Diverge tire clearance issue
Old 05-15-18, 01:14 PM
Nubie
Nubie's Avatar
Bikes: 2021 Specialized Diverge Carbon Comp, 2020 Specialized Roubaix Expert, 2020 Specialized Creo Expert
Quoted: 13 Post(s)
Liked 3 Times in 3 Posts
Excellent point. I have them on the stock Axis rims that came with the bike, figuring I wouldn't cry too many tears if they got bashed up. Not sure what the ID is on those, and I don't own calipers to measure the tire width.
Nubie is offline
Old 05-24-18, 09:29 AM
Jamg2412
Alberto
Jamg2412's Avatar
Bikes: Bianchi Liquigas Via Nirone
Quoted: 17 Post(s)
Liked 4 Times in 3 Posts
Panaracer Gravel King SK 38mm
I just put the gravel king sk 38mm in my Specialized Diverge E5. I feel comfortable with the Tyre clearance. Around 7 mm in respect to the seat post and 5 mm at the bottom. I can’t post photos.
Jamg2412 is offline
Old 05-24-18, 09:31 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
09
Jamg2412 is offline
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
08
Jamg2412 is offline
Old 05-24-18, 09:32 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
07
Jamg2412 is offline
Old 05-24-18, 09:33 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
06
Jamg2412 is offline
Old 05-24-18, 09:51 AM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
Originally Posted by Jamg2412
06
Ha. Just upload them to postimage.org and paste the forum hotlink here.
2019 Salsa Warbird
shoota is offline
Old 05-25-18, 10:46 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
Photos
I can’t post URL or photos before 10 interactions.
Coming soon 05
Jamg2412 is offline
Old 05-25-18, 10:50 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
Photos
Photos
postimg.cc/gallery/ttmxcnig/
this should work.
Jamg2412 is offline
Old 05-28-18, 11:20 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
Tyre pressure
What pressure do you choose for the Gravel King sk?
Jamg2412 is offline
Old 06-05-18, 09:00 AM
SargentRedbeard
SargentRedbeard's Avatar
Hey there,
Not sure if you guys have got gotten this figured out but I registered on this forum just to let you know what worked for me. I have the 2018 limited edition E5 Diverge finished in copper and I have run a variety of wheels and tyre sizes with great success. I will list the combo I have run with no clearance issues.
Industry Nine Enduro 305 650b wheelset with 650x47c and 650x48c tyres. The 47mm tyres were WTB Horizons and the 48c tyres were Compass Switchback Hill in both standard casing and extralight casing.
Roval CL50 700c wheelset with Compass Barlow Pass 700x38c tyres in extralight casing.
I have run all the combos both on and off the road with no clearance issues. Hope this helps!
Cheers,
Jared
SargentRedbeard is offline
Old 10-07-18, 12:25 AM
eeparis
Bikes: Liv Avail Advanced 2 (2016), Specialized Diverge e5 comp women's (2018)
Nubie, I just bought a Diverge e5 comp, also in the women's version, and I'm planning to change the tires for more gravel-oriented ones since I already have a good road bike. Just wondered how those panaracer 35 tires are working out for you.
eeparis is offline
Old 10-14-18, 06:39 AM
skidad21774
Bikes: Diverge, Roubaix
Also interested in an update/info on gravel tires. Recently purchased a Roubaix for my road rides. Looking for gravel/trail tires for my 2016 Diverge DSW Elite (Alum). It is stock (AXIS 3.0 wheels) recently replaced my OEM Specialized (30mm) for a set of Gatorskins (28mm). Now that my wife and I are riding more "mixed surfaces/rails and trails" I'm looking for a larger tire with better grip (Gskins are slipping too much when we get on wet grass, etc.).
skidad21774 is offline
Old 10-14-18, 10:22 AM
Jbhardy
Quoted: 10 Post(s)
I'm running Gravel King 35 SK on my Diverge and find them ideal on pavement and dirt. No experience yet on any true gravel, but suspect there won't be any difference. For what it's worth, my experience with Gatorskins is that they suck when it's wet.
Jbhardy is offline
Old 10-14-18, 10:50 PM
eeparis
Panaracer Gravel Kings hard to install?
