Value of Trek Madone cca 2013?
BumpyRidesDoneDirtCheap
Value of Trek Madone 5.5 2008?
Hello, and thanks in advance for helping out. Cannot post pictures (this is my second post).
First question is the one in the title: what is the approximate value of a Trek Madone (owner states age as approx. 10 years)?
Second, without seeing the bike, what cues do I use to determine the model? The picture I have is of the opposite side of the drivetrain.
I am currently searching for Trek catalogs, so far I found only one that's not in pdf format, and hard to navigate, so any pointers would be appreciated.
Dan
Dan
Last edited by DanXBoon; 10-11-23 at 09:14 PM. Reason: Changed the title to reflect the actual name, model, year
2008 is a more likely year
A quick search by image reveals that I may be dealing with a 2008 Trek. Still interested in its possible value ...
Source for 2008 catalog
Source for the 2008 catalog identified on vintage-trekDOTcom
I am answering my own question
Bikes: N+1
Quoted: 230 Post(s)
Liked 659 Times
That's not really a C&V bike -- it is a "modern" carbon bike. Not likely to get a lot of love on this sub forum. As always, an awful lot depends upon condition (perhaps especially so for used carbon bikes, as carbon does not like to be mistreated). To my knowledge the older Madones have little collector value -- but it should still be a nice bike to ride. if in good shape (newish tires, good cables, all mechanical bits working as they should, very clean, with no scuffs, etc.). The 2008 Madone came in several varieties with different levels of components, so very hard to evaluate without more information. I'd guess it would be worth $180-$600, but YMMV depending upon specs, condition, location, etc. Without more info really hard to say.
2008 Trek Madone is 5.5 model
Thank you, it seems that the model is a 5.5, so there is more clarity (for me) in terms of components.
I suspected that there's not much love forthcoming in this subforum - especially without pics - but I had to start somewhere.
Hopefully I will be able to post some pictures and give some more info (if I decide to visit this actual bike "in person"
Quoted: 795 Post(s)
Liked 1,811 Times
Hard to say without pics while nice bikes these hard some issues with the Bontrager race lite wheels and compact crank set, so figure on adding a wheel set with tires ancassette, a crank set with bb and pedals to the cost of the bike considering age. So I wouldn't go much over $200 on one of these and would be inclined to say pass on one of these if you need to ask questions.
Thank you zukahn1 - I will take note of these issues - in another setting, someone mentioned issues with the stock seat mast (causing cracking of the frame) - most probably will pay a courtesy visit to this bike if still available, as it is close to my bike route - pictures forthcoming when I will be released from probation
Welcome. You have six posts currently. Easy way to get more posts is to head to the Introductions forum and say hello to four of your new friends in their posts. Then you can post pix without issues.
Likes For bargainguy:
Thank you bargainguy. It seems that we have something in common - see my "handle" BumpyRidesDoneDirtCheap
A pic of the bike that sparked the initial question - I will summarize the responses I got (here and elsewhere) shortly
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 375 Post(s)
Liked 474 Times
Looks like Ultegra or 105. If it came equipped with Dura Ace, it would nearly double the value.
These ride nicely. To me, it would work great as a vacation home bike. Just bring your kit each time.
Possibly worth $600, in my estimation.
roadcrankr, thank you for clarifying the components issue - according to the catalog(ue) this is/should be equipped with Dura-Ace - is my method of coming up to this conclusion reliable? - (1) I am reasoning that colors are unique for the particular year and (2) and thus a specific bike will have uniquely associated components (if these were not changed by the owner) - obviously, I am new at this type of ”detective work” so I want to see if my line of reasoning is correct
Thread derailleur
Quoted: 375 Post(s)
Liked 474 Times
Not a Trek expert here. Your research indicates the 5.5 came with Dura Ace.
Evidently, the prior owner down-graded the gruppo. The bike's value will follow suit.
You can still enjoy riding it. Haggle it as low as you can.
Likes For roadcrankr:
To summarize, so far I got info to its possible value as follows, from various sources.
(1) Range of $400-600. (2) Range of $180-600. (3) ~$200. (4) More expensive in Europe ("like-new 2008 Madone 5.2 with Ultegra 6600 SL (instead of Dura Ace 7800) for 900€."
On another note, there were also some warnings concerning (a) the seat mast producing cracks in the frame and (b) multiple potential issues (see posts above).
If I manage to visit this bike "in person" this week, I will provide more info.
