Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
Advice Please...What Bike For This TT Profile?
Old 02-04-09, 01:09 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
Bikes: Felt FC, S-Works Roubaix, Epic Comp, Cyfac Proxidium
Hi,
Looking for some advice from the TT pro's. This is the profile for the TT of the Southern Nevada Stage Race.
My instinct tells me that a TT bike still takes the advantage on this course, but I'd like to hear your thoughts.
The equipment choices available are a Cervelo P2C or a Felt F1 (around 15 lbs). Also have the choice of full disc rear, tri-spoke front, Easton 56mm EC90s, or Reynolds 46mm DV's. What do you think, TT bike with the full aero set-up, or go lightweight, or something in between. If there's no real advantage to the TT bike, I'd rather not haul around the extra bike. Thanks...
OC Roadie is offline
Old 02-04-09, 01:35 PM
DrWJODonnell
Slow'n'Aero
DrWJODonnell's Avatar
What is the weight difference between the two setups (lightweight road bike vs full aero TT)? Also, what kind of wattage do you expect to put out (and your weight?)? Finally, what is the total ascent? Looks like about 500-600 feet over 3 miles?
My initial thought is that with an average grade of less than 4% for the first two miles, a TT bike is a good choice. If the total climbing is in the range of 600 feet, that is roughly 4% in the first three miles which is usually where the breaking point lies for amateurs. However, the 3/4 mile flat descent should push you toward TT bike. Give the stats and there might be a change, but I would guess TT is the way to go.
DrWJODonnell is offline
Old 02-04-09, 01:44 PM
cslone
Quarq shill
cslone's Avatar
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
Maybe a compromise of TT bike with the EC90's. Aero would trump weight on most of that course, but it is still uphill, so I'd make the best compromise of aero vs weight.
cslone is offline
Old 02-04-09, 01:54 PM
umd
umd's Avatar
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Are you going for sure or just considering it? I have not decided...
umd is offline
Old 02-04-09, 01:57 PM
bdcheung
Carpe Diem
bdcheung's Avatar
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
What power are you targeting for each of the sections of the TT? How much do you weigh? Do you think you'll be climbing on the bar flats, on the hoods, in the drops? Would you consider putting mini-clipons on your road bike?
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
bdcheung is offline
Old 02-04-09, 02:01 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
Dr- I weigh 168 lbs, I expect to put out between 315-330 watts for ~15 minutes. The F1 with my lightest wheels (Reynolds DV 46's) is about 14.75 lbs and 15 lbs with the Eastons. I've never weighed the P2C, my guess with the light wheels it's about 17.5 lbs, and with the TT wheels about 19, but that just a guess.
Cslone- That was one of my initial thoughts. Really the course comes down to ~3 miles of 4% or less and only .7 miles in the 5-8% range, which is where I figure that light outweighs aero.
Thanks guys
Old 02-04-09, 02:02 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
I'm registered, but that's never meant I'm going for sure I've paid for this race before and not gone.
Old 02-04-09, 02:04 PM
Brian Ratliff
Brian Ratliff's Avatar
Bikes: Three road bikes. Two track bikes.
Quoted: 47 Post(s)
Liked 4 Times in 4 Posts
TT bike. It's a power course for all but half a mile. Just make sure that you don't hit your knees on the elbow pads when you are climbing out of the saddle and bring a cassette with a 25 tooth cog. Use aero wheels, not climbing wheels; you're not attacking anyone or responding to accelerations on the climb so inertia won't matter too much.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Brian Ratliff is offline
Old 02-04-09, 02:10 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
This is somewhat hypothetical, yet reasonable:
First 2.25 miles at 0-4% AP~315
.75 miles of climbing at 5-8% AP~360 (standing on the hoods, and seated)
Final .75 miles of flat and downhill AP~320 (In the drops or aero bars)
The thought of using straps-ons on the road bike occurred, but if that's the case, I'd probably run lighter wheels on the TT bike.
Old 02-04-09, 02:11 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
As in disc and tri-spoke or 56mm deep rims?
Old 02-04-09, 02:19 PM
Cdy291
EC90's for sure, with the TT bike.
Originally Posted by RacerOne
Get the Trek, either one. You'll piss off BF and you'll be happy.
Co owner of The Chain Station bike shop.
Cdy291 is offline
Old 02-04-09, 02:28 PM
Brian Ratliff
Quoted: 47 Post(s)
I'd probably go with 56mm rims over the disk and tri-spoke, but that said, I doubt you'll be hurt much by the disk/tri-spoke combo, and they might help tremendously on the way back (I'm assuming that this is out and back).
