canti's vs. v-brakes
for searching thru the archives on this forum, it looks like this topic has been discussed at length, but i haven't found an answer to this.
from my understanding, if you want to use v-brakes w/ drop bars & road brake levers you need travel agent to get the proper pull from the lever. does this decrease the effectiveness of the brake? and in this set up will you get better stopping power with canti's or v-brakes?
(and if it matters i'm running 700c tires)
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
If you are using road brake levers you need travel agents to make the V brakes work.
It's a little bit of a pain too. More stuff to fiddle with. You lose leverage too.You don't really lose stopping power you have to squeeze the brake levers harder. There is no particular advantage to the V brakes then.
Go with a good set of cantis. Save yourself some trouble.
I am a lonely visitor
Bikes: Michelle Pfieffer, the Carbon Fiber Wonder Bike: A Kestrel 200 SCI Repainted in glorious mango; Old Paintless, A Litespeed Obed; The Bike With No Name: A Bianchi Eros; RegularBike: A Parkpre Comp Ltd rebuilt as a singlespeed.
Originally Posted by riderx
Dia-Comp makes V-brake compatible levers. I think they go by 287 or something similar.
Religion is a good thing for good people and a bad thing for bad people. --H. Richard Niebuhr
Bikes: 2 many
Liked 323 Times
