Bikes go flat suddenly, Texas, U.S.
Hello,
I have a strange flats happening rather regularly. I've been living in Texas (Houston area) for the last three years, and every 6-9 months flats happen suddenly when bikes are idle (at rest). Both mine and my spouse's bikes are affected.
Few details:
- We live in an apartment complex, bicycles are stored outside. I stored them in two places: in the shadow under the stairs and on the balcony where they were exposed to sun in the afternoon. In both places these flats continued to happen.
- After replacing tubes every time I inspect tires and tubes and see no signs of vandalism or animals.
- The damage is often located on the side of tires (neither at the inner circle, nor at the outer circle, just on the side), and sometimes I see a thread of very small holes on the side (again, can't post the image because of the forum rules )
- I don't see anything special on the tires, except that they are quide aged (mine are 10 years old, and my spouse tires are 5 years old)
- The flats never happen immediately after we ride. Usually, a descent amount of time passes after the last ride, at least few weeks. So I don't think this is a delayed result of a direct damage to a tube.
- We ride bicycles about one time per quarter (infrequently).
- This never happened to me before moving to Texas so I am puzzled.
I have two pictures I took today, a week ago after both tubes on my bike went flat both at the same time (!), but the forum rules don't allow me to post pictures.
At this point, I have two hypotheses:
1. The fact that I store the bicycles outside makes them exposed to some extreme Texas conditions that just lead to the rubber deteriorating with time. It is about ~40 degC here during summer, and in spring the temperature fluctuates sometimes from 0 degC to 30 degC.
2. When we do ride, even though it is infrequent, the tube gets into contact with something inside, like a tire or a rim, and gets some excessive rubbing so that it creates an area which later deteriorates further with time (maybe this is catalyzed by Texas climate) and eventually ruptures.
At this point I am pretty tired of replacing tires before almost every our infrequent ride.
Did anyone experience something similar? Any idea how this can be be prevented without moving the bicycles indoors? (I don't have space )
Front wheel
Rear wheel
Few details:
Front wheel
Rear wheel
Quoted: 5793 Post(s)
Liked 2,584 Times
If you mean that the tire is found flat after a long period of non use, then I suspect you're seeing the effects of thorns.
These cause tiny pinhole leaks, so slow that they don't affect rides, so you don't notice until much later.
The thin tread of worn tires compounds the problem, but it's more about your move to the Southwest.
Consider using a liquid sealant and/or replacing the worn tire.
Unfortunately, I can not paste the pictures. In the pictures I took today the damage points are located on the side of tube (neither outer which is in contact with the road, neither inner) and is surrounded by a large number of small holes/imperfections of the tube as if the material was aged or as if there was an excessive rubbing of some sort. I does not look like a single point of damage. I wish I could attach the pictures. Eight more posts to go before I can do this.
Liked 2,584 Times
Based on the newer post, it might simply be age and chafing of dried out material. This might be compounded by inadequate pressure which causes excess tire wall flex.
If you're not ready to replace both tires and tubes, try riding at or near the maximum pressure marked on the tire walls. However, long term, you might have to accept that your tires are well beyond their prime of life.
FB
Chain-L site
FB
Chain-L site
Quoted: 6196 Post(s)
Liked 4,811 Times
is this the picture you wanted us to see?
https://www.bikeforums.net/g/picture/28779982
Till you get ten posts and maybe a day later, just let us know you put them in the Gallery here on BF and someone will post it for you or at least know to go look at it.
As for your flats, might be just a coincidence that you moved. Perhaps it's some other person that thinks it's funny to let the air out of your tires.
Can't tell much about the abrasion you have circled. Do you see bubbles coming out of it when you inflate the tube and wipe a soap solution over it or dip in water?
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times
I live in Houston and store my bikes at ambient temperature in a garage. I have not experienced anything like what you described.
It is not real clear from your post if the holes you find are only on the inner tubes or both the tube and the tire.
Thoughts:
1. With a long time between rides, it’s probably necessary to pump them up before each ride. I’m adding air every 2-4 weeks. Low tire pressure can give pinch flats somewhat like your description.
2. If the tires are old, they may have developed flaws that could rub holes in the inner tube. If this is the cause you would expect your patches to be in about the same place or the equivalent if the tube was flipped on re-installation.
So there may be chupacabras in the area but no indication they target bike tires or tubes.
