Inexpensive slicks for a tandem MTB?
Quoted: 637 Post(s)
Liked 1,285 Times
I just took an old K-Swiss Northwoods Safari tandem MTB in trade on a bike I sold, it's appears to be a fairly low end bike but in like new condition. I was intending to flip it ASAP but my wife likes it and I have had it in the back of my mind we might like a tandem so it's staying, at least for awhile. I'm going to do some upgrades from my "excess inventory" on the saddles, drivetrain and brakes, especially the brakes! Since we're just going to use it to cruise around town occasionally and see if we like tandem riding I want to swap out the knobbies for something more pavement friendly. Would a decent quality 26 inch street tire be OK for this type of riding? I don't want to spend a lot on it at this point because we don't know how serious we'll get about tandem riding and if we do get into it we will most certainly upgrade to a better quality bike as I'm fairly confident the Northwoods isn't up to much more than putzing around town. TIA.
Schwalbe Kojak Slick MTB Tyre 26x 1.35 or 2.0 $25
SCHWALBE STELVIO 26 X 1.10 $15 I have these on my Tandem Alls the Schwable tires are very durable exceptional puncture resistance.
Or look at the Schwalbe City Jet MTB Tyre
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Nashbar slicks on sale for $12 right now. Nashbar Slick City Tire
Quoted: 48 Post(s)
Liked 10 Times
Quoted: 637 Post(s)
Liked 1,285 Times
I had some of those Nashbar/ Performance Bike tires they worked and were cheap I paid under $10 on sale when I got them but not as durable as I'd like, I can say the Schwables have some of the best puncture resistance around on all their tires. They are know for their MB tires in Europe.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
I have NASHBAR tires on other bikes and have been very happy with them but I think we'll need something a little wider. These are only 26 X 1.25, it has 26 X 2.0 on it now and I'd like to stay close to that, it's a HEAVY bike even without riders. I don't expect to get a lot of miles out of the tires on this, I just want to make sure the tires are safe for the weight. It doesn't appear to have tandem specific wheels on it so we'll need to be careful with bumps and potholes too.
$20.36 each shipped.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
The Nashbar tire for example is rated for a max 85lbs psi. That might lead to pinch flats for a big team, and a heavy bike.
Also the wheels are probably more sturdy than you'd think. 26 inch wheels are stronger and stiffer than comparable 700c wheels with the same number of spokes.
You could get lost and die.
You could hit a tree and die.
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
The bigger the load the more I would look 26 x 1.50 wide tires. I don't know what the pressure rating is and wider tires generally have lower pressure ratings but also can safely run on lower pressures without pinch flats. The problem is that handling gets pretty bad at really low pressures. All told our load is only 300lbs or so but we run expensive tires about 1.50 wide (38mm) and we have used 50 lbs psi on occasion. Actually we could probably not pinch flat at 30 psi but the handling would be unacceptable.
Quoted: 637 Post(s)
Liked 1,285 Times
Thanks everyone, my wife and I combined probably weigh about 375 and I'm guessing the bike to weigh around 50 Lbs. I have a nice pair of 26 X 1.75 city tires I took off one of my MTB's when I put studs on it for this Winter, I'll go ahead and use them.
Schwalbe Stelvio 26 Inch High Pressure Tires 26x1.1 Folding Bead (28-559, 115 Max. PSI, 250 grams)
I've got Bontrager Hardcase 26x1.5 on my tandem and the do fine, but may be a little pricey.
Quoted: 509 Post(s)
Liked 9 Times
Good call. Having switched from 26 X 1.25 (100 psi) to 26 X 1.75 (45-50 psi) this year, I heartily endorse going fatter with lower pressure. It's dramatically improved the handling for the captain, the comfort for the stoker (me) and reduced the rolling resistance. Okay, we bought nice tires that were expensive, but they last so long they are cheap per mile you may not get the same decrease in rolling resistance with cheapies.
Quoted: 38 Post(s)
Liked 9 Times
I like Kenda's 26 x 1.5 100 psi Kwest tires 40-559. Amazon.com : Kenda Kwest Commuter/Recumbent Bicycle Tire : Bike Tires : Sports & Outdoors
Quoted: 637 Post(s)
Liked 1,285 Times
