Why did the orientation of the square taper change from diagonal to parallel?
Most modern cranks (new bmx cranks) new TA (Carmina) cranks all have their square taper parallel in their cranks, the older types all had it diagonal. Does anybody know why?
Makes it impossible to mix and match.
Quoted: 4210 Post(s)
Liked 3,878 Times
Being the cynic I would first think of the need to source from the manufacture that started it (like Schwinn did with it's slightly different dimensional standards way back when). The second thought is a work around to some patent. Third is an engineering thought.
Maybe people smarter then I can chime in. Andy.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Quoted: 5793 Post(s)
Liked 2,585 Times
From a design standpoint it doesn't matter on the right crank because there's plenty of meat. But on the left where there's lot's less the orientation can affect the strength and whether it'll crack. Most forged cranks are diamond, but many lower end cranks are square. As pointed out earlier, this isn't so much a matter of a change, as of a design difference of opinion.
FB
Chain-L site
FB
Chain-L site
just 2 ways to do the task.
Manufacturer discression.. it was their choice, ask them.
Quoted: 2026 Post(s)
Liked 1,096 Times
Bikes: '02 Lemond Buenos Aires, '98 Fuji Touring w/ Shimano Nexus premium, '06 Jamis Nova 853 cross frame set up as commuter, '03 Fuji Roubaix Pro 853 back up training bike
I respect the fact that the spindle manufacturers held their ground and stayed with diamonds rather than jumping on the square bandwagon.
Some cranks are square, some cranks are diamond. There is no standard and what a manufacturer uses is entirely up to them.
Which part are you having trouble understanding? We'll type it more slowly.
I don't know the answer to the question, but the ability of BF posters to take even the simplest questions and turn them into snarky contentious arguments is a constant source of wonder and entertainment for me. So thanks for that everyone (although I will add that mechanics seem slightly less prone to this, in my observation, than, for example, the roadie forum where threads degrade into gibes and snark pretty much as a matter of course -- quite entertaining) .
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
The question nobody has addressed is whether a square crankset can be used on a diamond spindle, or vice versa.
Liked 2,585 Times
The answer to that is yes, assuming the cranks and spindle are both the same taper - ISO or JIS. Of course you have to replace both cranks at the same time.
FB
Chain-L site
FB
Chain-L site
Quoted: 1858 Post(s)
Liked 664 Times
Quoted: 67 Post(s)
Liked 67 Times
(It was supposed to be a joke!)
Bicycle Repairman
The manufacturers of aftermarket left crank arms have a very powerful lobbying group in DC. They force crank manufacturers to make both styles and alternate years when diamond and square tapers are spec'd on new bikes. That way I have to stock six different left arms (12 if I want to have black and silver. Even more if we want to stock the oddball road sizes) instead of three in my parts bins at the shop. It's all a big conspiracy fueled by dollars from big left crank and their Washington cronies...
Quoted: 503 Post(s)
Liked 634 Times
Liked 2,585 Times
Actually the Congress is split with different parties in control of the House and Senate. They cannot pass a bill mandating either Diamond or Square orientation. This happened before, which lead to a compromise solution in the form of the spline drive system. However with square and diamond cranks grandfathered, the problem remains, so the current proposed solution is to orient the hole so the corner is exactly in between both, or pointing 22.5° off the axis of the crank.
FB
Chain-L site
FB
Chain-L site
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Just looking at these two examples, it seems that the diamond makes a stronger 5-bolt crank, and the square makes more sense for a 4-bolt crank. A change for either would leave less "meat" at some of the corners.
Liked 2,585 Times
So there's no one always correct answer, and either is fine assuming the rest of the design is consistent.
FB
Chain-L site
FB
Chain-L site
Yeah, wish I'd gotten the memo before I ordered the new left arm for my old Suntour crank. A real wtf moment.
