Are 1X the future of road cycling?
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
I noticed this weekend that several of our active bikes don't have but one front ring.
Hill bike - 1X - Di2 FD removed. DA rings in parts bin.
MTB/Gravel road bike - now 1X
TT bike - 1X
Next on the block DI2 Venge yet another Di2 FD and rings joining the parts bin as well.
Not counting the fixie, track bikes etc.
TT bike - 1X
Silver Comet Fred
Bikes: 1
Quoted: 8826 Post(s)
Liked 2,949 Times
I hope I can go 12 speed "out of the box" in a few years when I get my next bike. Why even pay for a small ring and FD and related shift cables if you don't need it. It would probably save a nice amount of weight for the weight weenies but also add simplicity without loss of gear choices for my riding needs.
I guess the rear would be 11-30 and a 46 front. It would give me enough to push on flats (113 gear inches) and a small enough gear (41 gear inches) to do most hills. I do my best to avoid severe terrain and I'll be in my late 50's in three years when I anticipate the new bike. I mostly use the big ring now so I already am using a 9 speed.
Quoted: 40 Post(s)
TT bike - 1X
TT bike - 1X
Just an added option for buyers. But The 2x11 is still needed for lots of riders or bikes that see different terrain.
Maybe. Twenty two are a lot of gears. My 2x7 was just fine in terms of number of gears. I don't think I'd mind losing two or three more. On the other hand, what's the point?
I know a crit rider who has forgone his small ring, and for that type of riding, I think it makes sense. Really, for flat land riding period, I think I'd consider doing the same since I'm only in my small ring when I'm on a sustained climb. Chainline would need to be dialed though. I tried 1x earlier this year, and my chain would jump down to higher gears on the cassette if I backpedalled.
After riding 7 speed for a couple years, I would probably get along fine on the wide range 11 speed cassettes that we have now. 10-42 would probably be plenty of range with a 42t ring.
However, I've heard enough road riders complain about their gear spacing, that I don't see it ever catching on for anyone that wants to anything more than flat riding.
Wouldn't surprise me to see 12 speed cassettes coming along, and a 1x SRAM version will probably be first. But I'd bet there's still a double attached once they become mainstream.
Quoted: 1096 Post(s)
I'm of two minds regarding 1x. I was kind of keen on getting one, and now that I have it, although I realize its advantages with its mega range cassette (11-42), in a way, I don't like the mega range cassette. For one thing, it's big and ugly. And honestly, as long as there's just one chain ring, that mega range just isn't as versatile as a normal range cassette with two chain rings. I have a 46 now, which is fine for ordinary rides, but for a super-climby, steep ride coming up (lots of 18-25% grades), I'm planning to put the original 40t ring back on. But that's an ordeal, not something you can pull over to the side of the road to take care of like a flip-flop. It takes a shorter chain, too! So yeah, if you have a separate bike for every separate kind of ride, a 1x may seem like a natural choice. A 1x may be simple, but for versatility, a front derailleur is a nice complication, kind of elegant compared to a dumb old monster cassette and long rd.
Bikes: Surly Disc Trucker, Ribble Nero Corsa, Surly Karate Monkey, Surly Ice Cream Truck, Cannondale MT800, Evil Insurgent
Quoted: 186 Post(s)
I hope not. I still like my triples, although the next bike will be a compact. Weight does not matter to me at all, and finding a comfortable cadence is way more important than the weight difference.
The simplicity makes sense for mountain, but I hope this doesn't come to road.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Only with the advent of CVT on the rear.
For road cycling, you're more efficient with closer gear spacing than a 1X can net you for the visible future. IMHO. A double lets you get close gear spacing and fairly wide range. This ofc, ignores the needs of tourists-who still pine for triples quite reasonably.
Liked 371 Times
I know a crit rider who has forgone his small ring, and for that type of riding, I think it makes sense. Really, for flat land riding period, I think I'd consider doing the same since I'm only in my small ring when I'm on a sustained climb. Chainline would need to be dialed though. I tried 1x earlier this year, and my chain would jump down to higher gears on the cassette if I backpedalled. ...
SRAM patented using 12 speeds in the rear?
