Sram Red GXP crank on a Cervelo S5
Hi,
I'm trying to install a Sram Red GXP crank on a Cervelo S5 2014 with a Wheels Manufacturing Bottom Bracket but I have a hard time compressing the wave washer enough that it's almost flat. The Wheels Mfg installation guide says to add some cup spacer on the non drive side but if I do that, my chainring is rubbing against my chainstay. Should I add spindle spacers instead ? On which side ?
Thanks for the help.
Marc
Marc
Quoted: 4389 Post(s)
Liked 1,555 Times
This is the guide for the BBRight to GXP adapter. There is no wave washer.
https://wheelsmfg.com/tech/PDF/BBRIGHT-SRAM.pdf
Or are you talking about this one?
https://wheelsmfg.com/tech/PDF/BBRIG...STRUCTIONS.pdf
Do you have the outer dust cover seal on the spindle between the wave washer and DS bearing?
SuperGimp
There's a mechanic subforum here, you should try asking your question in there (or maybe a nice mod can move it for you).
