3/32 cog & 3/32 chain with 1/8 crankset
gotta EAI 3/32 cog . wanna buy sugino messengers from my LBS but they only got the crankset in 1/8. i told the guy i had a 3/32 cog and 3/32 chain and he said the 1/8 cranks would still fit nicee. is he right? or is that bs.
GONE~
Is the LBS ran by monkeys...or did you misinterpreted what he said.
1/8" crank + 1/8" chain + 3/32" cog is fine, but 3/32" chain will not fit because it will be too narrow to fit onto the crankset.
1/8" and 3/32" both indicates how wide the chain is.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
3/32" chain will not fit the Sugino 1/8" chainring on my SS frame. I have tried it. A 1/8" chain is cheap and will work fine with the 3/32" rear cog.
Have the LBS monkey pull out the crankset and a 8 speed 3/32" chain and try to match them up.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
You should've called him on his bluff when he told you. Think about it. 3/32 is less than 1/8, which would be 4/32. Obviously something too thin can't fit onto something that's too wide.
KoolKeith
Singlespeed & Fixed Gear
6
03-23-12 06:13 PM
plowmanjoe
9
05-20-10 12:05 PM
