New Helmets....Less Vents? Atmos
Pleasurable Pain
Bikes: Voodoo Rada, KHS Alite 4000, Smith & Wesson Tactical, Diamondback Response
So I started getting back into cycling and I noticed my old Atmos from 2007 helmet has seen better days, mainly cosmetic. I started searching for similar helmets and find it hard to find anything comparable in terms of venting. They all are basically a bubble with 18 or so vents where my old one had 26. Am I going to die tomorrow if I use my old Atmos? I know you are supposed to replace your helmet every 5 years, but can they not make helmets that are cool anymore? I have thick hair and just seeing the pictures of those old new helmets looks to be a hot sweaty mess. Am I the only one who wants cooling AND safety? Maybe you cant have both?
Quoted: 6196 Post(s)
Liked 4,810 Times
Maybe you just need to look at more than one new helmet?
What about these....
https://www.giro.com/p/aether-mips-r...300000099.html
https://www.specialized.com/us/en/s-...=320642-187323
And there are less expensive too.
https://www.specialized.com/us/en/sh...yproperty:Road
Now that I've done some of your leg work, you'll have to do the rest to see all the other options for well ventilated helmets.
You might die anytime anywhere. It's likely it'll still give you better protection than nothing at all. Though if you can afford it, get another. My helmet is due for replacement.
Likes For Iride01:
Pleasurable Pain
See, I don't want more than one helmet. I just want one good one, rather than multiple bad ones, more isn't always better.
I have seen the Giro Aether with its less than stellar vents and motorcycle bubble look, and the S-works more of the same. You have to admit those are a far cry from 26 vents. Sorry if I made it sounds like I didn't search for helmets myself with similar or comparable specs in terms of venting. I don't expect you to shop for me, its more of a "What changed in cycling helmets to cause this shift?" question.
But.....
My question about dying wile using the Atmos was mostly facetious, but a Mfgr of helmets would want you to believe you might. Like I said I have been out of the game for a while, are these older helmets dangerous? If that's case I'll suck it up and strap one of those tupperwares to my head and die of natural heat strokes (joking btw).
But.....
Liked 4,810 Times
Between the 80 dollar helmets and the 300 dollar helmets sold here in the USA and a name brand helmet, I doubt you find any that are a poor choice for your protection.
The difference between the 3 star helmets and the 5 star helmets is still subject to a lot of opinion because they can't test for every situation and angle that your noggin might get bashed.
I have no idea what your Atmos looks like, but I ride in 85 - 100°F plus temps and my helmet which is one of the two I showed you provides plenty of airflow. Also helmet makers have been advertising that they have improved airflow through helmets by making the holes and tunneling through the helmet more aerodynamic.
So based on that, it might be that counting holes and equating that to good airflow is not a reliable method.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Especially if you're comparing non-MIPS to MIPS helmets (or other designs to deal with rotational effects). We can figure a lot of reengineering has had to go into ventilation consistent with structural changes prevalent in the industry. Strikes me that fewer better placed and better shaped vents makes a lot of sense when essentially the 2022 version of a helmet is more likely "a helmet within a helmet" than a 2007 model.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
My first thought is that fewer well designed holes could work better than more poorly designed holes.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Here in southern AZ my number one priority is ventilation. Giro Aether. Done.
Quoted: 4415 Post(s)
Liked 4,867 Times
There are plenty of modern helmets with great ventilation. It's not just about how many holes they happen to have. I have a Lazer Genesis (G1) which vents really well and is rated highly for safety.
Quoted: 5224 Post(s)
Liked 3,584 Times
that S-Works Prevail II Vent helmet looks terrific
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
I'm sticking with my 2009 Bell Array, because not only does it have better venting than current offerings I've seen (from Bell, Giro...), but it covers more of the side of my head. I'm not going to pay out money and get less protection.
Quoted: 283 Post(s)
Liked 262 Times
It’s not just the holes, it’s the holes combined with the inner channels that ventilate your noggin. If you skeletonize the shell with too many holes, risk of cracking and whatnot goes up. Ventilation balanced with required strength. My guess, some of Giro’s new helmets are an improvement over your old helmet design.
