Endurance vs gravel vs Cyclocross geometry
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 209 Post(s)
Liked 315 Times
Roads and MUPs are pretty bad here, so I'd like to replace Roubaix with wider than 25mm tires. Picked up Orbea Terra yesterday designed for cyclocross, however, after flipping the stem and raising the bars higher, it feels very much like my endurance oriented Roubaix. It came with knobby tires, however, I have another wheelset with 35mm Gatorskins. Am I set with this set up as for gravel/road bike? It feels like all these terms are just marketing, and you can set up any bike for comfort vs race geometry.
Expired Member
Quoted: 3724 Post(s)
Liked 5,594 Times
Likes For shelbyfv:
Quoted: 2624 Post(s)
Liked 1,966 Times
Pulled from roadbikerider:
Likes For pdlamb:
Quoted: 6290 Post(s)
Liked 4,880 Times
What year model Roubaix do you have? The newer models come with 32mm wide tires. And are claimed to have clearance for 38 to maybe 40mm wide tires. And previous to that, I think Roubaix's were good to at least 32mm. But older models might be more limited.
I don't know what to make of your comment about flipping the stem on the Orbea and it feeling like your Roubaix. Do you want it to fit like your Roubaix? If so, why didn't you buy a gravel bike that gave you that fit without having to flip the stem. They make gravel bikes with higher frame stack that are about like your Roubaix. Not that flipping the stem is wrong. But if you wanted to have the best range of possible bar heights, you now have a bike that is at it's max and if you want more, then it can't really give that to you without spending more money.
Are gravel bike and road bike marketing terms. Sure they are. But they also tell you a few things. One being that gravel bikes will usually handle wider tires. But gravel bikes are basically a road bike with a particular focus on a special use. Gravel roads.
Quoted: 209 Post(s)
Liked 315 Times
Terra is similar year, the stem seems designed to be flipped up as well, based on the labeling that can be read from either side. I wanted it to fit like the Roubaix, but with meatier tires. It was a great deal, so I couldn't pass it up or shop around for actual gravel bike, which I'm not even sure I needed with this set up.
Likes For XxHaimBondxX:
Quoted: 3984 Post(s)
Liked 7,435 Times
Quoted: 1464 Post(s)
Liked 1,489 Times
That said - what is your question? Gravel bikes can be used with road tires t make them more suited to paved riding, and most endurance road bikes (with enough clearance) can be used with gravel tires for some light duty gravel riding. How well that will work depends on a lot of factors. There are lots of ranges of bikes within both categories and some overlap in the middle.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 343 Post(s)
Liked 242 Times
Check out Geometrygeeks.bike and compare the two. That might answer your questions.
Liked 1,489 Times
“Designed from the ground up for gravel, Terra isn't a repurposed road bike or a slimmed down mountain bike.”
I am confused about what you’re asking here, but you bought a gravel bike.
Quoted: 209 Post(s)
Liked 315 Times
Orbea Terra seems more like an all-road/gravel bike than something “designed for Cyclocross”. CX specific bikes are actually pretty rare these days and usually involve high BBs and steep HTAs to allow quick cornering, and large triangles for easy shouldering. Gravel bikes are typically longer and lower than CX, with more slack HTAs for stability on long descents.
Liked 1,489 Times
Generally speaking (and talking about new bikes):
Endurance Road: more relaxed geometry than traditional road race with higher stack and shorter reach. Usually clears wider tires for a more comfortable ride, but still has steeper head tube angles for sharp handling, and traditional 2x road gearing. Some aero shaping on tubes. Most endurance road bikes would work well for tame gravel.
Cyclocross: Race specific bikes designed to go fast on mild off-road terrain and mud tracks with tight/twisty corners for short duration. Bikes have high bottom brackets for clearance in tight corners and bunny hopping barriers. Steep head tube angles and short chainstays for fast turns and acceleration on climbs. Bikes are designed around 33mm tire widths with additional room for mud. Some hardcore CX race bikes have no mounts for bottles, fenders, bags, etc. CX bikes typically have narrow range 1x gearing. CX bikes can sometimes make good road and gravel bikes with some modifications to gearing, but might lack things that bikes specifically designed for those purposes would have.
Gravel: it’s a huge spectrum ranging from road style bikes used for smooth dirt paths/roads, to gnarly single track and bike backing. Gravel bikes generally are long and low for stability, have lower range gearing and many mounts for bags, bottles, fenders, etc. plus 45mm+ tire clearances. Gravel race bikes have more road-like geometry with aggressively low stack and longer reach, and adventure oriented gravel bikes have more MTB like geometry with more upright position and slacker head tube angles.
