Can I change this cottered BB for a square tapered one?
Hi All
I have a round cottered bb on an early Dawes I am restoring and I want to swap it out for a square tapered one to match some cranks etc. I have coming. Its a TDC No 9. 120mm. Can anyone tell me what to look for?
Bikes: old ones
Quoted: 26464 Post(s)
Liked 10,420 Times
...look online for a sealed unit, square taper bottom bracket unit that has the proper threading for your Dawes (I assume it's standard threading), and is the recommended spindle length for your chosen cranks. The spindle length varies from crank to crank. You'll need to pull the fixed cup as well as the adjustable one, which is not always an easy thing to do. Might be worth getting someone with the right tools to do that operation.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Whatever bb or bb spindle you use, it should match the crank. I'm sure you can find a spindle that will work with the existing cups, or you can get a whole sealed unit. A standard English thread unit should be fine, but we can't tell you what length you'll need; that will depend on the crank.
www.rhmsaddles.com.
www.rhmsaddles.com.
Vintage - Silstar Alloy Double Chainset 52 / 42 T , Cranks 170 mm, 80's Dawes
From a 1983 Dawes
Square Taper FIt
Chainwheels are 52 and 42 teeth
Crankarms 170 mm
How do I know which spindle is compatible with these cranks?
Old fart
Quoted: 3609 Post(s)
Liked 3,433 Times
Sounds like just buy a complete sealed unit is best. I have these cranks on order'
From a 1983 Dawes
Square Taper FIt
Crankarms 170 mm
From a 1983 Dawes
Square Taper FIt
Crankarms 170 mm
Likes For JohnDThompson:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2215 Post(s)
Liked 4,687 Times
Silstar was manufactured by Sakae Ringyo. Have a look here, and see if you recognize your set. If you're lucky, you'll find the right spindle length there.
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,300 Times
A bottom bracket from that era typically had a bit of offset toward the driveside, perhaps a couple of millimeters, versus a cartridge bottom bracket that more often will be symmetrical unless it's one of the OEM cartridge bottom brackets having the style of letter code such as "D-NL" or some such.
Note that a thin cup spacer can often be used to duplicate such an offset, but the thickness is somewhat limited when using today's Shimano UN-5X series of cartridge-style bottom brackets having a mini-flange on the left-side cup.
Note also that using a square spindle in the old cups may not only affect the offset, but also that the left-side cup may either protrude from the bb shell or may not leave enough threads showing. These issues are due to the differences in cup thickness that turn up between different brands and models. But by all means give it a go if you have a spindle at hand or can return one that you buy locally.
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
I would bet on 118mm as that's what was on my Austro. The spindle also may be stamped 3P, which corresponds roughly to the same. 122mm if you go to a modern symmetrical one.
Quoted: 1324 Post(s)
Liked 927 Times
If there is a bicycle co-op near you it might be worth your while to take the bike and the crankset there when you get the crankset. Then you can try different spindles.
Cheers
Cheers
Quoted: 796 Post(s)
Liked 522 Times
Your fortunate if you have standard threading the Raleigh's of the early 70's had proprietary threading which makes this swap difficult and the Peugeot's are well French and the easiest option for them is the somewhat spendy VO French threaded bb
Old fart
Liked 3,433 Times
1) retain the original 26tpi cups and find a square-taper spindle with the appropriate length and offset for the chosen crank.
2) Use a threadless cartridge bottom bracket from Velo-Orange, YST, etc.
3) Use a Phil Wood cartridge ($$$) with Phil's 1-3/8" x 26tpi mounting rings.
Old Bike Craphound
My Dawes Realmrider (late 70's, early 80's) had a British standard threaded bottom bracket, unlike Ralieghs I have cursed.
I agree with the suggestion of sizing the spindle at a bike co-op, if that is possible for you.
-Will
-Will
