Front wheel lifting off ground when sprinting
Quoted: 528 Post(s)
Liked 230 Times
Do I just need to put more weight towards the front or is my technique wrong?
Thanks
Thanks
Quoted: 2483 Post(s)
Liked 2,955 Times
As you press down on the left pedal, pull up on the left side of the handlebar and push down on the right side, twisting the handlebar to counter the pedal force. As you press down on the right pedal, pull up on the right side of the handlebar and push down on the left side.
Likes For Trakhak:
Likes For Kimmo:
Quoted: 528 Post(s)
Liked 230 Times
Might try this on my trainer first, sounds like something that is straightforward but doing opposite things with arms legs is actually quite hard without practice.
Quoted: 6972 Post(s)
Liked 10,968 Times
If you’re sprinting properly (see post #2), you should have a greater likelihood of pulling the rear wheel off the ground… Though neither should happen.
I really can’t fathom how you can be pulling the front wheel off of the ground. Is your weight waaay back on the bike?
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
What a BAD and UNRELEVANT question!
Just kidding (I am imitating some forum members here). Perhaps you should lean more towards the front of the bike when getting out of the saddle and attacking. You should be feeling weight on your shoulders and arm transferring to your handlebars when sprinting.
Quoted: 20810 Post(s)
Liked 9,456 Times
Do you dislike your bike that much?
In all seriousness, a typical trainer is the last place that I'd practice sprinting; I personally won't go beyond a seated sprint on the trainer. Having the bike/rear axel locked in when trying to rip off my handlebars just seems like cruel and unusual punishment to my bike and, just as importantly, it feels completely unnatural. If you need to practice, do it on the road, but dial down the intensity and work on form before stepping it back up.
Likes For WhyFi:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
When you say sprinting, I'm envisioning out of the saddle throwing down the max power you can manage...where are your hands? Hint, if they're on the hoods, you're doing it wrong. Unless, your name starts with Guiseppe and ends with Saronni. (Rule 92)
Get into the drops, and power away. If you already are....you are massively powerful and I want to ride with you.
Quoted: 479 Post(s)
Liked 277 Times
Definitely too far back. I think. I also have a hard time understanding how your front tire is coming off the ground. With my sh***y technique, I'm often fighting the back tire skipping around.
Likes For Zaskar:
Quoted: 6196 Post(s)
Liked 4,810 Times
Is your front wheel actually coming off the ground, or is it just about to?
If it's just about to but not, that might be a good indicator you are in the right gear at that moment to get the best power and acceleration.
But I'm just guessing and imagining. Have at it guys and gals.
Quoted: 3241 Post(s)
Liked 2,512 Times
Is the OP's last name Sagan?
Likes For seypat:
Quoted: 365 Post(s)
Liked 419 Times
If you're riding without weaving all over the road, especially when riding out of the saddle, you're probably already doing it without being conscious of it. Doing different things with your arms and legs is also critical to cornering correctly.
Likes For Jack Tone:
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Yes, simple as that. Sometimes when I'm hill sprinting, I'll lift the back wheel off. Simple, move weight back. Lifting the front wheel is not good as one loses steerage.
BTW, you're doing it right.
Results matter
Results matter
Quoted: 2952 Post(s)
Liked 3,106 Times
Do form sprints in a parking lot or low traffic road. Out of the saddle and wind it up, but only with about 80% effort. Really focus on form and front-to-back balance. You'll feel it. Then start adding power.
Quoted: 528 Post(s)
Liked 230 Times
I'm going to echo WhyFi! DON'T DO THIS! It has great potential to end badly.
I prefer to have them on the hoods, but this particular time they were on the drops (which may explain some of the lower power versus my max, pretty sure I can do more on the hoods).
Quoted: 528 Post(s)
Liked 230 Times
Quoted: 528 Post(s)
Liked 230 Times
Also maybe to clarify, I am not doing wheelies, as in it isn't massively in the air, it jumped off the ground I think twice for a very short time
Quoted: 528 Post(s)
Liked 230 Times
I have a local road that has a cycle lane and almost no traffic. Perfect for this. I assume with form you mean as described in post number 2?
Quoted: 528 Post(s)
Liked 230 Times
Always big ring 8000 watt, rhymes in German.
Hm, trying to link an instagram post but it doesn't show the URL but instead the whole photo, which is kind of obnoxiously large. Anyway, it's a meme in German cycling.
Likes For ZHVelo:
Liked 10,968 Times
Hence why I asked, I probably am doing something wrong. Logically I must be pulling the handlebar upwards, I can't think of why else the front would go up. Not sure why though.
Likes For Koyote:
Habitual User
Quoted: 4955 Post(s)
Liked 8,097 Times
Likes For Eric F:
Liked 3,106 Times
Absolutely need to have hands in the drops.
Likes For caloso:
Liked 2,955 Times
Couldn't get the link to load, so search YouTube for
