Does anyone have this Campi nut?
I was missing the same one from my Superbe brakes. I found one at a local hardware store with a good screw stock department. It was a plain stainless acorn nut, not the same as the original but it's doing the job. Since I am not bothered about that nut on that particular bike, I'm happy.
A stainlesssteel 6x1mm acorn nut will do. and look OK.
genuine means cannibalization. robbing peter to pay tullio..
Quoted: 3464 Post(s)
Liked 2,829 Times
I had this problem once, I ended up buying two chromed metric acorn nuts, that way both looked the same. The leftover went onto another bike that arrived w/o that fastener.
Those parts do show up on ebay from time to time. but finding an auction for a single caliper w/o brake block holders may be cheaper.
Bikes: Colnago C40 HP, De Rosa-Primato, Titus Ti FCR, MOOTS YBB-SL, Pogliaghi Pista
Ill be watching this thread since I'm in need of one for my Pogliaghi. The rear nut was missing from my C-Record gruppo when I acquired it.
Quoted: 556 Post(s)
Liked 132 Times
Callig. Just a thought but, if you can't find one, I could try to replicate one on my metal lathe. But, since I don't have any stainless bar stock large enough, I would need to start with a metric acorn nut and shape it down to a cone. May work, may not.
Quoted: 556 Post(s)
Liked 132 Times
Nuthin'. But you'd probably have to supply the metric acorn nut as I can't think of a place around here that might have one. Maybe West Marine, but it's doubtful.
I'll take a look at my local ACE. They have a fairly good selection of metric stuff, but not sure I've ever seen metric acorn nuts there.
I may also need to take a close look at your remaining nut. Would be great to have it in hand so I could match the profile but that may be more than you're willing to do. My only reservation is how deep the threaded bore is cut in a standard acorn nut. They're generally cut nearly full depth and so, if I cut that taper to match the original, I'm sort of concerned about running into the bore.
I got one from our local Ace Hardware (in SS no less), but they seem to vary in what they carry from store to store. Surprisingly, Home Depot also has them, but their stock was a mess (drawers) and they did not have the right size in stock.
Quoted: 5 Post(s)
Liked 37 Times
In the first picture on the right are 2 campi nuts the farthest right the super record nut next the NR nut next an acorn nut I found in a box of assorted Bicycle nuts I've collected and next the nut I used when I discovered I was missing the SR nut also found in the box. Second picture its reversed. hope this helps
