Which Look cleats will fit my pedals?
Which look cleats can i use? I'm fairly new to this, but i know that there are different kind of look cleats (delta and keo) Can i use both? Thank you very much!
Apparently i cant post pictures, but the pedal just says Look, bike is an old bianchi.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Most likely Keo since Delta is an old design.
Which model are the pedals?
Quoted: 6063 Post(s)
Liked 4,694 Times
There is a gallery on BF that you can upload it to and then tell us it's there. Or you can just write the URL to where ever else your pics are hosted in the plain text of your message and remove the https:// and put a space on either side of any . (dot)
No model number whatsoever on the pedal? I'm not familiar with Look or even SPD-SL. I've always been SPD. Someone else will be along soon.
On Your Left
Liked 2,433 Times
Liked 4,694 Times
Quoted: 4730 Post(s)
Liked 3,831 Times
You can use the LOOK Delta cleats or the cleats made by Wellgo (also sold/branded as Nashbar and Forte). Some say the LOOK cleats are higher quality. I use both and cannot tell any difference, Now I use the black cleats that lock out float for my knees and run Forte pedals. Perhaps with the red cleats and/or LOOK pedals there is a difference. If there is, that difference is small. Both work well.
