crank spinning with wheel in stand
the wheels have about 500 miles so break in should not be the issue. it only happens when spinning the wheel very fast. and it doesnt sag when i am coasting during a ride. what im not sure if this is a big enough issue to get nashbar to replace them with a new pair. or if its a so what kinda problem. thanks for any answers.
Bikes: Moots Vamoots, Colnago C60, Santa Cruz Stigmata CC, and too many other bikes I don't ride
Quoted: 152 Post(s)
Liked 7 Times
Huh?
Mechanical doping is the first thought came to my mind
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
So the freewheel sticks ever so slightly? You're probably losing valuable watts when coasting.
ya it is only able to turn the crank when spun very fast. just wanted to make sure this was not a sign that something was going to go bad,since the wheels only have 500 miles. but if its a so what kinda thing,then I'm fine not worrying about it.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
It's normal; don't worry about it...
Today, I believe my jurisdiction ends here...
George Krpan
Quoted: 12 Post(s)
Remove the cassette body, pry out the rubber seal in the rear of the cassette body, and dribble some oil into the cassette body.
don't try this at home.
Quoted: 982 Post(s)
Liked 517 Times
EDIT -- The following responses explained it: Spinning the rear wheel forward by hand moves the chain and so the cranks turn when normally the cranks don't move.
So this post isn't related to the original question.
and
I'm not sure what you are asking. Is it about the bike bouncing in the repair stand when the wheel is cranked fast?
That's normal. The rim joint opposite the valve is heavier than the rest of the wheel, so it's a little out of balance. But it's not a problem at all when riding. Once, on a newly paved, very smooth downhill, I could barely detect the vibration, but not on normal roads.
The other responses think your question is about the wheel slowing down too fast.
With the rear wheel off the ground, grab the tire and spin the wheel with a moderate pull. It should spin for at least 5 seconds (and usually a lot longer than that.) If it stops within a few seconds, something needs adjusting.
Quoted: 18459 Post(s)
Liked 15,710 Times
Non omnino gravis
Liked 15,710 Times
Quoted: 1873 Post(s)
Liked 692 Times
You're on a roll lol.
It wasn't lost on me, beautiful.
and you're not even new here...
2019 Salsa Warbird
2019 Salsa Warbird
