Will I have enough seatpost for my bike?
Quoted: 15 Post(s)
I ordered an 18 inch bike because I read its better to go with a smaller one than a bigger one (i'm 5'10 with a 33.4-35 inch inseam 34.5-35 inch inseam with shoes on. 69 inch wingspan).
it says the seatpost has a maximum height of 37 inches from the bottom pedal stroke.
is that enough seatpost for my inseam? I'm not really sure how high up it should be besides for full leg extension.
I'll buy a bigger seat post if I have to, i'm just wondering if i'll have enough height with the stock one.
Duke Ulysses
Bikes: An old orange one for dirt, and for the other stuff: a white one, a kinda mint green one, and a black one.
Quoted: 165 Post(s)
Liked 175 Times
that is a very small bike
Not sure about an 18 inch frame for your height and inseam. I'm similar to you at 5'11", 34 inch inseam, and have a 20 inch framed hybrid and 56cm road bike and those are on the small side. I could easily go larger if needed. Smaller would be way too small. YMMV
Quoted: 608 Post(s)
Liked 352 Times
All the information you could possibly want is on their website.
https://radpowerbikes.ca/products/ra...ric-metro-bike
Look at the chart near the bottom of the page. You are on the upper edge of the smaller size, so I would have sized up. It isn't just leg length but reach to the handlebars that should factor in sizing a bike.
Quoted: 15 Post(s)
I was told that since I have longer legs but shorter arms, I need a shorter reach once I put the seat up high enough for my legs. The handlebars are a bit closer on the mid-step and they are also higher which I assumed would be best once the seat is up.
Quoted: 608 Post(s)
Liked 352 Times
Except your arms are within the normal range of your height. I am still not convinced that this is the size of bike I would choose for you. Your original question was "would there be enough seat post" and the answer is yes but at the extreme edge of the sizing chart. This tells me that I would rather size up rather than have a ton of seat post showing and have all that leverage to play havoc. This may or may not happen. This is just one opinion, let others chime in and see what they say.
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,956 Times
You are finding a lot of ways to talk about buying a rad power. Just buy the bike and when it fails get something more decent. Easy Peasy. If a bike only comes in one or two sizes and you can't test ride it probably a bike I would avoid especially if I am worried enough to create 3-5 different threads on the same topic.