Thoughts:
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
It sounds like it’s time for new tires on both bikes.
Also, be aware that bike tires/tubes don’t hold air indefinitely. Butyl rubber used for most inner tubes will leak air over time.
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
I toured through there some years back.
Likes For tcs:
Quoted: 540 Post(s)
Liked 416 Times
I always do my best to choose tubes that don't need to stretch out to the tire.
For example, if the tire is 26x1.50, using a 26x1.25-1.50 tube means that skinny tube has to balloon all the way out to 1.5.
Instead, choose a 26x1.50-1.95 tube, it won't stretch.
Quoted: 967 Post(s)
Liked 1,631 Times
Tubes are not what they used to be. It appears you are showing some manufacturing defects in a butyl tube. There is really no telling how long those little bubbles have been there and the area around the tube stem is particularly undesirable.
Sure sounds like a good excuse ta get your bikes new tubes and maybe tires.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I could also locate the link to the second picture of my rear wheel referenced as 28779933 (still can't paste the full link)
About "other person" - that's what I thought when it started happening two and a half years ago, but I inspected the tires after each flat and I could find no cuts or distinct holes pointing at the human/animal intervention.
And yes, the red circles are around the areas where bubbles appeared from inflated tube under water.
Thanks for your inputs!
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
cheap tubes plus Houston Sunshine equals flat tires.
and months is not "suddenly".
the tubes show signs of literally MOLDING themselves to the tire... note the serrations... that's from the tires.
Bike Tires lose air over time...
Hot sun does REALLY bad things to Cheap bike tires and Tubes.
Where the stem is bonded to the tube is even coming apart.
Thoughts:
Thoughts:
I guess in your case garage damps a bit Texas temperature hikes, I don't have such opportunity unfortunately.
Yes sir, will replace tires and rim tape most likely as well as it has couple of folds in few places. Thank you!
Liked 739 Times
Thank you for your input! At this point the old tires are my main suspect. I just ordered two "Goodyear 26" x 1.9"-2.3" Heavy Duty Bike Tube" and I will be looking for tire replacement as well.
I would replace the tubes and check that the new tubes are not leaking out the valves. The lighter "race" tubes wil be thinner and there will be more permeation with air leaving through the material. I would check that the valves on your tires are tight and use a valve core tool to tighten them. The Park Tool valve tool is cheap and works on both Schrader and Presta valves.
Thanks everyone for the inputs!
The next logical question is there a recommendation of not very expensive but descent tires for 26" tires? This is mostly for dirt rides in parks, and some occasional rides in a city, something like city/MTB profile for hardtail.
And similarly inexpensive but good rim type?
Cheers,
Pavel.
Cheers,
Pavel.
Liked 739 Times
Are the Tires showing Weather Cracking? Are the tires Significantly Worn?
If you answer "no' to both questions, you DO NOT NEED New tires. THE TUBES should be replaced with a better brand, NOT THE TIRES.
not sure if it was you or someone else,but Goodyear HEAVY Duty tubes (enphasis on HEAVY!) were mentioned...they will make your bike ride more roughly and sluggishly.
i use Kenda, Specialized and Michelin tubes,mostly. Regular tubes... and then i Check the pressure Every riding day, then top up as needed.
to review.. Bike Tubes Lose pressure over time..especially over three or more months.. it's a FACT. Slimy Sealants are a mess, Heavy, and Will Plug The Valve occasionally, which is just another problem.
Good quality tubes, No Sealants, and Frequent Pressure monitoring.. then shield those bikes From That Brutal Houston Sun.
Likes For maddog34:
Liked 739 Times
hybrid/crossover tires for a decent price... https://www.ebay.com/itm/29230661493...3ABFBM1pLInPdh
you should spend your savings on a Sheet of Plywood... 3/8" ACX will work.
Quoted: 501 Post(s)
Liked 436 Times
Schwalbe Land Cruiser is a basic mixed-use tyre, or their Black Jack is more dirt oriented, both available cheap on Amazon/eBay or at many stores. You may also find Continental Cross King at a good price, or some Michelin models - none of the big name brands makes junk, but you do get what you pay for regarding speed/weight and puncture protection. Be careful not to get anything too wide for your frame, or too narrow for your rims.
Sock Puppet
Liked 863 Times
Cheers,
Pavel.
Cheers,
Pavel.
