Impromptu Chainwhip
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
Impromptu Chainwhip
Never owned a cassette before, only free wheels.
Buy splined remover, lock it into vice, put wheel on top, turn wheel. - easy
But that doesn’t work with a cassette, wheel just goes around. And you need a “chainwhip”
And I don’ts-gots a chainwhip.
I don’t recommend you do this. This is for entertainment purposes only.
I took a 9/16” ring spanner (wrench) put both ends of an old chain through the ring.
where the chain folds it is too big to pass through the 9/16” - instant chainwhip.
I will mention that a didn’t have to lean on it. I suspect it might break the wrench.
hey, I now have a squeaky clean cassette.
Barry
Barry
I just put on some padded glove, wrap the chain arond my hand and find a leveraged position to hold it in place while unscrewing the lockring.
Quoted: 1438 Post(s)
Liked 1,092 Times
I've looped an old chain around the cassette and clamped it with Vice-Grips.
Quoted: 41 Post(s)
Liked 39 Times
DON'T DO THIS AT HOME
but it works fine . I do have a chain whip but if you don't use an air impact wrench SET TO TURN IN THE PROPER DIRECTION !!!!!! to turn the lockring tool . It spins the lockring right off no problem. If you turn it in the wrong direction.........well, you wanted a new hub anyway.
It takes about 15 min to make a chainwhip from a piece of steel stock and 2 sections of old chain; some blue tape for a handle if you want to be fancy
Likes For 3Roch:
I always just took an old chain and grabbed it and the spokes with a gloved hand. I also put the tool in a vice and turned the wheel. Now I have a whip and it takes two seconds. A whip isn't that expensive.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I have an old 18" pipe wrench that grabs a large cog with a bit of chain around it.
I seldom buy special tools if I only need them once a year or so. I volunteer at enough bike shops, and I can usually use the facilities when they're not busy, so my home shop is pretty bare of special bike tools.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Quoted: 4806 Post(s)
Liked 3,928 Times
Now, you can get much fancier. The fix-gear of my avatar sports a 22" aluminum shop-quality chainwhip that weights 1 pound exactly. For on-the-road cog changes at hill tops so I can go from a 23 tooth cog to a 12 for long (ear-to-ear grin) descents.
I had to replace the chain of my first tool after 15 years because the end pin pulled out. Luckily, I have bikes that regularly generate surplus chains.
Ben
This. Home Deport for a piece of 1 x 1/8" flatbar. An 1/8" (or a touch larger) drill bit. 5" of chain and a foot of chain. 3 holes. (Look at any chainwhip and the hole locations will be obvious, There is no rocket science here. You will need to grind down the flatbar in the area of the holes to the inside width of the chain. (1/8" chains for fix-gears are easy!)
Ben
Ben
Liked 3,928 Times
