Any of you have experience using frame saver or other products?
Old 06-07-16, 10:51 PM
djb
Quoted: 1556 Post(s)
Liked 224 Times in 194 Posts
Hi, I'm usually in touring and occasionally in the mechanics section. I've bought a used steel bike that has not been ridden much, but has some little rust issues.
It's a 3 or 4 year old Surly Troll, and I plan to take the hollowtech bb off, partly to learn how to work on them, but also to make sure everything is well greased. I'm going to open up the hubs as well, so that I'm sure of the condition of all the bits and not have any guessing on grease quantity or contamination.
I figure I can pull the fork off and do a frame saver job while it's apart.
It seems that the spray cans of Frame Saver" are not easily found around here, so do you have personal experience using linseed oil, or other products?
No matter what I use, I realise I'll need to be careful of the bb threads and not let them get gummed up.
So from experience, are the canned products worth getting, or are things like Boeshield or linseed going to do a reasonable job?
The bike was kept in a damp barn like structure, there is just a bit of internal surface rust in the tubes, so I figure it's worth taking the time to do this now when I take things apart, and then never think of it again.
Any suggestions, comments or preferences would be good to read.
Thanks
djb is offline
Old 06-07-16, 11:00 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2082 Post(s)
Liked 455 Times in 334 Posts
I haven't used the products you mentioned other than having received custom frames that were all FrameSaved buy the builders. I have used AMSoil Heavy Duty Metal Protection at ~$8/can good for at least three frames. I have seen no changes in any of the frames I have treated with the stuff. but I haven't spent a lot of time looking.
I'd use the stuff again. $8 for 3 frames? That's worth 10 minutes of AMS saleman time.
Ben
79pmooney is offline
Old 06-08-16, 03:02 AM
cb400bill
Model Moderator
cb400bill's Avatar
Bikes: Fuji SL 2.1, Schwinn Voyageur, Cannondale Synapse, Raleigh C50, Trek 710, Raleigh Granada, Legnano Pista, Viscount Aerospace Pro
Quoted: 1788 Post(s)
Liked 898 Times in 592 Posts
Thread moved from Classic & Vintage Appraisals to Bicycle Mechanics with 3 day forwarding.
cb400bill is offline
Old 06-08-16, 04:02 AM
dsaul
Quoted: 400 Post(s)
Liked 164 Times in 125 Posts
+1 for the Amsoil Heavy Duty Metal Protector. I build frames and have used Framesaver and the Amsoil stuff. They are the same product in a different packages. The Amsoil stuff can be ordered direct from their website.
Its a messy job, so lay down plenty of old newspapers and do it outside or in the garage. Allow at least a day for the stuff to set up and stop dripping out the holes in the frame.
dsaul is offline
Old 06-08-16, 06:07 AM
djb
Thanks for that recommendation, I'll look into it. Sometimes here in Canada there are products that are not available that you have in the states, so I'll start looking and asking around for that product.
As I've never done this before, are there any precautions you have to take with the fork and steerer headset races or whatever you call them?
Any concerns with paint?
Any tips or "don't do's" that stand out in your memory?
Thanks again
djb is offline
Old 06-08-16, 06:53 AM
Standalone
The Drive Side is Within
Standalone's Avatar
Bikes: Road, Cargo, Tandem, Etc.
Quoted: 87 Post(s)
Liked 5 Times in 3 Posts
Can't hurt. I put Framesaver in any steel frame that I have apart or mostly apart.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Standalone is offline
Old 06-08-16, 06:57 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1360 Post(s)
Liked 180 Times in 147 Posts
Another vote for Amsoil HDMP. I have also used Weigel's Frame Saver and the two products are identical. They look alike, smell alike and work alike. The benefit of HDMP is you get a larger can for less money and it's available at many auto parts stores. NAPA stores in the US carry it but check auto parts stores in Canada.
HillRider is offline
Old 06-08-16, 07:09 AM
dubes
In my experience, Framesaver (and I assume HDMP since others say it's the same stuff) does not hurt paint. After spraying, it's easiest to wipe off the excess while still liquid. If you find some dried on later, I use some WD-40 on a rag to wipe it off.
Mike
dubes is offline
Old 06-08-16, 08:05 AM
djb
Thanks for the Amsoil stuff auto supply store recommendation and for the wipe while liquid tip.
I am replacing someone who is ill so will not have time probably for a while to actually physically do the project, but will do some calling for the product.
With a can of liquid, do you use a big sringe or something, or just pour it out of a smaller container into the frame openings?
Common sense seems that turning the frame around and around so it coats all over inside would be best?
After doing all the areas, would it be better to let the frame stand upside down in a work stand, bb area highest, to minimise stuff collecting in the shell threads?
djb is offline
Old 06-08-16, 08:41 AM
GravelMN
GravelMN's Avatar
Quoted: 73 Post(s)
I use LPS-3 Rust Inhibitor. Not saying it's the best available, but it has worked well for me. I picked up 18" of small diameter tubing from a hobby shop that just slips over the red straw that comes with the product. It still creates a good fog and allows me to snake it into various areas of the frame for good coverage. I've never had a bit of rust inside my steel frames even though they get ridden under wet conditions and one is my winter bike on salty MN roads. The bikes do get good care and are stored in a garage.
GravelMN is offline
Old 06-08-16, 08:48 AM
corrado33
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1126 Post(s)
I've personally used frame saver. Worked well. It's thicker than you think.
