Go Back  Bike Forums > Bike Forums > Triathlon
BMC TT02 frame. Now, what do I put on it?
Triathlon Swim / Bike / Run your thing? Drop in our new triathlon forum for the latest in training & gear. From beginner to expert, and sprint to ironman.
Old 11-06-11, 11:01 AM
dr_max
dr_max's Avatar
Bikes: BMC SLC01 Promachine with full DA grupo on Ksyrium ES/ BMC Roadmachine 01 One disc Ultegra with DT Swiss
Quoted: 154 Post(s)
Liked 59 Times in 37 Posts
I am currently in my winter season mood, i.e. looking at all the endless possible parts to build the perfect weigth/price ratio TT bike. Just bought this frame: https://www.ebay.com/itm/160662614153...84.m1497.l2649 and now I'm hesitating between a Sram red build vs FSA vision cransket build. Enjoy my anticipated build and feel free to post any comments or suggestion that could help me or destroy my opponnents.
Groupset: https://www.ebay.com/itm/New-Sram-Red...ht_1639wt_1396
Tri bars: https://www.ribblecycles.co.uk/sp/roa...rs/ITALHBAT110 vs https://www.trisports.com/profile-des...d-aerobar.html
Saddle: ISM Adamo racing 2 white https://www.ebay.com/itm/320788228696...84.m1423.l2649
Crankset: https://www.probikekit.com/ca/compone...-chainset.html vs https://www.ebay.com/itm/New-SRAM-Red...ht_2241wt_1163
Zipp wheelset: https://www.ebay.com/itm/2012-Zipp-80...item3a6ba9f9a4
Water bottle cages: https://www.xlab-usa.com/products/cag...s/aero-tt.html
Just received the frame, in the next week I'll be buying everything to build up that frame and adjust/index it perfectly in my garage getting it perfectly ready for the next season.
dr_max is offline
Old 11-08-11, 03:35 AM
900aero
Bikes: Pinarello FPQuattro, Giant XTC 29er
All I can say is: you lucky ba$tard. There appear to be no wrong choices there, its all nice stuff.
FWIW - I like SRAM.
900aero is offline
Old 11-08-11, 04:08 AM
Dalai
Quoted: 89 Post(s)
Liked 8 Times in 6 Posts
Personally if you are going to spend that much on a crankset, I'd look at putting the funds towards a Power2Max or used wired SRM...
Dalai is offline
Old 11-08-11, 07:23 AM
Oysterboy
All work and no play...
Oysterboy's Avatar
FWIW I like the SRAM red and kinda wish I hadn't made the Shimano decision so hastily during my build. The extra money you put towards the crank is better put towards wheels, IMHO.
Looks like you got a cool winter project ahead of you. Have fun
Oysterboy is offline
Old 11-08-11, 10:25 AM
hyperlitenerd
hyperlitenerd's Avatar
I don't find PF aero bars comfortable. Just picked up some vision ones, feel soo much better!
hyperlitenerd is offline
Old 11-08-11, 12:23 PM
tessartype
tessartype's Avatar
Bikes: 2009 Felt B2 Pro, 2009 Trek 1.2, '80s Hercules beater
Volna aerobars come with ski-bend extensions, just like my (discontinued?) Lightning Stryke.
Which is a fine shape - for clip-ons. If I had to put my shifters in the extensions, I'd get flat or S-Bend extensions. Profile's Ski-Bend ones are supremely comfortable, but I wouldn't think so if I had to shift from them.
tessartype is offline
Old 11-08-11, 05:39 PM
Dalai
Quoted: 89 Post(s)
Interesting. I went from Vision Tech Integrated bars with Ski ends to 3T Mistral bars with S bends (had to change bars to be UCI compliant - I'm also racing road ITT's on the bike). Never found the S - Bends comfortable even on shorter races. Also I have found with the forearms being lower meant my shoulders are up a little higher so less aero.
I have now bought ski extensions and will be swapping back out to these. If the ends are at the right height, there is no issues changing gears with ski extensions.
Dalai is offline
Old 11-10-11, 02:00 AM
jordo_99
Bikes: KHS John Howard (6500 Ultegra) - Quattro Assi XXX (6510 Ultegra/Neuvation wheels) - Gary Fisher Tasajara (Deore/LX)
If it were me, I would just get whatever is cheaper between a red or dura ace groupo.
Is there really any difference between bar-end red and dura ace (non-electric). There is obviously going to be a difference between the STI versions...but bar ends should function nearly identically right?
jordo_99 is offline
Old 11-10-11, 11:15 AM
hyperlitenerd
you would think they should be the same, but sram and shimano have different pull ratios, so make sure to match up your derailleurs to your shifters.
Old 11-11-11, 01:59 PM
Gege-Bubu
Gege-Bubu's Avatar
Quoted: 23 Post(s)
What crank size are you going for? 50/34 or 53/39?
Gege-Bubu is offline
Old 11-12-11, 02:34 AM
tessartype
tessartype's Avatar
SRAM shifters (and Zipp's and the newly-released Campagnolo TT-shifters) return to the center ("R2C") after every shift - Dura-Ace doesn't.
Why go 34/50 on a TT bike? Even a moderately fit cyclist will outspin a compact on a flat course with some backwind, and you'll lose masses of time on those who can still put the power down. If the course is hilly enough (remember, it's a TT), you can take a cassette with a 29t cog.
Old 11-12-11, 08:46 AM
dr_max
dr_max's Avatar
Quoted: 154 Post(s)
Actually I'm hesitating between 54/39 and 53/39. I would never go compact.
dr_max is offline
Old 11-12-11, 06:44 PM
Triguy
Things like cranksets and groupsets make little difference in your actual time. If you like Red, go Red all around.
The Firecrest 808 are probably the best time trial front wheel out right now.
I'd buy your aerbar based on your fit needs. It's always better to use aerobar spacers as opposed to stem spacers. If you need a "low" bar, this is pretty sweet:
https://www.backcountry.com/pro-missi...bon-tt-aerobar
If you need a "high" bar, then I like the BRezza:
https://www.treefortbikes.com/product...0cm-Black.html
Triguy is offline
Old 11-12-11, 07:01 PM
CCrew
Older than dirt
CCrew's Avatar
Bikes: Too darn many.. latest count is 11
Force front Derailleur versus RED. 1090S chain and cassette is junk - chain clatter and noisy., run Ultegra chain and rear cassette.
Planet X brakes are stronger and lighter. https://www.planet-x-usa.com/pCNC%20U...ht-Brakes.aspx
I'm running the Profile Design Cobra Wing front bar in carbon with these for aerobars: https://www.profile-design.com/profil...lus-cobra.html
This on a BMC TT03 frame
CCrew is offline
Old 11-12-11, 07:11 PM
CCrew
Older than dirt
CCrew's Avatar
Only the RTC SRAM's do ( https://www.sram.com/sram/road/produc...-aero-shifters ) The TT900's and the TT500's are just like DA in that they don't return to center.
CCrew is offline
Old 11-18-11, 09:37 PM
dr_max
dr_max's Avatar
Quoted: 154 Post(s)
Couldn't hold myself, I bought this auction too: https://www.ebay.com/itm/330639886968...84.m1497.l2649
dr_max is offline
divemedia
Singlespeed & Fixed Gear
75
07-15-15 08:16 PM
stuntmatt
16
11-18-11 07:18 PM
dr_max
Road Cycling
2
11-06-11 12:48 PM
Snapperhead
3
10-27-10 04:35 AM
thegunner
Road Cycling
32
03-14-10 03:34 PM
