Dura Ace Flight Deck replacement options
I have an S5 Cervelo with Dura Ace Flight Deck shifters that are pretty tired and on the way out. Suggestions for replacement? I have no experience with what is currently in the marketplace and would welcome opinions.
Thanks.
Thanks.
Quoted: 1525 Post(s)
Liked 1,667 Times
If you don't care about the Flightdeck capability, and assuming you have a 2X9 setup, you can replace with Sora ST3500 shifters, which you can still find new, or Microshift R9 shifters. If you have 3X9 setup, you can replace with the current Sora ST R3000 shifters.
Liked 1,667 Times
In that case you could go with either the Microshift R10, or Tiagra ST4603, 105 ST5603 or ST5703, Ultegra ST6603 or ST6703. You can find all these on Ebay.
By the way, have you tried to flush and re-lubricate your existing shifters? That typically brings half-dead shifters right back to life.
[QUOTE=i.
By the way, have you tried to flush and re-lubricate your existing shifters? That typically brings half-dead shifters right back to life.[/QUOTE]
I'd like to second this suggestion. If done properly, even nearly completely 'dead' shifters can be brought back to life. To do the job thoroughly you need to take them off the bike, spray them completely with a stream of solvent, something like WD40 (not to lubricate but to loosen all the dried grease and crud). Work them, soak them, spray them and work them some more... Anyway, there are YouTube videos on this....rinse out solvents, dry and re-lube.
It's a little trouble, but it could save you a few hundred dollars, and give you great satisfaction!