I was considering these tires for my Diverge e5 comp and then read that the tires are really hard to mount on the wheels. One guy posted that it took him so long to get them on the wheels that he decided not to use them, since he worried about having to change a tire on the road somewhere. Have you had this problem? Another tire I've heard is very good is the Schwalbe g-one, also in 35.
eeparis is offline
Old 10-15-18, 03:39 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
Panaracer Gravel king SK 38 mm
I have experience in these tires with two different wheels, the OEM Axis sport disc and Mavic Aksium, no problem to change tires. The grip is very good, you can roll fast in gravel and tarmac, no problem at all, in mud and rain is not bad. If you are not going into rainy days and mud you can go with the gravel king, it is lighter and lower rolling resistance (faster). I only had one puncture but it was in a side wall of the tyre with a thorn, completely my fault. My recommendation is to use the proper tyre pressure. I ride with inner tubes and I usually go with 55 in the front and 60 in rear. If I am bike packing 60 front 70 rear. The tire limit is 75 with inner tubes, 65 tubeless.
Jamg2412 is offline
Old 10-15-18, 03:44 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
Gravel king sk 38 mm
In my case it is easy to change the tires, more than 1000 km with them and only one puncture. Two different wheels and no problem no change them from one to the other.
Jamg2412 is offline
Old 10-15-18, 05:58 AM
eeparis
Thanks so much for your quick answer! This helps a lot.
eeparis is offline
Old 10-15-18, 06:29 AM
Jamg2412
Alberto
Jamg2412's Avatar
Quoted: 17 Post(s)
gravel king 38 mm.
Check this video. He goes tubeless, but whit a inner tube in the middle of the road you should be fine.
Jamg2412 is offline
Old 10-15-18, 07:51 AM
Jbhardy
Quoted: 10 Post(s)
They were very difficult to get on the rim in my case, Roval CLX32's. I haven't needed to remove them yet, only one puncture so far, glass, that sealed within a mile with the orange seal. I'm going to get a bead jack for the future.
Jbhardy is offline
Old 10-15-18, 08:12 AM
eeparis
That's what I've read in other posts. One rider posted that he broke two tire levers trying to get these on. Maybe it depends on the rim.
eeparis is offline
Old 10-15-18, 10:50 AM
eeparis
Check this video. He goes tubeless, but whit a inner tube in the middle of the road you should be fine.[/QUOTE]
Thanks so much for posting the video! I've never used tubeless and I wondered how to do it!
eeparis is offline
Old 10-21-18, 04:18 AM
eeparis
Originally Posted by Nubie
Just wondering if the OP ever discovered the answer to her/his question. I also recently bought a Diverge (aluminum) and my cousin purchased a carbon version. Hers comes with 38mm stock knobby tires, mine with 30mm smooth ones. I'm looking into knobbier tires so we can do trails together, not sure what width I should get. I read that 38mm was the max my aluminum frame could use, 42mm for carbon. Is this true? I only read this in one review, all the others I've read state that 42mm is the max, making no differentiation between aluminum vs. carbon frames. Can anyone clarify?
Thanks!
Hi, I just bought the same bike as yours, the Diverge e5 comp women's version, and I'm wondering how those Gravel King 35s are working out for you, and if you had trouble getting them on the rims. (I had no idea, when I bought the bike, that it would barely take/wouldn't take 38 tires. Almost all the info I see online doesn't differentiate between the aluminum and carbon frames re. tire clearance. Very annoying. I also wonder if frame size makes a difference. I've seen posts by people who are running 38 tires on this bike, but maybe their frames are larger. Mine is a 48 women's frame, so pretty small.)
eeparis is offline
Old 12-28-19, 07:27 PM
Meech33
Quoted: 7 Post(s)
Liked 110 Times in 38 Posts
This person was able to fit 700 x 40c on an alloy E5. Not much clearance but they fit.
Meech33 is offline
Old 12-29-19, 06:32 AM
diego83
Do you think a 700x28 on road rim(17 or 19c) could be a problem with bottom braket height?
I think a 265 mm bottom height with 38c tires will become a 255 or 256 mm height with 28c tires.
Thank you
diego83 is offline
