Source of steel pins for chainrings
Brit Rider
Bikes: Mercian King of Mercia (1983), Balance XR-550 (1993), Surly Cross Check, 1948 Condor British steel lightweight.
Quoted: 33 Post(s)
Hi All
Does anyone know a supplier / source of steel pins used on chainrings to help with shifting?
Many thanks
Arb
Many thanks
Arb
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
I have never seen them for sale separately. They are installed as part of the manufacture of the chainring.
Although they are likely some off-the-shelf fastener or part that can be purchased, but I don't know what you would call it outside of a bicycle drivetrain.
Brit Rider
Quoted: 33 Post(s)
I am sure there are off the shelf pin options - just need to find a source.
Quoted: 18376 Post(s)
Liked 4,512 Times
My guess is those pins are extremely proprietary. Is that a Campagnolo crank in your photo?
Drop stop pins for between the large ring and crank may be available, as for some reason they often were designed to be installed by the end user. However, I'm doubting those shift pins are widely available. If they are a wear item, the chainrings usually have significant wear before the pins would fail.
You could try contacting a small domestic chainring manufacturer such as Vuelta and ask if you can buy some.
https://www.vueltausa.com/components/chainrings.html
Or, perhaps try to track down a Chinese chainring manufacturer.
If I was making my own, I'd start with something extremely hard such as a tool steel, or high speed steel. Perhaps a drill bit shank. After machining, they may need hardened. Perhaps even tungsten carbide.
Likes For dsbrantjr:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Even if you could get them, to install them you'd have to have some pretty sophisticated milling and drilling and press and measurement equipment. I don't think adding the pins is practical, compared to just buying the pre-made chainring set.
But perhaps the OP owns a machine shop....
Likes For WizardOfBoz:
Likes For jadocs:
Bikes: 70's frame, newer parts
Quoted: 92 Post(s)
Liked 38 Times
Are they "pressed" in? Then you'd need a press and a fixture (jig) to install them.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Lots of sources: pin manufacturers, rivet vendors, round head screws threaded in and peened...doesn't make it easy to do it right.
Brit Rider
Quoted: 33 Post(s)
Thanks for all the input on this. We have access to all of the processes and tooling necessary to manufacture we just want to determine if it is possible to purchase these from a supplier rather than make our own.
Thanks
Thanks
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 341 Times
Again, if you look at the picture you see that the pin in the larger chainring is meant to catch the chain. The chainring has a groove that will allow the chain to extend directly from the small chainring to the pin on the larger one. The groove in the pic is tapered, that is, its deeper the closer it gets to the small chainring. Clearances and geometry are chainring (large and small) specific. I believe that, because the chains are normally high-strength steel (that is heat-treated and hard). the pins must be too. To engineer pins for a new chainring pair, I'd suspect you'd have to get very accurate pins (more like disks) and carefully consider geometry, testing a few positions. I'd probably heat-shrink the pins in (pins in dry ice/propanol, chainrings on a bearing heater) and might even add geometric retention (kind of a dovetail end on the pin, larger at the end, with the chainring holds bored with a taper, larger diameter deeper in the hole).
To ensure that the things don't pop out, I suspect that you'd precision grind them as well, to ensure a tight fit.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
I would think a flat head screw, maybe M3 or M4 thread, threaded into a hole tapped and then partially countersunk in the chainring , would make a reasonable facsimile of a chainring pin. Selecting the most advantageous location, and modifying adjacent teeth, will be a bigger challenge.
Liked 4,512 Times
If you are planning on doing a one-off, then you can probably find a hack that will work. However, if you are planning on manufacturing for resale, then I'd encourage you to purchase a half a dozen different brands of rings (pairs of rings). Test, then disassemble to see how they work.
I am a little curious about pressed vs threaded. Also note, Aluminum has a bit higher thermal expansion than either steel or tungsten, which you might be able to use to your advantage.
SE Wis
Quoted: 2747 Post(s)
Liked 3,396 Times
https://patents.google.com/patent/US8506436
Many appear to be SS. likely 400 series.
https://www.chainreactioncycles.com/...g/rp-prod35784
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 708 Times
I then Dremeled off most of the excess screw and peened the end so there was no chance of it backing out.
It worked until I wore the chainring out.
Jeff Wills
Jeff Wills
Brit Rider
Quoted: 33 Post(s)
Thanks Jeff and All
So it seems like these are not something we can purchase off the shelf which is in itself good to know. The screw option is obviously an option albeit this is a very manual process and ok for one-offs but not really viable at a larger scale when you would want to be using a press to insert correct sized pins to ensure consistency.
Thanks
Thanks
I've done this, using stainless M4x0.7mm hex socket flat head screw for pickup pins. I drilled the chainring on its webbing where it had the most material, tapped the hole, countersunk it slightly, then inserted the screw. This left the head of the screw slightly proud of the chainring's surface.
