Post pics of your “too small” frame (and how you set it up)?
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 765 Post(s)
Liked 1,593 Times
My 58cm '72 PX-10, with the seatpost and stem maxed out, and still not 'tall' enough. After this photo I went to a tall Technomic stem and a longer seatpost from Velo Orange. It worked, but..... I managed to find a '72 62cm blue PX-10 last summer, so everything has been moved over to that frame and it's a better fit (and I can use the original stem and Simplex seatpost). I also picked up a 175mm Stronglight 93 crankset- I was a little skeptical about whether I'd even notice a difference (and if pedal strike would become a problem)- I definitely notice a difference, especially on hills.
Quoted: 765 Post(s)
Liked 1,593 Times
Likes For ehcoplex:
Quoted: 7359 Post(s)
Liked 2,497 Times
Here is my 1971 Raleigh Super Course. I figured I should use a tall stem, but now I find it's too tall for me. I've left it like this for a few years anyway, because it's close to good enough.
Likes For noglider:
First picture off the lighthouse didn't work. Full on only on the tops with extended fingers. Bike is a 53 ctc seat and 57 ctc top with at the time 130mm stem.
Went to a 100mm technomic and it's kinda high and maybe not long enough, but I haven't been riding it enough to see. At least it's doable now.
Benotto is a 54 ctc top and seat. Need to ride it more but it's reasonably comfortable. Isn't fully setup yet.
Found I can do with a normal stem a 56 ctc up to a 62 ctc seat tube. Long legs and arms short torso build. Also found 44cm bars fit me the best but most bikes seem to come with 40's.
Bikes: Old Carlton frame and fork. Old Nishiki frame and fork, single speed build? 2003 Scattante full carbon/Ultegra. 90’s trek steel with full 600(purchased for the components) Also vintage K2 full suspension
Quoted: 22 Post(s)
Liked 32 Times
What a bunch of sweet rides you’ve put together out there. Impressive bunch.
Great thread! I think I will be showing a bunch of seat post and stem on my Nishiki repaint. It’s only 52 and I ride 56. But hey I wanted to save the frame so mission accomplished.
Likes For Velosophy:
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
24” (60cm) a bike that fits
57 cm (and I think this is measured CtT so really a 56cm)
The attempt to make one fit.
Likes For Chr0m0ly:
Likes For grumpus:
feros ferio
Quoted: 1395 Post(s)
Liked 1,336 Times
Since I bought mine as a bare frame, I was on my own for a fork, and the one I installed brings the front wheel closer to the bottom bracket, and yes, I do have toe-to-tire overlap, even with a 700C front wheel replacing the original 27" and 165mm cranks replacing the original 170s. Turns out not to be the big issue the Consumer Product Safety Commission claimed it was.
Likes For John E:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 415 Post(s)
Liked 950 Times
Besides the Nitto Technomic extra-long stems, this quill stem adapter is an option for threaded forks:
High Rider Stem Adapter 28.6 to 22.2mm - Soma Fabrications
Likes For Fredo76:
Quoted: 22 Post(s)
Liked 32 Times
Ehcoplex, that PX-10 is sweeeet. That can’t be original paint can it? Either way it’s a beauty
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 987 Times
The jamis dragon is a 17 that I made fit to me thanks to a long seat post, 30° ritchey stem and high rise bar, the result is very good
Likes For georges1:
Steel is real
Quoted: 671 Post(s)
Liked 987 Times
Another one is the 1993 Giant Tourer, where I took the stem and seatpost out to the limit, again very good fit and the Giant is one ofmy most comfortable bikes
Likes For georges1:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2203 Post(s)
Liked 4,650 Times
The first bike I ever took on a vacation trip was this Gijs van Tuyl Racing Feather touring bike. The tall stem I had available for the build at the time was a bit short, but the bike turned out to be pretty comfortable nonetheless. A really nice frame. If only it were a couple of inches taller ...
Likes For non-fixie:
Quoted: 360 Post(s)
Liked 328 Times
I prefer 25.5” or 26” frames. Unfortunately, Raleigh did not make the International in that size. This is a 24.5”. Not terribly small. I just prefer the look of less seat post and stem. It rides incredibly well so it is allowed to stay.
Andy
Andy
Likes For beicster:
Quoted: 1147 Post(s)
Liked 1,773 Times
The Pro Miyata is right on brink. Here it is, with the seatpost at minimum insert. I need a tiny bit more extension. It is set up with 170mm cranks. The bar reach and drop are more than more of the recent build.
I think a 172.5 crank may take that feeling of small away. A 175 would definitely give me the extension at the stock seatpost maximum height.
Quoted: 62 Post(s)
Liked 261 Times
I recently also posted this as part of a discussion about how stem length affects fit and stability but seems appropriate here, too. This bike is small for me but it works with lots of seat post and the 110mm stem that was original on it. I think it being small is part of why it’s a blast to ride. Probably waxing too philosophical now, it may be a time machine back to when I was a kid and practically lived on my bike, and that bike was too small for me except in the first year I had it.
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1105 Post(s)
Liked 1,869 Times
I apologize if this is redundant info…
the Nitto stems,
the dynamic is normal geometry like you’d expect
the dynamic 2 has a great upward slope, for a more relaxed ride.
the Nitto stems,
"Leave the gun. Take the Colnagos."
Quoted: 4527 Post(s)
Liked 6,419 Times
Many of us are past the point where form can still overrule function, whatever it takes to get down the road well is what it is, again, all good.
I've gotten plenty of grief for many of my setups and I have no sense of humor about it, my bikes, my rules, nobody else will be riding them.
Edumacator
Quoted: 2476 Post(s)
Liked 3,205 Times
Mountain bikes seem to be easier to morph to a usable size (not too big...just ranging on the small side).
I have ridden 15” frames comfortably up to about 20/21” (likely my “true” size).
Larger seatposts, angled quill stems...
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 540 Post(s)
Liked 1,031 Times
I bought this Takara for $5 to scavenge a few parts. I put it back together with mountain bike parts to make it into a hybrid runabout.
Mid 80s Takara Advantage
Likes For Pompiere:
Quoted: 1610 Post(s)
Liked 2,216 Times
This is my smallest size in the stable, 56.5.
I wanted to keep it all Campagnolo.
The only way to make it ridable was to use a Brooks saddle which I like anyway. The saddle is still a bit low for me and the post insertion line is just above the lug.
There might be 5k miles on this configuration. It is not ridden much as I don't ride as much as I should and this is only ridden on special occasions.
In contrast, the Langster is the largest frame at 61.
Likes For SJX426:
Quoted: 62 Post(s)
Liked 261 Times
For me, if I can get 36” from the top of the saddle to the top of a pedal at the bottom of the rotation, ~28” from the sit-bone area of the saddle to where the bar goes through the clamp (without putting the saddle at an extreme fore/aft position), and if where I grip the bar is at least level with the saddle, I consider the frame a fit for me. I think I’d run into problems with this approach at the extreme ends of the size range (like you noted), but I think it otherwise works.
I love this saga of getting the right fit. Reminds me of a lot of my builds for various features. Also curious... what happened to the 22" frame !?
Klaatu..Verata..Necktie?
Quoted: 10477 Post(s)
Liked 11,991 Times
Still sitting in my garage. Frame and fork, Sante headset minus the covers, Sante BB cleaned and regreased in 2021.
Likes For genejockey:
