelets or braze-ons on the fork for mounting a rack, just the fender eyelets and the hole for mounting a side-pull brake calipers. I don't run disc brakes, just drum brakes and/or caliper brakes. Ideally the rack would be silver in color to match the back rack . Hopefully that's enough info. I appreciate any input; I just want to make sure I'm not missing any great options as there are so many out there.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
The key to using a low rider rack is to load them with all the small, high density stuff you carry, like stoves, fuel, food, kitchen stuff, etc. You use smaller panniers on the front but you put the denser stuff in them. For optimal handling, put about 60% of the whole load in the front. You carry the lighter, bulkier stuff in the rear. This is what my road touring set up looks like
2015-05-03 11.38.54 by Stuart Black, on Flickr
If you are doing off-road touring, the set up is different. I wouldn’t use panniers at all, except for very small ones. You don’t want to be hooking a pannier on a rock. Depending on where you off-road tour, the narrowness of bikepacking bags comes in handy to avoid dragging the bags across rocks. They are usually more securely attached to the bike. This is my off-road touring set up
2020-01-26 16:51:13 by Stuart Black, on Flickr
Stuart Black
Stuart Black
This is strictly for on-road touring. I’d suggest low rider panniers. Axiom makes one that uses U-bolts to fix the rack to the fork. Blackburn made a low rider rack but they don’t make them anymore. You can find them on EBay or copies of them. They use the same U-bolts. Tubus Tara is a very good rack but it is more expensive and requires an adapter that is a bit expensive. It works well but it is expensive and the Tara is already more expensive than other racks.
Likes For mornview:
Quoted: 137 Post(s)
Liked 81 Times
I commuted with low riders and 26” wheels and the panniers were just too low to the curb for my taste. I found a simple front platform rack worked fine given I could move the load back a bit Old Man Mountain brand, not inexpensive though.
Lee G might have liked the Tubus Smari, have to scour the web, they're discontinued..
Now the Tara , a fine one, & Duo Hoopless need thru fork / double bosses in and out sideof fork blade..
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
There are many brands in the market. i bought LKLM front rack, simply because that was the most economically viable solution for me.