Likes For msu2001la:
Quoted: 2356 Post(s)
Liked 2,875 Times
I think tires and tire clearance make as much difference as anything anymore
interesting that the winner of paris-roubaix Mathieu van der Poel road the same Canyon Aero he normally rides but went with 32mm at 52 psi (normally rides 28)
and riders riding specialized stayed with Tarmacs, rather the moving to th Roubaix as in previous years
Likes For squirtdad:
Quoted: 4500 Post(s)
Liked 4,977 Times
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 239 Post(s)
Liked 989 Times
I guess it depends on the bike, there are some nuances to different gravel bikes. Everything from bikes that are practically road bikes with wide tire clearances, to drop bar MTBs. My particular gravel bike is fairly conservative and closer to road bike geometry than it is MTB geo. The geo, along with smooth gravel "race" tires and carbon hoops, definitely blurs the line with some of the more progressive endurance road bikes out there.
I know some think the different sub-categories of gravel bikes is rather absurd, but they do have different missions. I've been dabbling in gravel racing and my bike is set up very aggressively...but still a bit of a compromise, as I do a lot of recreational riding on it. Even as it is right now, I have different gearing set ups for it depending on use. If I suddenly found out that I'm the heir to a wealthy Nigerian prince's riches, I could see myself acquiring both an aero gravel race bike, as well as a drop-bar hardtail XC bike. Both are "gravel" bikes, but totally different purposes.
Likes For Sierra_rider:
Expired Member
Liked 5,594 Times
It would be possible to look at several mfg websites, compare geometries and specs of their road, gravel and cross bikes. Check three or four companies and one might have enough info to draw some conclusions. That said, there is no end to the variety to be seen at most gravel rides. I'm only a gravel dabbler but I've ridden dedicated gravel bikes, hard tail MTB, vintage sport touring and cross bikes. Only the vintage was a fail due to limited tire size.
Likes For shelbyfv:
Sunshine
Quoted: 11035 Post(s)
Liked 7,585 Times
That seems kinda goofy.
Nobody here has any idea if you are set for gravel riding with 35mm tires and your current fit. Everyone's comfort and confidence is different. Everyone's gravel and unpaved riding is different. A 35nm tire could be plenty for some and woefully awful for others.
Liked 4,977 Times
Quoted: 209 Post(s)
Liked 315 Times
Found this on Canyon website, which sort of confirms my assumption:
Before the gravel bike boom, CX bikes were the do-it-all bike and perfectly capable of handling gravel riding. However, you may need to make minor adjustments like moving your seat height and maybe raising or swapping the stem for a more upright position (just keep in mind that the bike’s frame geometry will set limits).
Given cyclocross tires are 33 - 35mm wide, if you’re not confident on slimmer tires, a bike that can fit wider tires, like a gravel bike, might be more suitable. You’ll also need to change your tires if your regular CX tires are designed for mud.
Expired Member
Liked 5,594 Times
Yep, if a 35mm tire is enough for your gravel and you can get a comfortable fit w/o kludges, go for it.
Quoted: 209 Post(s)
Liked 315 Times
eventually I'll try going wider than 35 mm. Currently, my go to bike is Trek FX 7.3 with GravelKing SS+ 38 mm, but it's pretty heavy, especially yanking it in/out of the trunk. This Orbea is literally half it's weight and I can't wait to put it back together and start riding.
Quoted: 1431 Post(s)
Liked 1,967 Times
I’ve ridden a fair amount on 32mm - 40mm tires on mixed surfaces including a fair amount on packed smooth limestone
I prefer the wider tires
you will hear / read comments that you can use narrow tires - 28 mm and even lower - with little issue … I won’t dispute that - but the wider tires are a big plus even on the smoother surfaces
Likes For t2p:
Habitual User
Quoted: 5039 Post(s)
Liked 8,273 Times
If I was forced to bear the unthinkable horror of having only one bike, it would be my gravel bike with two (or more) sets of wheels set up for different types of riding. My position on my gravel bike is nearly identical to my position on my road bike. Set up with fast wheels and tires, and road bike gearing, it would perform nearly as well as my road bike for fast road riding. Swap out for wheels with 40+mm gravel tires, and it's capable in the dirt almost everywhere I ride my MTB.
Liked 1,967 Times
wide track is not just a slogan
