new max heart rate
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
new max heart rate
today i hit a new max heart rate, not a goal, it just ahppened. never thought it would but as it turned out my usual climb was closed due to the road being used as a race track so i had to head up a much steeper climb. i managed to knock my max HR from 171 to 172. it is very rare that i even get in the 160 range. the climb was 15% which is twice the other climb. i am still amazed that some of you have MHRs in the 180 range at the ages i read about. but of course, we are all different.
Quoted: 6196 Post(s)
Liked 4,810 Times
Could just be rounding up or down. Might have only been a 0.1 bpm difference! <grin>
Likes For Iride01:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Yeah we are different and really I can only guess. When I run, my HR might be 160 for 30 or 40 minutes. So definitely max HR is not the 160 from the simpleminded 220 - age, or I wouldn’t be running in relative comfort. I infer 185 from assuming 160 is in the vicinity of threshold. And I’ve seen higher. I kinda don’t think there is a clearly defined max HR, but I’m no expert on that.
Otto
Otto
Liked 1,182 Times
yeah, i suspect if one tried to actually measure their actual maximum heart rate it could very well be the last few beats that heart ever does. i'm moving mine to 172 now regardless of what Iride01 says . its all anecdotal anyway.
i'll tackle that hill again in a few weeks once i develop some muscle in my chicken arms for the OOS effort.
Likes For spelger:
Quoted: 3242 Post(s)
Liked 2,086 Times
Likes For Steve B.:
Quoted: 4415 Post(s)
Liked 4,867 Times
That’s very unlikely otherwise I would be dead pretty much every week! I can hit my limiter fairly easily during a full gas effort and often do. I’m always amazed how consistent max HR is too.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4392 Post(s)
Liked 3,016 Times
Bikes: Lemond Poprad, Cervelo Soloist, Cannondale F4, RANS Velocity Squared
Quoted: 42 Post(s)
Liked 67 Times
There was a method of measuring what your training max was, it was documented in a book by Sally Edwards back in the 90’s. I did this test, 15 minute session on a wind trainer riding as hard as you could to maintain a top of HR. Then you spin for 10 minutes, then repeat, spin for 10 again, then repeat a 3rd time. You avg. together the 3 HR numbers you were able to achieve and hold, mine was 192. I use that number now, 30 years later, to assume my max is 162.
I seem to recall reading something about that max h/r is genetic in a sense (you're max h/r is what your heart/internal pacemaker can fire). But that could be old news.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Liked 2,086 Times
For those who run, there was something like this I followed back in the 90s using a track. A bunch of 400s or something like that. Came up with a max of ?? I think like 196 or 197. Based all the zones off of that. But that was then.
I’ve no idea if any of the methods for determining and using these numbers are still considered valid. I should ask my cardiologist next time I see him.
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 97 Times
Max heartrate is how many (most?) of us figure out where the zones are including threshold. We start from max and calculate from there. Unfortunately many use a formula that is often way off to calculate their max.
Liked 4,867 Times
There is no formula that can accurately predict an individual’s max HR. The most commonly quoted 220-age formula is miles out for me. There is simply too much individual variation to make any generalised formula useful.
Likes For PeteHski:
Quoted: 242 Post(s)
Liked 455 Times
I managed to hit 180 bpm this season in a race...while it was only for a few seconds I did hit it. My max last year, in a hard group ride on a climb, was 182.
My lactate threshold is 165.
Not bad for a 68 year old of 63.5k.
It is likely training, diet, rest and genetics...
climber has-been
Liked 3,567 Times
Training Peaks calculator lists these options for threshold based zones:
It seems to me that for training purposes, zones based on threshold (or maybe VO2max) are more practical. It's also quite a bit easier to determine LT than max. heart rate.
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,990 Times
I’m impressed that so many of you monitor HR and take the time to make sense of it.
FWIW, here are my numbers over the last 6 months.
The low number is asleep, of course, and the high number on a particularly hot extended climb. No idea what it means.
Liked 1,182 Times
it means you have a huge HRR of ~150. i started reading up on that and found that a low resting HR was not as good a thing that i thought it once was. mine is just over 50. i don't pretend to really understand it all. heart is going to do what it is going to do. i may be capturing the data but it is captured on my phone and that is eitehr in my saddle bag or jersy pocket so not really knowing what is happening until the ride is over.
Likes For spelger:
Really? How do you do it? I figured an accurate reading required stuff that was beyond what most of us had readily available with finger pricks and all that.
I think I know what it feels like and in the past have just siad it was where I could carry on a slightly breathless conversation or sing a line, but never tried to use that to assign a number.
climber has-been
Liked 3,567 Times
I just figure my highest 20 minute heart rate is my LT.
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
20 years ago, trying to win races (sometimes successfully), or training to win races, was when I would see my max HR. These days, I see my max HR when I'm at my absolute limit trying to hold on to the tail end of the group ride, going over a short climb. Survival has replaced victory as my measure of success. Sigh.
Likes For Eric F:
Habitual User
Liked 8,098 Times
Pretty much the same for me, too. It doesn't take long before that feeling becomes identifiable, and you can control being above/below that threshold. However, the threshold BPM may vary from day to day depending on fatigue, environment, etc. IMO, recognizing how your body is responding is the critical part.
Liked 4,867 Times
Many HR zone calculators work from threshold heart rate, with zones defined by Andy Coggan or Joe Friel.
For those who hesitate to push to max hr to find it... I'd suggest that one could start with the formula and then fudge the settings to get reasonably accurate results by playing with the max hr number until they got % in zones that matched their actual efforts. If you are showing time in the red zone and know you weren't in the red you can assume that your max hr should be set higher. If the opposite is true it should be lower.
I think you could zero in way better than what any of the formulas do.
OTOH, you could just test for max hr