A friend used boiled linseed oil. Her bike was sticky for a few days afterward, but it's fine now. Linseed oil works great at preventing rust, I'm sure it'll do a fine job.
corrado33 is offline
Old 06-08-16, 08:56 AM
SkyDog75
Bikes: Bianchi San Mateo and a few others
Quoted: 633 Post(s)
Liked 4 Times in 4 Posts
Amsoil HDMP and Weigle's Frame Saver come in aerosol cans. Spray it into the frame, then turn/twist/rotate the frame to move the liquid around inside and get coverage. The cans come with a small red straw, which you can use to spray into small openings like the top tube openings to the seat tube and head tube, or even really small ones like the brazing vents on seat stays.
It's kind of hard to screw it up, no matter how you let the frame sit. I re-oriented the frame every once in a while to let the stuff trickle elsewhere and to try to prevent big deposits of it in places like the top tube or the bottom of the seat stays below the brazing vents. At the end of the day, I left the frame in a work stand right side up, letting the excess run out of the downtube and chain stays into the bottom bracket shell. I wiped some excess from the threads and let the remainder drip out of the bottom bracket cable guide screw hole or drain hole, whichever the particular bike has. So long as you don't let the frame sit unattended for a whole day or more, it's easy enough to wipe up excess with a paper towel. The stuff takes quite a while to completely dry.
SkyDog75 is offline
Old 06-08-16, 09:02 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7009 Post(s)
Liked 395 Times in 303 Posts
Shop I got my Pinarello CX frame from did that before They handed it over to Me, in 1990.
fietsbob is offline
Old 06-08-16, 09:27 AM
3alarmer
3alarmer's Avatar
Bikes: old ones
Quoted: 17504 Post(s)
Liked 1,316 Times in 978 Posts
...available in the paint department of any Home Depot (its one great advantage over other products). Comes with a little red tube to spray into stay holes and other recesses. Recommended to me by a local framebuilder here. Let it dry a day or two before you reassemble the bike.
3alarmer is online now
Old 06-08-16, 10:18 AM
djb
thanks a lot everyone for all the comments and further suggestions.
djb is offline
Old 06-08-16, 09:14 PM
Ronsonic
Quoted: 86 Post(s)
Liked 20 Times in 16 Posts
I use Boeshield. Have no reason to believe it won't work well. I'm thinking the marine and aeronautics industries are mature enough to produce a quality product for the job.
Ronsonic is offline
Old 06-09-16, 06:48 AM
Kopsis
Kopsis's Avatar
Quoted: 83 Post(s)
You can find Maxima Chain Wax at most motorcycle shops and it's very similar stuff to Pro Gold Frame Protector.
Kopsis is offline
Old 06-09-16, 11:50 AM
HillRider
Amsoil HDMP is also recommended as a motorcycle chain lube as well as a rust preventative coating so it may be the same or very similar product.
Old 06-09-16, 12:49 PM
djb
An initial call to an automotive supply place I know unfortunately came up with nothing. They had heard of it, but have never stocked it.
I also unfortunately saw on the Amsoil site an ominous "**Not Available in Canada" sentence....
Will keep on trying as I'd prefer to use something that has been used with experience by some of you.
djb is offline
Old 06-09-16, 01:54 PM
Metaluna
Bikes: Niner RLT 9 RDO, Gunnar Sport, Soma Saga, Workswell WCBR-146
Quoted: 114 Post(s)
Liked 18 Times in 18 Posts
That's what I use as well. Seems to be about the same stuff as Frame Saver, HDMP, and all the rest (just make sure you get LPS-3. LPS-1 and LPS-2 are different). A lot of aviation supply houses sell it, as apparently it's popular for small plane fuselages, so how bad could it be. I got my last can on Amazon for around $12, I think, though if the Rust-oleum product mentioned earlier is the same stuff maybe I'll try that next.
The hobby shop tubing sounds like a great idea. I've always thought it would be great if someone made something like that, but with a nozzle at the end that produced a very wide (or even annular) spray pattern. Then you could just snake it down a tube, press the button, and draw it out slowly. Done.
FYI, here's an old roundup review of a few different products, targeted to boating applications. LPS-3, CRC Heavy Duty, and a couple of others finished at the top.
Test of Corrosion Inhibitor Sprays - The Hull Truth - Boating and Fishing Forum
Metaluna is offline
Old 06-09-16, 03:41 PM
djb
Thanks for that, if the other one is bust, at least I have some options, and I like the idea of some added tubing to feed down the larger openings.
djb is offline
Old 06-09-16, 04:24 PM
SkyDog75
Quoted: 633 Post(s)
Odd. The Amsoil web site actually lists a number of retail stores in the Montreal area. I used the "Find Amsoil near you" button on the top of the page and entered 12919, the ZIP (postal) code for Champlain, NY since it's nearby.
<EDIT> Ahhh... I found the "not available in Canada" disclaimer and it's specifically for HDMP. Well, if you can't find alternatives, the U.S. border's only a few miles, er kilometers, south. ;-)
SkyDog75 is offline
Old 06-09-16, 05:00 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2766 Post(s)
Liked 674 Times in 470 Posts
Experience using Frame Saver on a frame or two, sure. Evidence that it has prevented or slowed internal rust in the couple of years since? Ehhh, I'll get back to you.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 06-09-16, 06:51 PM
djb
Re popping over the border, may do that if it works out going to do some biking in Vermont or something , and if I could get it, we'll see.
Thanks though for looking.
In the end, whatever I use I figure will be good for the frame because of the light rusting it has here and there, and like I said, I'm taking the bb etc off anyway at some point to give it a good once over of all grease points.
djb is offline
Old 06-09-16, 09:14 PM
Ronsonic
Quoted: 86 Post(s)
Do add a drain hole in the BB shell if there isn't one already there. That can make a big difference especially for bearing life.
Ronsonic is offline
