Tips For Getting Tire Pump Off of the Valve Gently
Firstly, I acknowledge that this is a pretty lame question as far as bike "mechanics" go.
In an attempt to be responsible cyclist, I try to check my tire pressure at least every third ride. I check every ride if I'm going to be far from home.
I struggle mightily to get the pump attachment off of the valve when I'm done pumping. This is especially the case for my Schrader valves. I wind up twisting and prying the valves vigorously. I'm worried that:
1) This will damage the valve and cause the very flats that I seek to avoid and/or;
2) I lose a lot of tire pressure in this process on my smaller tires an wind up going through the exercise two or three times.
Anybody know of a way that I might improve the situation?
Are some pumps better than others in this regard?
Is there some technique I don't know about?
Is there a little gadget on the market that would help me to pull the pump attachment from the valves more cleanly?
It sucks starting every ride wondering if I've torn a crack where my valve adjoins my tube as a result of incompetence.
Quoted: 4806 Post(s)
Liked 3,932 Times
What is your pump? Hose or no? I've used the Zephal HP and HPX forever. No hose. Head locks on with a lever. I pump with the valve at 12 o'clock. Open the lever. Do a mini karate chop down to knock the pump of cleanly and straight. (This was also how were were taught in a long-gone millennium to remove Silca pumps (minus the lever bit as they do not have it).
It's a Serfas floor pump with a hose. It's meant for bicycles but, at the same time, it's department store grade. In most respects, I like it. I'll try the karate chop but I'll likely be chopping hose rather than firm plastic. Another issue that I didn't mention is that, because I pull so hard on the attachment sometimes, I wind up punching the spokes and hurting my paws. Again, a lousy way to start a ride.
Likes For holytrousers:
I just googled the Zephal HP and now see how the karate chop works on it. I'll give this thread 48HRS then I'll buy one. It seems somewhat odd that a portable pump would replace my floor one in the garage but, then, I don't much care if it solves my problem.
Quoted: 3514 Post(s)
Liked 2,927 Times
I wouldn’t recommend a frame pump to keep your tires topped off. Invest in a Silca floor pump and call it a day. I prefer the pista plus. It has a thread-on Schraeder valve. Every part is replaceable. Last pump you’ll ever own.
Liked 2,927 Times
Quoted: 6196 Post(s)
Liked 4,811 Times
Put some plumbers grease or silicone grease on the head of a swab and lube up inside your air chuck. Usually there is an O-ring or seal that gets dry and starts grabbing too hard on your stem. Might could just put a blob on your valve stem if you don't have a Q-tip handy. But if your air chuck has been doing this a long time, then you probably need a new air chuck.
You can find replacement chucks and hoses from the maker of your pump or at various bike shops online.
Likes For Iride01:
I suppose that one option would be to just throw some pliers around the valve loosely and karate chop that.
Reverse pliers might do the trick but I don't know of any that open as wide as I'd probably need them to and would be gentle-ish on the valve.
I feel like this Park Tool is darn close to what I want even if it's meant for something else. No Shrader option though.
Quoted: 1109 Post(s)
Liked 1,200 Times
It's not a dumb question because it's easy to damage where the stem meets the tube by removing the chuck by twisting or wiggling it off. I always try to pry off with my thumbs, straight in line with the stem. That's the goal anyway. It's much easier with smooth stems vs. the threaded ones. I have more problems with the lever kind than with this kind:
Liked 2,927 Times
If you like your pump except for the chuck, you can easily replace it with any number of aftermarket options—some with a thumb lever, some without (see the image Camilo included above).
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,444 Times
I bought a Lezyne pump that threads on the valve, and you unscrew it to take it off. It eliminates the stress on the valve, but will put some on you if you haven't previously tightened your valve cores.
Quoted: 4210 Post(s)
Liked 3,878 Times
Spit into the chuck first. Bubbles indicate a poor seal. The saliva lubes the chuck's removal. Of course using good attachment and removal techniques helps. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 4,811 Times
The metal chucks can be just a crappy made as the poorly made plastic chucks. If you pay high dollar for a swanky looking metal chuck and it subsequently goes bad after some use, then you may suffer longer with it because you spent the big bucks on what was to be the absolute best.
Although my air chuck is metal. It only cost me about four bucks. It's about five years old maybe a tad more and now is starting to grab onto valve stems when the clamp is released. A little grease has helped some. But I expect it'll be up for replacement soon.
Replace the head. They are pretty cheap. Also, when dealing with Presta valves always pump at 12 o'clock because the weight of the chuck and hose and the force you may apply to get it off tends to bend and then break the valve. At least at 12 o'clock it is pulling straight down and when you need to remove it you apply downward pressure. I learned this the hard way after I'd damaged countless valve stems. I bought a bunch of replacements with the tool included, but haven't broken one again,
senior member
Many comments are pointing to the chuck and by association the pump - my vote would be to replace the floor pump, don't think OP needs an unthreaded valve stem - I now have gone the compressor route but still have my Specialized floor pump with flip lock chuck - I had to push it on the valve pretty hard to get a good seal and taking it off required a good hard pull but it wasn't near as bad as OP described - there are lots of good floor pumps out there , Topeak , Lyzyne , SKS , etc .
Oh, and currently I'm using an EVT inflator connected to a Craftsman 1 1/2 gallon compressor .
3-in-1 Inflator — Efficient Velo Tools (EVT)
Maybe some of the problem is the flip-lock head, you are applying pressure to flip it but in the meantime the valve stem is somewhat delicate.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 3,932 Times
Zephal HP and HPX are easily up to being every day pumps. I used nothing else for a decade including all of my racing riding sewups only. Yes, it takes longer than floor pumps. But on and off are fast and reliable with decent technique. (The simple karate chop.) And those 100 or so pump strokes? A little arm exorcise never hurt a cyclist.
Liked 2,927 Times
Anyway, I doubt those pumps could get to the 140psi I need.
senior member
Liked 2,927 Times
Price isn’t for the faint of heart. But it’s built to last forever.
