Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
BT Edge
Old 01-25-23, 04:06 AM
Poppit
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
BT Edge
Hi all
Has anyone got any experience of cutting the Edge's seatpost to size, just wanting a few tips on how to do it in the best way.
Thanks
Poppit is offline
Old 01-25-23, 11:32 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
measure once, cut twice is what my dad always said.
Morelock is offline
Old 01-26-23, 12:44 PM
Poppit
Poppit's Avatar
Quoted: 111 Post(s)
Not sure I'll follow that advice
Poppit is offline
Likes For Poppit:
Old 01-29-23, 02:00 PM
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
Liked 76 Times in 57 Posts
I was told to cut with a dremel using the fibre cutting disc if you have access to one. The heat from the cut melts the resin and helps to seal it up I was told. Can’t say if that’s especially true, but my cuts with the disc are a whole lot smoother than with the fine tooth hacksaw - that’s the other option I’d look at
brawlo is offline
Old 02-02-23, 10:38 AM
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
lol
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Old 02-02-23, 10:48 AM
carpediemracing
Quoted: 385 Post(s)
I had to cut my Dolan DF4 post. Prior to that I cut a few steerer tubes. I used a Park carbon fiber cutter blade in a normal hacksaw. I don't remember if I sealed the cut bit.
The Dremel idea sounds better.
The dust is not good for you. When cutting I wore a mask thing (respirator mask, two filters, not full face). After cutting the Dolan post (which is big and had a lot of powder left) I put some glue on the powder so it wouldn't blow away - I learned about capturing stuff on cardboard in the auto shop, for brake cleaner you put cardboard down, let it catch/absorb the brake cleaner fluid coming down, then throw out the cardboard. I didn't think of capturing the dust when I did the steerer tubes.
Old 02-07-23, 10:53 AM
Poppit
Poppit's Avatar
Quoted: 111 Post(s)
Cheers all
Poppit is offline