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 471 Post(s)
Liked 1,214 Times
Likes For Sedgemop:
sedgemop, thanks - one issue, apart from geometry, components, etc., is that I have zero experience with carbon
When these questions of value come up on this forum and others like it, the crowd response always tends to skew quite low. Getting this bike for $600 would be a steal. Compare what you can buy for $600 in a bike store.
If you paid $800 to $1,000 for it, I think you'd get a lot of bike for your money. These old Madones are probably among the best buys around.
They are quite durable, were built well by hand in the US, and ride great.
Tire clearance and rim brakes might be drawbacks -- they max out at about 700x26 tires. Some people like the paired-spoke Bontrager wheels, some don't -- I'm not a big fan, but they're decent wheels and often have hubs made by DT Swiss.
You're on a C&V forum, so you're not going to get a lot of cheerleading for a carbon frame, but if you look up Sheldon Brown's republished study of frame failure, Trek's USA carbon withstood more abuse than many steel frames.
Thank you ljsense. Tire clearance - I don't like the lack of it, but open to accepting it if other aspects work. I will check out the Sheldon Brown study.
What I am most fascinated with though is that some people can say "it looks like it has ..." (7800 Dura Ace shifters). This is what I cannot see at this point, due to lack of experience. Will report back later in the week, if I manage to see this bike.
As for the variation in pricing opinions (from $200 to $600, to be conservative), I don't mind it at all. It is understandable, being a function of one's experience (and saturation with) bikes, as well as purchasing power.
Quoted: 471 Post(s)
Liked 1,214 Times
Yeah, it's a little short on carbon experts around here. I think there are no appraisal opportunities over on the Road Forum. You might try an appraisal post over there anyway if they don't have rules against that type of thing.
Likes For Sedgemop:
Quoted: 656 Post(s)
Liked 470 Times
The higher-end Trek Madone bikes were credible racers. No shortage of them in the Saturday morning A group back in the day. Not sure where 5.5 was in the hierarchy those years but the Dura Ace group is a sign for me it was probably on the upper end. And yes those are Dura Ace 7800 STI levers and my assumption at this point would be the rest of the group is likely the same. Terrific 10 speed groupset. That alone adds $300+ to the price. Still brings $400+ if you parcel it out on eBay.
IMO, this is a great bike for someone riding fast on a budget and wanting to represent in a competitive group. If it's solo riding and MUP strolling you're into, you can spend much less on a perfectly suitable bike.
From what I follow, the value of a mid '10s Dura Ace bike pivots around $1,000. Anything less is a good deal. Up to $1,200 is still okay if it's what you're looking for and options are limited in your area. Again, this bike is all about your need to go fast with the local hammerheads!
plonz, thank you, the focus on the components is - again - helpful. Those perfectly suitable bikes I have, just as others do, and at great prices ($120 is my all-time upper limit). Which brings us to another interesting data point, to inject more drama into our discussion.
In my brief and friendly online interactions with the seller, they stated that they paid ”almost ten thousand for it.” $10,000? Online sources indicate a MSRP of $4000+, and the helpful parsing of components above indicates upgrades on this Madone 5.5 bike compared with the catalog model.
Is such an original estimated price accurate, or the seller does not recall after so many years, or likes hyperbole, useful in literature, but not so much in an economic transaction context? Trek did have Project One, which allowed for customization, but customization of what for so much greenback?
Quoted: 656 Post(s)
Liked 470 Times
The Specialized Tarmac would have been the equivalent to the Madone. I recall the Tarmac prices being about the same as the Venge. Again, I’m not sure where the 5.5 sits in the lineup but given the DA group, my gut tells me it was probably at the level of a Tarmac Pro. I’d further guess it was around $6K new as equipped.
Likes For plonz:
don't try this at home.
Quoted: 984 Post(s)
Liked 519 Times
My 2014 road bike has room for 28mm tires that I run at much lower pressures than the 23mm or 25mm typical of earlier years.
Likes For rm -rf:
THE END (*contains spoilers)
Well, we'll never know.
Today, before driving back to my humble abode (close to the seller's location), upon online contact to arrange for a meeting tomorrow, I am informed by the seller that they decided not to sell anymore.
Sold to someone else? Cold feet? Nothing to sell in the first place? Seen this very thread and got horrified by our cumulated wisdom?
(the last one is my favorite, given its conspiracy flavor, please add others).
So, dressed in black, I'm now mourning not the loss of something I had but of something that I haven't even acquired.
