remote locking devices out there?
Old 11-28-06, 04:26 PM
adamtki
Bikes: Soma cyclocross with Bionx PL500HS
Are there any locks out there that can be unlocked/locked remotely? Especially one that can lock the wheels in place? I think having something like that can save a lot of time over the long run.
adamtki is offline
Old 11-28-06, 04:56 PM
CrosseyedCrickt
erm....
ummmm....
how will that save time?
You'd still have to manually run the cable or wot-not.
*confused*
CrosseyedCrickt is offline
Old 11-28-06, 05:03 PM
Lossy
Commuter hits the trail.
Like inside the hub so it wouldn't rotate?
Lossy is offline
Old 11-28-06, 06:11 PM
rs_woods
Bikes: Trek T80, Trek SU200, Trek SU100, Giant Bowery
Trek used to make locks like that on their T80 bikes. It wasn't remote controlled, but it was just as quick with a key (think "car door" easy). I don't know of any remote controlled ones, but I think it would be useful against theives. Obviously when locking the bike up and leaving it you would need to lock it to something stationary, but if you're riding by at night and assaulted for your bike, you can just flip on the remote lock and the thief goes nowhere & has no idea why they're going nowhere.
rs_woods is offline
Old 11-28-06, 06:42 PM
Frankenbiker
Slow ride, take it easy -
Frankenbiker's Avatar
Location: Corn, corn, corn, corn, corn, corn, soybean, corn fields of Illinois
Bikes: 98 Mongoose Cambridge with Xtracycle
Imagine, if you will, a miscreant stops you and demands your bike. You calmly hand over your priceless ride and watch as he pedals away. You wait until he has picked up some speed, say about a block away and in traffic. Then… you reach into your pocket and press the remote control. Steel bolts spring out of their stored position on each wheel, passing through the spokes and immediately lock up both wheels. The miscreant does a face plant in heavy traffic. Bwahahaha. These bolts, of course, latch in their extended position and can not be pushed back in place without a reset command from the remote control and physically pushing the bolts back into position while pressing the remote control. Sounds so James Bond-ish. I love it.
Frankenbiker is offline
Old 11-28-06, 06:49 PM
deputyjones
Striving for Fredness
deputyjones's Avatar
Bikes: Old Giant Rincon
When I was in the Netherlands a lot of newer bikes used a rear wheel lock that was permanently mounted to the seat stay cross bar (the thing above the rear tire. sorry, new to bikes and that part probably has a name that I am unaware of.) They were typically spring loaded and worked with a key, but I could see how that could be easily adapted via some solenoid type mechanism to work remotely.
Although that was effective in the Netherlands it would be worthless in the US as someone would just throw your whole bike in the back of their p/u and drive away.
deputyjones is offline
Old 11-28-06, 07:00 PM
Air
Destroyer of Wheels
Air's Avatar
Bikes: Surly LHT, Dahon folding bike. RIP Nishiki Sport, Downtube IXNS, 1950's MMB3 Russian Folding Bike, MTB
Liked 7 Times in 5 Posts
I was just thinking that - awesome! Even better if it had GPS capabilities so it didn't matter where you were!
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Air is offline
Old 11-28-06, 07:05 PM
Mchaz
Dances a jig.
Mchaz's Avatar
Bikes: 2007 Surly Long Haul Trucker 54cm (Commuting/Wanna' go tour so bad), 1985 Trek 670 21" (Road), 2003 Gary Fisher Tassajara 17" (MTB), Cannondale DeltaV 600 (commuterized MTB), some junker bikes in my garage
Imagine, if you will, a miscreant stops you and demands your bike. You calmly hand over your priceless ride and watch as he pedals away. You wait until he has picked up some speed, say about a block away and in traffic. Then… you reach into your pocket and press the remote control. Steel bolts spring out of their stored position on each wheel, passing through the spokes and immediately lock up both wheels. The miscreant does a faace plant in heavy traffic. Bwahahaha. These bolts, of course, latch in their extended position and can not be pushed back in place without a reset command from the remote control and physically pushing the bolts back into position while pressing the remote control. Sounds so James Bond-ish. I love it.
The part that's even more funny...The unit mal****ions and sends you into a face-plant in hevy traffic.
Mchaz is offline
Old 11-28-06, 07:07 PM
CrosseyedCrickt
forego the remote part
if you have CPS disc brakes just tighten them down when you park it and remember how many clicks, then untighten them before you start going again
Old 11-28-06, 07:20 PM
ax0n
Trans-Urban Velocommando
ax0n's Avatar
Bikes: 06 Trek 1200 - 98 DB Outlook - 99 DB Sorrento
GPS? Hopefully you mean satellite transponder (like LoJack, satellite phones, and OnStar use). GPS will only recieve orbit data and time information from satellites (it then calculates its location based on those signals, and puts you on a nifty map)
I think some solenoid-assisted ratcheting system that would remotely clamp the brakes with pretty good pressure (enough to lock up the wheels and keep you from removing them, not enough to damage the rim) would be a good first stage setup. It would require no electricity to maintain the clamping force, so disconnecting power would do no good for that. They would need to use brute force to un-do the ratcheting mechanism. Remote unlocking is a bad idea, and I believe that you should need a key to unlock it.
Often times, you get to talking to someone outside and you think "I should lock it" before going in. You might be kind of far away. Remote locking is a good idea. But how often would you want to unlock it without riding it? Kind of pointless.
For additional security against "grab it and go!" theives (the variety that will steal a bike locked to itself through the wheels and frame) a cheap, ultrasonic transducer-based proximity delta sensor could send a once-per-second pulse to an inductor coil whenever it sensed something getting closer to it. This would add a painful (but not lethal) high-voltage, low current bite to the bike's frame, to make holding onto the bike a "shocking" experience. This would be able to be armed, disarmed, or "actively pulsing" regardless of sensor -- remotely and independently of the bike locking system.
