Any desktop weather programs?
Hey guys.
I am looking for a free desktop weather program that shows current temperature, wind direction, and speed. The only ones I have found just show temperatures on your taskbar, unless you open them each time. Even then, the one I installed this morning (weatherbug) only updated once an hour. That's pretty worthless.
Anything else out there?
Portland Fred
You have a number of options. If you have programming skills, you can get the weather data directly from weather stations.
Be aware that even official weather stations often post data once per hour. One thing you might consider is getting your own weather station. It's quite a bit of fun, and you have a lot of control over the display. I like mine https://weather.alptown.com/ but since I have dialup, it only updates when I'm at work to avoid tying up my phone line.
Later this year, I'm taking the broadband plunge so it can update in real time.
p.s. warning: many free weather utilities (I think weatherbug is one of them) installs adware that can slow your computer down quite a bit. Be sure to read the licensing agreements.
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
Originally Posted by pricklycommute
Hey guys.
Gatoraid powered engine
Bikes: A mixed-breed beater util/commute rigid hybrid I frankensteined out of assorted resqued components, called "Streetdancer". Ugly as sin, yet beautiful in function.
If you use the Firefox browser, look for an extension called 1-click Weather. It pulls weather forcasts from the Weather Channel website, customized for your location. 100% spyware free, too, plus free as a bird.
IMHO, it smacks Weatherbug around mercilessly.
I think the National Weather Service is much more reliable.
This is a great tool for cycling. It predicts wind, temp, windchill etc. by the hour. (click on hourly weather graph from first link)
Easily distracted...
Bikes: Surley Cross Check
I like Weather Pulse. Puts a small window in one corner of the screen displaying a graphic of the current weather, current temp, and a text description of the current weather (cloudy, sunny, windy, etc). Not a ton of info, but easy, quick, and seems to be adware free.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
I prefer a little surprise in my life.
The Cycle of Life
Bikes: Trek 520, Eclipse Carbon, Eclipse Al, Unknown Fixie.
gnome has a cool applet that sits on a panel, it even has a radar map if you set it up.
ohh yeah winblows.... sorry.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
Survival of the Fitest
Bikes: 198? Univega Custom Maxima, 2009 Motobecane Fantom Cross Uno
I use the Firefox 1-Click and also check the National Weather Service www.noaa.gov
Originally Posted by oboeguy
The current release is a buggy POS. Forecastfox is excellent, using the AccuWeather assuming that AccuWeather is accurate in your area it seems (it used to use the Weather Channel, but no more for whatever reason).
I've never been able to get forcastfox to work corectly. It would sometimes crash the browser when trying to call up a forecast.
Antelope Valley cyclist
Bikes: Lynskey, Brompton, Public
If you go to weather.com, they have an online store. That's where I bought my weather station. Just a little one that tells me the temperature inside and outside. Here right now, it says it is 63 degrees inside and 43 degrees outside. I find when I check weather.com or the Weather Channel that the temperature there is taken only once an hour, so the outside sensor gives me a more accurate reading of what it is here at any given time.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Olé Olé Olé Olé T-C...N-J
Bikes: 1985 Trek 620, 2005 Cannondale R700
Originally Posted by Ranger
Yeah but all of the spyware is priceless. .
I use the National Weather Service's hour-by-hour weather graph.
1985 Trek 620 (picture pending)
2005 Cannondale R700 (picture pending)
Bike & Build
NJ Bike Map
Bike & Build
NJ Bike Map
Bikes: IF, Litespeed, Bianchi, Fisher, Dahon, Schwinn, Burley
Nobody has mentioned:
https://www.weatherunderground.com
This is not standalone but informs well enough.
JG
JG
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
The ForecastFox extension for Firefox. If you're not using Firefox, then you're hopeless... Oops, I mean I can't help you.
Of course, not many places HAVE data more than once per hour. If you want constant updates, check weather underground (wunderground.com) and click "personal weather stations" to see if any individuals have weather stations in your area. (https://www.wunderground.com/weathers...stStations.asp)
If not, spend $300 and put one in yourself, and register it with weather underground.
darling no baka
Location: I come from a place where the nuts hunt the squirrels
Bikes: Bike Friday New World Tourist, 2005 Trek 520, 2005 Raleigh Companion
Dragon... ATTACK!
Dragon... ATTACK!
Weather watcher is nice and no spyware. It will show the temp on toolbar and all you have to do to see wind/feelslike temp,humidity or a bunch of other stuff is to hover your mouse over top. no need to click on it.
https://www.singerscreations.com/RSS/Posts/297.asp
Bikes: Pake fixie. Klein Reve (for sale, https://www.theveer.net/gordons_klein)
JG
JG
For many zip codes it includes private weather station readouts. It also has times of sunrise and sunset, which I often need for planning.
Bikes: 02 Jamis Coda
Hey guys.
Dubito ergo sum.
Bikes: Bessie.
In Canada The Weather Network has a free taskbar plug-in for Window, see WeatherEye.
You could also add any web page to your desktop as active content (Windows 98 and above).
Or just make the weather forcast page of your favourite weather site your browser's home page- so everytime you open your web browser, the current conditions are there.
I know that the OP is look for software for some variant of Windows, but I thought I'd mention the wonderful Rader In Motion widget for OS X Tiger for anyone using a mac.
Proshpero
Bikes: Fixed Surly CrossCheck, Redline Conquest Pro
There is a weather extension for Mozilla Thunderbird as well (I think just called Weather), but it also only updates once an hour, and can only be set to NWS stations, which may not be local enough.
Bikes: Jamis Aurora Elite (2011); Trek 520 (2006); Specialized Globe (2005); Lemond Zurich (2003)
I wrote my own. On startup each morning, it downloads the verbose weather forecast from RSSWeather and displays it. No web browser necessary. Let me know if you'd like a copy.
