Cleaning the chain with rubbing alcohol?
Quoted: 86 Post(s)
Like many people, I use isopropyl to clean the brake pads and braking surfaces. Sometimes I also wipe dirty spots on the frame with it. It works well and evaporates quickly. So I started wondering recently if it would be a bad thing to use it to wipe down the chain? So I did some quick searching, and I found an article that actually recommends this.
So my question to the mechanics is whether this is actually a good idea or not. Specifically, I wonder whether it is a good idea at all to wipe down just the outside of the chain with rubbing alcohol, and further, would it be bad to just drip it from the bottle directly onto the rollers. Could this have any negative effects?
For the sake of clarity, I'm not specifically asking whether it is an effective degreaser per se. Although I'm not actually sure whether it technically qualifies as one or not. Nor am I asking whether it can take the place of one. I'm merely asking whether the practice itself would be safe for the drivetrain.
Wiping the outside is fine. Dripping directly onto the rollers isn't going to accomplish what you want. If you want to clean the old lube off the rollers a degreaser, like OMS, is better. If you want to lube the chain, use chain lube. Isopropanol will just wash some of the old lube out, but not enough to be an effective cleaner.
like we used to say
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
Isopropyl alcohol is not an ideal solvent for chain lubricants. I'd suggest using odorless mineral spirits (OMS) instead. OMS can be reused; just put the used liquid into a container and let the particulate matter settle out. Decant the clean spirits off the top the next time you need to clean your chain. Replenish with fresh spirits as needed from the original container.
Quoted: 86 Post(s)
Well, I tried it. It seems to work pretty well on the outside of the chain. The chain is nice and shiny. But I can still see a tiny bit of black gunk between the plates, even though when I grab the chain with my fingers and wiggle the plates, I can't feel any "grit" (I take this as a sign of a clean chain). So it's great for an exterior polish, but seemingly not for a deep clean (it was already free of that "gritty" feeling before I used the isopropyl). And yes, I added oil afterwards. It was already time to do that anyway.
How often do you guys completely clean the chain? I rarely do that. Usually I just wipe it down regularly, and add more oil when it feels like the previous application has gone dry. Very rarely will I give it a bath. By the way, I really hate the park tools chain cleaner. It's so messy. It does seem to do the job, but the cleanup sucks.
Quoted: 645 Post(s)
Liked 797 Times
70% isopropyl will make the chain shinier, but won't really get to the heart of the matter ie, internal gunk. Otherwise, it's a great general cleaner. I buy three chains when I get a new cassette, then rotate them every ~500 miles, so that when I take the dirty chain off, there's a properly clean chain ready to go on, and I can spend a little time getting the chain clean. It also ensures that chain and cassette wear proceed in a coordinated manner. Every ~1500 miles (1 full round of chains), I pull the cassette, chainrings and jockey wheels and give them a good clean. Derailleurs get degreased and relubed. To clean the chain, I use heavy duty degreaser and a nailbrush, and slosh it around in mineral spirits. Finally, it gets a good rinse in running hot water, then hung up to dry. A hot chain usually dries in ~30 min, so no rust.
Quoted: 86 Post(s)
Eh... I'm nearly at 1500 miles on just the one chain. I measure the chain wear with a special tool. Park Tools CC-3.2. The chain still isn't worn yet and everything still shifts fine. Would it be a waste to switch the chain at this point? I've been using the same chainrings and cassette for all of those miles.
Quoted: 567 Post(s)
Liked 562 Times
Senior member
Quoted: 942 Post(s)
Liked 656 Times
If anything, I find chain wear checkers tend to give false positives for wear, so generally speaking, if the chain checker says it's good, it should be.
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
I used to remove and thoroughly clean the chain about once a month. Disconnect the quick link. Shake the chain in a half gallon milk jug with a cup of mineral spirits (then let the spirits settle, and reuse it). Still not perfectly clean, so shake with water and dish detergent. Dry completely overnight with a little heat. Relube and wipe down. Back on the bike.
I got 4000+ miles from the chains this way.
Now, I just wipe off the outside of the chain with paper towels dampened with rubbing alcohol. Relube, wait a few minutes, then wipe the chain with dry paper towels.
The chains still go for 4000 miles.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Bottom line: The alcohol is safe but it just doesn't work. Mineral spirits...odorless or otherwise...is also safe but it works.
Stuart Black
Stuart Black
Quoted: 86 Post(s)
Perhaps I will look into getting a different chain checker tool to compare against.
Quoted: 567 Post(s)
Liked 562 Times
Apologies, but I did some searching on the forums looking for a measurement of the chain checker tool to compare mine to, and I didn't find anything. All I found was a bunch of people arguing about the tool. Short of measuring the chain itself, which I also see people complaining and arguing about, I really can't find a way to make sure that the chain checker has been created with accurate dimensions. Of course that may not be the exact issue that some people are complaining about. Not wanting to get into error caused by play in the rollers or whatever, which I believe the tool is intended to measure in the first place anyway, I will just trust the tool for now. That is unless of course you'd care to provide more helpful information. With respect, thank you.
Measuring Chain Wear
The standard way to measure chain wear is with a ruler or steel tape measure. This can be done without removing the chain from the bicycle. The normal technique is to measure a one-foot length, placing an inch mark of the ruler at the side of one link pin, then looking at the corresponding link pin 12 complete links away. On a new, unworn chain, this link pin will also line up exactly with an inch mark. With a worn chain, the link pin will be past the inch mark. For accurate measurement, the chain should be held under some tension -- either on the bicycle, or hanging. Also, use a metal ruler or tape measure. Wood, plastic and cloth all can expand or shrink. Measurement is also possible with a metric ruler -- see below.This technique gives a direct measurement of the wear to the chain, and an indirect measurement of the wear to the sprockets. first, let's look at how to do this with a ruler that measures in inches.
- If the link pin is less than 1/16" past the mark, all is well.
- If the link pin is 1/16" past the mark, you should replace the chain, but the sprockets are probably undamaged.
- If the link pin is 1/8" past the mark, you have left it too long, and the sprockets (at least the favorite ones) will be too badly worn. If you replace a chain at the 1/8" point, without replacing the sprockets, it may run OK and not skip, but the worn sprockets will cause the new chain to wear much faster than it should, until it catches up with the wear state of the sprockets.
- If the link pin is past the 1/8" mark, a new chain will almost certainly skip on the worn sprockets, especially the smaller ones.
I use a park tool chain cleaner. I put some citric cleaner in the reservoir and chain looks brand new when I am done.
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4407 Post(s)
Liked 4,520 Times
Same here I use the Park chain cleaner. I will power wash the chain and cassette looks like new. Yes I know that is a bike sin but I changed my chain after 4000 gravel / road miles. I don’t use any fancy measuring tools I just go by how the shifting feels and the stretch by pulling the chain with my hand. If I get a stubborn link I use Remington gun oil to loosen it up. Yes this is barnyard but it works.
Quoted: 741 Post(s)
Liked 818 Times
I use citrus degreaser from the 99 cent store. I have used Simple Green, but for 99 cents, this works just as well. Spray it on, wipe it thru a rag. I use an old toothbrush to scrub the tough to reach inner areas. I've also used the Finish Line gadget with the little roller brushes in the plastic housing that snaps over the chain. You pull the chain thru it and thru the degreaser in the reservoir. It does a good job too, but spray and rag works as well for me. I use the citrus spray and tooth brush on the jockey wheels too.
Life Feeds On Life
Liked 4,520 Times