But a solid half the course is uphill, so I'd probably go with the lighter 56mm rims over the heavier disk/tri-spoke combo. A 56mm rim is still pretty aero.
Old 02-04-09, 02:30 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
It's point to point, so there's not much downhill. I still have to ride back, but it's not part of the course. Like most of you guys, I'm leaning towards to TT bike with the 56mm Eastons.
Old 02-04-09, 02:33 PM
Brian Ratliff
Quoted: 47 Post(s)
Oh... In that case, yea, the 56mm Eastons for sure.
Old 02-04-09, 03:26 PM
esammuli
Glimmers of form
esammuli's Avatar
Bikes: Cannondale SystemSix 3, Specialized Stumpjumper M4 Comp
Funny you should post this. I was just out doing intervals on my TT bike about 45 minutes ago and wondering what to do with this course.
esammuli is offline
Old 02-04-09, 03:31 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
Yeah, my initial thought was that the TT bike probably had a slight advantage, but I was second guessing myself. I think the general consensus to use the TT bike with deep rims makes sense. I think I'll practice some short climbs in that 7% range, just to get used to the feel of it and not hitting my knees on the pads, which can be tricky at almost 6'3".
Old 02-04-09, 03:34 PM
jfmckenna
Tiocfáidh ár Lá
jfmckenna's Avatar
Bikes: A whole bunch-a bikes.
Quoted: 463 Post(s)
Liked 123 Times in 76 Posts
I don't think I'd bother bringing my TT out of the basement for that one. How much time would you really save in 2.5 miles?
jfmckenna is offline
Old 02-04-09, 03:36 PM
DrWJODonnell
Slow'n'Aero
Basically 2kg difference. Aero all the way, even if you have a bad TT position. The exception is if you fear shifting with bar end shifters on a hill, simply can't climb on a TT bike, or are going to have a day where you ware putting out 40 watts less than expected.
Old 02-04-09, 03:39 PM
cslone
Quarq shill
cslone's Avatar
A second is a second.
cslone is offline
Old 02-04-09, 03:40 PM
Enthalpic
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times in 102 Posts
Do you experience much power loss in the TT position?
Are you diligent about staying in the TT position?
Enthalpic is offline
Old 02-04-09, 03:45 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
Doing 2 x 20's I see about a 10-15w drop off in the TT position (290 vs 300). I haven't been on the TT bike that much this season, so not too sure how it looks right now. In early December I was about 10w shy on the TT position vs. road bike.
Yes, on being diligent in the TT position, especially for something shorter like this. The obvious exception being the 6-8% part of this course.
Old 02-04-09, 03:47 PM
umd
umd's Avatar
Pat, I wouldn't stress over it too much... you know we don't get points for GC in cat 4 right?
umd is offline
Old 02-04-09, 03:49 PM
jfmckenna
Tiocfáidh ár Lá
jfmckenna's Avatar
Quoted: 463 Post(s)
If it's a cat 4 stage race, though you don't get points you get a lot of consideration
Old 02-04-09, 03:50 PM
OC Roadie
Out of Commission
OC Roadie's Avatar
I won't overly stress about it, mostly curious what the TT experts thought. The course looks like it suits me pretty well and I'd like to go for GC, just to have some nice results before becoming permanent pack fill in the 3's. I'm planning on this and Orosi being my last races as a 4. Why have all this crap if I can't obsess over what to use ??
Old 02-04-09, 05:33 PM
tanhalt
tanhalt's Avatar
Hi,
To be honest...to answer that question you need to know (along with what's been asked before):
a.) What's the difference in CdA between your TT aero position and your "basebar" position on the TT bike.
b.) How does the "basebar" position CdA on the TT bike compare to your "hoods" position on your road bike.
c.) At what %grade will you find yourself coming out of the aero position?
One thing to watch out for in looking at the course profile is that you're looking at it with distance as the "x-axis". It's more helpful IMO if you can somehow estimate what the profile would look like if time was the x-axis...that way you'll see in which sections you'll spend more time (and where each option has pluses and minuses). My gut feel is that you'll be spending a lot more time "climbing" and out of the full aero position than in. In that case, go with the lightest, most aero combo you can put together.
Without looking into it further, if it where me, I'd probably go with your road bike (especially since you don't want to drag the TT bike along), EC 90s, clip-ons, skinsuit, booties, aero helmet...and the wheel choice might be different depending on what tires (and type - tubular? clincher?) you have on each set...
tanhalt is offline