I personally think that one of the 1/4 mile range car alarm transciever systems would be the most logical and cost effective option. The technology exists at an affordable price-point. Solenoids are cheap, lead-acid batteries are cheap, and pretty much everything I suggested is cheap. The "shock" wouldn't work on carbon-fiber framed bikes.
ax0n is offline
Old 11-28-06, 07:29 PM
JeffS
not a role model
JeffS's Avatar
And a radio and power windows and electronic tire pressure sensors...
JeffS is offline
Old 11-28-06, 07:35 PM
Frankenbiker
Yep, I just thought about the safety issue. It would be just my luck if the button on the remote control in my pocket got pressed while I was riding. Definitely a liability. It needs to be manually set some how. Hmmm. Think, think, think, think. Along the same lines of tightening down the brakes, what about a device that allows you to "set" the brakes so somebody doesn't ride off if there isn't something to chain it to. Perhaps a key-lock system on the front and/or back brake or brake lever that lets you pull-in the brakes and lock it so the wheels don't roll. It may not prevent the theft, but it will prevent opportunistic joy rides.
Edit: I want a remote controlled seat warmer for those cold winter commutes...
Old 11-28-06, 07:37 PM
noisebeam
Arizona Dessert
noisebeam's Avatar
Quoted: 5345 Post(s)
Liked 2,169 Times in 1,288 Posts
I waiting for remote start.
(There is a guy at the gym I change at every morning remote starts his truck when he gets out of the change area, but before he puts on his shoes. Then he drives 400yrds. to park it as close to the office building as possible, somtimes circling for the best spot. Our schedules are the same so its just about every day I walk past his running truck as I walk from the gym to the same office. I often beat him to the office door.)
Al
noisebeam is offline
Old 11-28-06, 08:00 PM
Air
Destroyer of Wheels
Air's Avatar
Yup!
Good idea - but the handlebars and seat are pretty nonconductive.
Someone my friend knew rigged his Expedition to shock the driver through the steering wheel if he didn't flip a switch beneath the dashboard. One day he was on a date and forgot about the switch. Woke up in the hospital without the skin on his palms. A few years later he killed someone and buried them near campus (Hofstra). Had a few screws not tightened enough...
Air is offline
Old 11-28-06, 11:44 PM
soccer.me
Bikes: Centurion Road Bike(old School), F800 Cannondale, New Belgium Fat Tire crusier
Breezer bikes have a quick lock system on them that you can lock and unlock quickly. It is a spring loaded bolt that is goes through the rear wheel. It is prety much so you can lock your wheel so somebody wont be able to roll off with your bike while you are not looking, dont think I would trust it much more than that though.
soccer.me is offline
Old 11-28-06, 11:59 PM
ax0n
ax0n's Avatar
Try picking up a bike on only the non-conductive parts.
A good zap would probably be enough to let them know you mean business. Why waste time on a bike that shocks you and won't roll when you could just go cut a few cable locks and have a truck bed full o' bikes for the same amount of effort? It's called the "Low-hanging fruit theory". Since evildoers are lazy blokes, they go for easy targets. So, unless you have a really high-end bike, it's probably going to keep most of them away.
ax0n is offline
Old 11-29-06, 07:36 AM
2manybikes
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
My security system automatically arms itself when I walk away.
It also has a proximity alert. And teeth.
2manybikes is offline
Old 11-29-06, 08:06 AM
ax0n
ax0n's Avatar
No offense, but I'd be more afraid of the LEDs. That's a nice looking dog to go with a nice looking trike, though.
ax0n is offline
Old 11-29-06, 08:32 AM
dobber
Perineal Pressurized
dobber's Avatar
Neat. Now instead of a bicycle that could possibly be recovered intact and undamaged, I've got one with damaged wheels, if not a damaged frame/components.
Add to that the medical costs you'll be liable for, plus any additional costs associated with the accident you've caused.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 11-29-06, 12:17 PM
saraflux
saraflux's Avatar
Yup!
wow. that's kind of random and creepy.
saraflux is offline
Old 11-29-06, 12:57 PM
Frankenbiker
However, if it were James Bond's bike, he wouldn't think twice about blowing it up, launching the rider into heavy traffic (or a tank full of sharks), wreaking havoc on the locals, then just walking away. After all, he rarely brings his transportation back in one piece.
Old 11-29-06, 01:04 PM
CliftonGK1
CliftonGK1's Avatar
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times in 6 Posts
Imagine, if you will, someone attempting to stop 141 Kg of speeding commuter armed with a U-lock and determined not to give up his bicycle. Short of clotheslining or shooting me, said miscreant has failed to think his cunning plan all the way through.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
CliftonGK1 is offline
Old 12-01-06, 01:23 AM
adamtki
Here's what I was thinking of ideally.
A remote lock that can lock/unlock the wheels and lock/unlock a cable (used to attach to something stationary) if used. Sometimes you don't need it locked to anything since you'll keep your bike in sight or you're not going to be away too long. You'll save a lot of time not having to fumble with keys or combinations and then wrapping it around stationary objects. And when you do need to lock it to something stationary, the remote can save you the hassle of keys and combinations as well.
And, of course, the wheel locking feature would only lock if the wheels aren't moving.
Well, I doubt anything like that is out there, but something that remotely locks and unlocks a cable would be an improvement.
adamtki is offline
Old 12-01-06, 01:29 AM
deputyjones
I found a remote control padlock on gizmodo:
That is getting closer anyway.
Old 12-01-06, 03:42 AM
adamtki
I like it! Tempted to get one. One step closer to ideal.
adamtki is offline
