Carbon wheel = tubeless capable?
Liked 2,981 Times
Has anyone taken an unknown brand hooked carbon wheel that didn't have markings for being tubeless ready & make it tubeless ready?
I'm thinking that if tubeless tape is used, it would be capable but I'm not sure what makes a carbon wheel different in that aspect.
I could buy the rim tape, sealant, TLR Tire, & try it, but would like to not overlook something that others would know.
It's double walled, but I haven't seen any not double walled.
-Oh Hey!
-Oh Hey!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1951 Post(s)
Liked 1,475 Times
Liked 2,981 Times
Liked 1,475 Times
It is my understanding that tubeless tires run at lower pressures, so that might help. But not my area, so good luck.
Liked 2,981 Times
the better reputable build set I have dont have the holes. both of the rims almost could pass as twins.
-Oh Hey!
-Oh Hey!
Liked 1,475 Times
2. With so open mold wheelsets available, there is no basis to assume that the construction of the two wheelsets are same or equivalent.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2589 Post(s)
Liked 5,652 Times
Heck, just get out your drill and a tiny bit and make your own weep hole (sounds so wrong). 💀
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 4418 Post(s)
Liked 1,569 Times
Seems like a good way to end up with you teeth in the asphalt.
Liked 2,981 Times
2. that makes more the reason to have a distinguishing difference made into the designs.
-Oh Hey!
-Oh Hey!
Liked 2,981 Times
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Does the prospect rim have a shelf between the bead seats? If so, then the answer is a 100% maybe. The shelf is necessary so the bead has something to come up and rest upon. Else the risk of a burp and related complete and unscheduled demount from the rim is much more likely.
Car dependency is a tax.
Likes For base2:
Liked 2,981 Times
-Oh Hey!
-Oh Hey!
Liked 1,475 Times
AR46 Carbon Road/CX/Gravel Wheelset - Light Bicycle
Both hooked and hookless tubeless wheels have bead shelfs / shoulders.
Quoted: 878 Post(s)
Liked 726 Times
Enve wheel blowout - Weight Weenies thread
Likes For surak:
Liked 2,981 Times
No. base2 is referring to the shoulders on both sides of the rim bed. See, e.g.:
-Oh Hey!
-Oh Hey!
Liked 2,981 Times
Better check that you have that better reputable build set up correctly then.
-Oh Hey!
-Oh Hey!
Liked 2,981 Times
Quoted: 6974 Post(s)
Liked 10,975 Times
Liked 1,569 Times
Liked 2,981 Times
I'm looking for responses that will give key indicators that determine what makes a carbon rim being tubeless compatible.
-Oh Hey!
-Oh Hey!
Liked 1,475 Times
I am potato.
Liked 1,631 Times
Likes For base2:
Liked 2,981 Times
-Oh Hey!
-Oh Hey!