I had a wolf tooth ring. It was awesome, but didn't do a thing to help with my chain jumping situation. I didn't give 1x a very fair shake though, since I was using a goat link and a bike designed for 2x. I think a proper crank, frame, and clutch derailleur would be the ticket.
I can do my commute with in my 50 ring with a 11-28 in back (might be tough in 20-30mph winter head winds). If I lived back in S.E. Michigan that would be all I can ever see needing. However, while I'm here, and have steep hills, I wouldn't want to loose my small ring.
Quoted: 18883 Post(s)
Liked 10,646 Times
We have a lot of up and down here, so not for me. I like tight gear spacing.
Quoted: 1221 Post(s)
Liked 628 Times
Not for me, I love having different range options. Here in the Midwest there's lots of rolling hills and always plenty of headwind! I have a standard 53/39 double that I've been thinking of switching to a 53/42 just for better cadence, since I rarely encounter any big climbs. This is with my older Shimano 6400 group and a 12-26 cassette.
I can see some advantages to a single chain ring though, especially in racing. However one of my favorite things to do is come into a sharp corner or steep climb on the large ring, while down shifting the cassette to mid point, then dropping to the 39 from the 53.
This usually let's me keep a steady cadence and allows a fast shift to lower gear inches once I'm out of the corner or cresting the hill. It's also great for coming to a stop, so that I'm not frantically shifting the RD.
Liked 628 Times
TT bike - 1X
TT bike - 1X
I admit I'd have more 1x setups if I had more dedicated bikes lol. With just two in my stable I make alot of compromises, especially with my hard tail mtb. I really do use the heck out of its triple, even with the 11-34 cassette.
And then, for anyone interested in performance, only by some miracle of modern technology. I don't know why it is, but the transmissions(?) on the CVT equipped Citibikes I've ridden feel dreadful, and they aren't really any more reliable than the geared hubs.
Erik the Inveigler
Quoted: 1310 Post(s)
I have a 1x (10-50 cassette; 30-tooth crank) on my MTB, which affords 17-84 gear inches. It's great for climbing, certainly; and the gear spread is fine for rough, mountain riding in which your cadence is normally interrupted by various obstacles. But, I'd really miss the higher end if I had this configuration on one of my road bikes and I were riding on smooth pavement. So, on those bikes I have 2x and closer gearing, still.
Liked 371 Times
What are you running for gearing then, and are they 1x10 or 11s? I'm curious as to how your "hill" bike is setup.
Front is Wolftooth 44, rear is 11speed 11-29(12-29 would have been preferred, I couldn't get in same spec). I have 46 and 48 T options. Junior has crit raced with same setup, although might just go to a single bigger ring for that as the chain angle is a wee better.
Erik the Inveigler
Cadence. I was just thinking about closer gear ratios and the bearing that they have in maintaining proper cadence. Something, that it strikes me, is not talked about enough is how a smooth cadence works towards countering the effects of rider fatigue over the course of a long ride. I find that if, in the course of a normal gear change, I get the wrong gear there is this momentary "lugging" effect in which my legs are needing to adapt. Of course, this should be the exception rather than the rule; but towards the end of a ride when you are getting a bit sloppy it could have negative consequences and these could also be cumulative depending on a rider's technique. So, another argument in favor of closer gearing.
Quoted: 20810 Post(s)
Liked 9,456 Times
TT bike - 1X
TT bike - 1X
Quoted: 3947 Post(s)
Liked 7,291 Times
A lot of the gear spacing talk is more perception than reality. Looking at the gear calculator reveals that 1x can be very close to a standard setup with a 11-28 in the back and a 34/50 crank. Its only above 89" gear inches the 11-28 is significantly tighter than an 11s 11-40 + 48t chain ring. That is to say in this comparison the 11-28 is only really "better" above 22 mph or so, or if you utilise the small ring to get close ratios at lower speeds. Most don't. At least where I live, most ride the big ring all the time and cross over to the bigger end of the cassette where the gear spacing is almost the same as it would have been riding a 11-40 + 48t.
1) A double chainring setup is better above 22 mph.
2) Two chainrings are better at lower speeds, if you use the small chainring.
3) But, no one uses their small chainring very often.
Conclusion: A single chainring is almost as good as a double? Brilliant!!!
(What kind of terrain do you ride where you are always on the big ring, but stay below 22 mph?)
