Carbon fiber wheels question
Bikes: 2013 Cervelo R3 Ultegra, 2011 Trek 2.1, 80's Guerciotti
Hi all,
Going to pick up a set of carbon fiber wheels soon. I currently hang my bike upside down by the wheels from the garage roof rafters. Can I hang my bike upside down by the carbon fiber wheels?
Thanks for any responses
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,307 Times
Yes.
....they won't explode.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Depends on the depth of the wheel..... my standard hooks don't fit 50mm rims.
I've also seen some of the latest rims from bontrager are so light weight that they bend with a finger press... hanging would break them, even if it was a 14lb bike.
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
170lb rider, 14lbs of bike, 25 mph into a small rock or pot hole is going to generate forces several orders of magnitude higher than hanging the bike from a hook.
You could get lost and die.
You could hit a tree and die.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
There are carbon wheels with carbon/plastic fairings. Usually these have aluminum rims (and braking surfaces). The fairing is not structural. It's like trying to jack a car up by using the lip of a fender. The fender is just a fairing for the chassis - you can't support a regular car by just the fender. I wouldn't hang a bike off of such a wheel. An example is the HED Jet, I'm sure there are others. My Jets have such a thin fairing that it's only slightly stiffer than a playing card.
Some more explanation here on the difference:
https://sprinterdellacasa.blogspot.co...r-fairing.html
With a structural fairing (a good sign is that the spoke nipples are visible/accessible) the carbon part really is supporting your weight. Hanging a bike by a wheel like that will be fine.
https://bontrager.com/model/09869
I eat carbide.
Liked 1,307 Times
from the outside... yes, you're right. However, these will suffer if you hang them upside down.
Bikes: 2012 BMC SLR01, 2012 Yeti ASR5, 2013 Trek Crockett
I have 2 sets of reynolds carbon clinchers. My old bike is hanging up in the garage from a hook on the rear wheel.
The normal size hook usually sold to hang bicycles may not be big enough for some deeper wheels. I was able to find some larger hooks that work fine with my 46mm deep carbon wheels. Eventually the foam on the hook cracked where it makes contact with the wheel. To prevent the metal from scratching up my carbon rims I put a piece of foam around the hook and secured it with some large heat shrink tubing.
Falls Downalot
Bikes: Now I Got Two
Quoted: 5 Post(s)
Extra Medium Member
Considering that MOST pro teams hang the majority of their bikes by hooks in the team trailer while the bikes are in transit....You'll probably be ok....plus what Psimet said...plus what gc3 said....plus what everybody else who said go for it...said.
Droping the hamer since '86
Novitiate
Bikes: TIme RX Instinct Frame and Cannondale Synapse, HiMod1
Are Carbon Wheels Faster?
A different question about carbon fiber wheels: I have always thought "all other things being equal" that lighter wheels are faster, but it appears that most of the posts I have read discuss the aero effects of carbon wheels. Of course, better aero also means faster. First I am 76 years old and have only been riding about 5 years. Recently, I heard that Conti GP4000S wheels are faster. I am pretty much of a doubter when someone says if you do this or that or whatever you will gain X mph speed. Nevertheless, I decided to change my Gatorskins to the 4000S wheels. I mounted them last week and I noticed immediately they felt better on the ride, but more importantly I increased my speed from 14.8-15.2 to 15.8-16.2 I ride the same ride with varying distances 4 days a week so I have history to backup my higher speed (please, when you see these pokey speeds, don't forget I am 76 years old and only been riding 5 years. I started too late to expect speeds of 18+ mph - done a few 17+ tho). I am absolutely certain that my speed has increased at least .5mph and maybe as much as 1.0mph. I don't know how it would affect a rider who is going 18-20 mph, but it definitely increased my average speed. Now for the question: I have ridden 4 years and 13,136 miles on Rol Race SL wheels which weigh 1555 grams. Would changing to lighter wheels, e.g., 1310 grams carbon wheels increase my speed?...Again all other things being equal.
Quoted: 6556 Post(s)
Liked 58 Times
Why bother to type the whole question? OP you could have just given the question number for this topic. I think it is 63. You just say, "Asking #63 again." And then everyone tells you it is okay.
Liked 58 Times
Liked 58 Times
It is not the weight that matters as much as the pressure. If your hook were a knife edge, 14lb would be much more damaging as the psi at the contact point would be very high. Of course, with a normal hook you are absolutely correct.
Novitiate
I would like to apologize to rpenmanparker and everyone else...I had no idea I was hijacking a thread. I looked for quite awhile trying to find something akin to my question and found something close to it, but somehow got onto the wrong one. I sincerely am sorry. I also, with tongue planted firmly in cheek, apologize for calling a tire a wheel...I know the difference and I have to say I first laughed at my mistake and then thought, really...sarcasm doesn't help so much either...
Bikes: Colnago, Cervelo, Scott
Quoted: 191 Post(s)
Yes, it may make you faster, and if you do decide to buy them, you should buy them at BikeFix which is a shop very near you for the best customer service in the area on Cin-Day road.
Liked 58 Times
Novitiate
I just tried to send you a private message; however, I couldn't because you have to have at least 50 posts before you are allowed to do that. The message is too long and no need to be burdensome to others to attach it to this post. In my private message, which I would love to send to you, I explain further what happened and I respect your knowledge and actually have a couple of questions that you might be able to answer in it. If you would like to exchange an email with me, please, write me at steve@varnum.com so I can send it to you. Cheer and thanks.
John Wayne Toilet Paper
Bikes: BH carbon, Ritchey steel, Kona aluminum
Steve, you may want to remove your email address from that post - web-spidering programs will pick that up and add it to spam-emailing databases, essentially sending you huge amounts of junk email.
You can obfuscate an email address like so: "joe dot briggs at varnum dot com" if you REALLY need to post your email publicly.
