I want out of this game- add a derailer?
I'm kidding. I'm keeping my fixed gear. But does anyone know if it's possible to add a derailer hanger to something like a bianchi san jose? Short of having a frame builder remove and replace the dropouts?
Bikes: Trek T80, Trek SU200, Trek SU100, Giant Bowery
you can put a derailer on your fixed gear, but if you want to have more than one cog on your bike (that is, to make the derailer USEFUL) you will have to swap out the fixed gear cog for a freewheel.
how would I add a derailer to a bike with track ends? with the exception of those very cheap derailers with the integrated hangers.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
Originally Posted by BostonFixed
I'd go with an internally geared hub.
Paste Taster
That seems like the way to go. Bostonfixed, I PM'ed you. Do you have a touring frame lying around? Oh, and retem, the san jose is steel. Welding aluminum and steel together is, from what I hear, not quite impossible, but requires a process called "explosive welding" and it's really expensive and very few people can do it.
Welding a derailleur hanger onto a steel frame is even easier then, but still, I'd go with an internally geared hub: you wouldn't f with your frame, the paint on the dropout(s) wouldn't be ruined, and the internal gear setup would still "look" like a single gear setup, at least at first passing glance.
I'm guessing a nexus 8 setup might run $150-200, built up into a wheel.
Paste Taster
yeah right they are 150 to 200 just for the hub
I would idealy go 8spd nexus in the rear with drum brakes
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Here you go.
https://sheldonbrown.com/harris/bianc...os8/index.html
Like everything else, Sheldon's got it waiting for ya.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Why don't you just get the Volpe instead of the San Jose?
brooklyn bike rider
Bikes: bmw park bike, tonic fab supernaut, chromag stylus, traitor ruben
there are a few chain tensioners out there that are also d-hangers.
i have the one revell makes; it's quite nice.
i know there are others out but i can't think of them..
spinspinspinspin
much easier than trying to get gears working correctly on a single speed bike.
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
oldsprinter
A red one of these would look great: https://www.rohloff.de/en/products/speedhub/index.html
Bikes: Yes please
I think this looks really clever, 2 in one chain tug and derailleur hanger. 'Cept you don't need the tug with a derailleur...
Just as much as you need it without one. That's why geared bikes use vertical dropouts these days.
Guest
Originally Posted by visitordesign
keirin racers pop bolt on derailleurs onto track frames sometimes. they exist. ask tomity, maybe.
I have one and the maker is Nemoto san of RAP keirin frames. I posted a pic before and will do another one.
It slide on the rear end and you just tighten it up. nothing happens to the frame.
S/F,
CEYA!
Cornucopia of Awesomeness
You can get good derailleurs that have integrated hangers
look for a shimano Saint or Hone. They bolt directly to the rear hub.
Basically what you would have to do is first find a wheel that spaced at what you need 120mm if its steel you can just bend it a little and go bigger.
then you get a bolt on derailer to a solid 1cm axle, intense does something like this, im not going to search for you to find exactly how to do it but its been done and actuatly the shop im working at (black sheep) is going to start having these bolt on derailer hangers made.
