TA single crank conversion
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
I want to single-ize my favorite crankset, my TA cyclotourist for a commuter build. It's a triple now. Am I going to run into any problems with this, or is it as simple as just slapping a single chainring on there? It'll be a 1x8 with a chainguard to keep the chain from falling off, so I'm not too concerned about chainline. I seem to recall @noglider did this with a TA with tiny crank arms, but I think that was an IGH setup.
"Party on comrades" -- Lenin, probably
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Might as well fix the chainline while you have the crank off. Shouldn't be too hard to measure what you have and order a BB with the right length.
Aspiring curmudgeon
Quoted: 111 Post(s)
Liked 26 Times
It's moving to a different frame anyway. Do I just shoot for the middle of the cassette?
Outer minus the others will do . BB length is what you pick for the chain line.
maybe just move the outer to the inside of the right crank arm. rather than fitting it thru the chainring.
Quoted: 7348 Post(s)
Liked 2,470 Times
Bikes: a few that I can't recall
Quoted: 346 Post(s)
Liked 302 Times
Additionally, after a bit of math, if I use the master ring on the front (53), I would need to use a completely silly rear freewheel that looks like a spoke guard. So, I am cutting off each of the six arms, radiusing the ends, and bolting the middle ring (44) only to what is remaining, like an external spider. I think this will look Klunkerish, without being obtrusive or silly, and have a good chainline
Alternatively, I think you or I could bolt a TA "copy", Ticinoi, on the the 5 bolt arm itself, available in a 42.
Although the Ticoni could arguably be a few mm outward on the chainline, but going from 44 to 42 might let you ride on 16 instead of 18 in the rear, curing itself.
Liked 2,568 Times
That would probably work... if you're going with a standard single-speed rear hub, I'd shoot for 42mm between the centerline of the seat tube and the chainring.
Quoted: 1627 Post(s)
Liked 630 Times
Noglider's not the only one
Works a charm, and you can mount the ring on the inside or outside of the crank arm, helping out with chainline and chainguard clearance issues. Another trick you can do, if you're real close and don't want to pony up for a new, longer spindle, is add a spacer or two between the fixed cup and the bottom bracket. That's what I ended up doing. Good enough for now, until I get a new, longer spindle.
Yes, lots of people have singlicized TA cranks. Here's mine. I did not change the BB, and the chain line is not perfect with the SA IGH, but it's close enough. The Q factor is still ridiculously low anyway, like 135mm.
You can find yourself a large outer ring (at least several teeth larger than your desired single ring, which would be the inner ring) and mill down the teeth, turning it into a chain guard. I've seen this done to TA cranks and it works very nicely!
Aspiring curmudgeon
Quoted: 111 Post(s)
Liked 26 Times
I'm actually going with an 8 speed cassette with a rear derailleur. Considering the middle chainring position works pretty well now with the entire range of the freewheel as a triple, I'll probably take the above advice and mount an outer ring to the inside.
Quoted: 3810 Post(s)
Liked 6,699 Times
Or guy with Nervar, the poor man's TA:
Aspiring curmudgeon
Quoted: 111 Post(s)
Liked 26 Times
I am doing the same thing, for a vintage look Klunker (1946 Schwinn DX), and the TA cranks look perfect and "period correct", but I don't want a front derailleur.
Liked 2,568 Times
D'oh, I've had FG/SS on the brain lately. Yeah -- shoot for the middle of the cassette.
Liked 630 Times
Liked 2,470 Times
Hey, I own that bike now, don't i?
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
1 X 2 IGH with a bash ring.
No one cares
anther single TA chainring user here. Sorry for the crappy pic, not to mention the lose chain
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 346 Post(s)
Liked 302 Times
Liked 6,699 Times
Aspiring curmudgeon
Quoted: 111 Post(s)
Liked 26 Times
Hey @noglider and @southpawboston, what spindle length are you running on yours? I'm moving from a french-threaded frame to and english-threaded, so I'll have to replace the BB.
Also paging @rhm, @-holiday76, and @Lascauxcaveman, plus anyone else I've missed.
Liked 2,470 Times
I don't know. The Viscount is using the original Viscount BB, and I didn't measure it.
