Raleigh-built 1970 3-speed - need new gum-wall tires (fatter?)
Recently got my wife a beautiful Royal Scot (black) and have a new Brooks seat on order to bring this bike to a looker. Wife also wants gum-wall tires. I personally think she'll enjoy the ride of this bike much more if I can find fatter tires than the 1-1/4" x 26" that I can find up to now.
Anyone know of a source to find wider 26" gum-walled tires?
(E.A.3)(590)
(E.A.3)(590)
Count Orlok Member
I've not used it, but the Panaracer Col de la Vie is wider than most tires in this size, at least according to Harris: https://sheldonbrown.com/harris/tires/590.html
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 847 Times
Should the tires not be 26 x 1 3/8 if you have a 3 speed with stock ISO 590s on it? I have a basic set of Kenda gumwalls on my green Sports and they are fine.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
A little less pressure is probably safe and would give you what you wanted better than wider tires.
I poked around a little myself for wider tires for an EA3 rim. Unless something's changed in the past few years there's really nothing wider than 1-3/8 except for the minor variations between brands.
You may already know this but there are several different rim diameters called 26" so make sure you get 590s if that's what you originally had. Tires marked "26x1-1/4" won't fit the rim. The name denotes a different rim diameter.
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
For the cushiest ride, spring for the Col de la Vie's. If the bike is only going to be ridden occasionally the Kenda gumwalls are fine.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
