Wheelset depth for all-round wheelset?
Old 05-31-19, 06:35 AM
maartendc
maartendc's Avatar
Bikes: 1989 Cannondale 3.0, 2001 Trek 5200, 2010 BMC SLC01, Minerva MTB Hardtail
Quoted: 432 Post(s)
Hello all,
I am tempted lately to get an aero carbon wheelset. I was just wondering, what is a good depth to go for for an all-round wheelset? (note: I have never ridden an aero/ carbon wheelset so don't really know what I'm talking about here)
- Mostly flat terrain, and would like it to be as aero as is practical.
- Probably will take weekend trips to mountains / hilly terrain
- Occasionally very windy, and don't want to have to leave the wheels at home for that. (I weigh 150 lbs if that matters at all)
What is the best depth to go for an all-round, do-it-all (semi-)aero wheelset? 35mm? 40mm? 50mm? 60mm? Something else?
I'm looking at some nice 60mm wheelsets, but it seems like those would be too deep for all-round usage?
Thank you!
maartendc is offline
Old 05-31-19, 06:56 AM
cycledogg
cycledogg's Avatar
Bikes: Cannondale CAAD4, CAAD5, CAAD7 (Optimo), '07 SystemSix, '08 Trek TTX 9.0, 2015 Cannondale Supersix Evo - ZIPP
Quoted: 333 Post(s)
Liked 9 Times in 8 Posts
Originally Posted by maartendc View Post
Hello all,
Thank you!
Some say 50 is best. I prefer 35-38. I have 25 to 50 and seem to get the best "all around" from my Zipp 303. Light, not too deep, not too shallow. YMMV
Cheers
cycledogg is offline
Old 05-31-19, 07:33 AM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 344 Post(s)
Liked 46 Times in 35 Posts
Agree
Cycledogg's advice is good, but don't think wheels are a magic wand. Real gains from carbon wheels are minimal, at best. Unless you're replacing steel wheels, of course. ;-)
dmanthree is offline
Old 05-31-19, 07:40 AM
str8jakett
I pedal in my sleep...
str8jakett's Avatar
Bikes: Giant Propel Advanced Pro 2017, Giant Propel Advanced Pro 2015, Giant TCR Advanced 0 ISP 2008, Cube Cross Race SL 2018
Quoted: 97 Post(s)
Liked 12 Times in 7 Posts
I have 38mm Superteam carbon and 58mm Zipp 404 Firecrest. I think either are fine for all around. I live in hilly to mountainous terrain and it's often more windy than not, usually 20 to 30mph gusts. I blow around regardless (also 150lbs), but I like both depths equally well and can't tell much of a difference between the two.
str8jakett is offline
Old 05-31-19, 08:08 AM
Sojodave
Sojodave's Avatar
Bikes: Fezzari Fore CR3 Di2
Quoted: 133 Post(s)
Liked 21 Times in 9 Posts
I have Reynolds 41mm carbon wheels and I think they are great for an all-around wheel. I occasionally get blown around, but not enough to be too concerned.
Sojodave is offline
Old 05-31-19, 08:42 AM
zatopek
Bikes: Neilpryde Nazare, Storck Scenero G3, Colnago Extreme Power, CAAD 10, Bowman Palace R, Strong Custom Foco Steel, BMC SLR01, BMC ALR01
Quoted: 22 Post(s)
45 to 50 mm. I recommend "modern" style aero wheels, ones with 19 to 21 mm, or so, internal width and rounded at the rim's edge where spokes attach. I ride 50 mm FSE wheels and they honestly deal with even gusty 30 mph crosswinds without much fuss; on par with even shallow, aluminum box section rims I have ridden. And, the wider, modern rims very nicely accommodate 25 to 28 mm tires that allow for lower inflation pressures and better ride quality and grip without much aerodynamic compromise, as far as I can tell. No, I have not tested in a wind tunnel and have no scientific data to defend these assertions.
On wheels between 60 and 80 mm in depth that I have ridden, I got blown all over the place in gusty, heavy crosswinds and felt very uneasy.
Good luck. Let us know what you decide and share your new wheel impressions, if you take the plunge, with us after you have put in some miles in various conditions.
zatopek is offline
Old 05-31-19, 09:46 AM
colnago62
Quoted: 312 Post(s)
Liked 24 Times in 18 Posts
Cheers
Zipp 303 was the best wheel set I ever owned.
colnago62 is offline
Old 05-31-19, 09:50 AM
colnago62
Quoted: 312 Post(s)
Cheers
Old 05-31-19, 10:45 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 8510 Post(s)
Liked 449 Times in 265 Posts
Cheers
Yup, there's no one answer. Probably depends on a bunch of variables, like there's probably a best all around depth and shape for me and a different one for you.
I'm on Enve 4.5s, 48 mm front 56 mm rear, very wide, and I'm heavier than average. They work very well for me in all the conditions I've been in.
Seattle Forrest is offline
Old 05-31-19, 10:48 AM
woodcraft
woodcraft's Avatar
Quoted: 1071 Post(s)
Liked 57 Times in 37 Posts
You get used to what you have, but 60mm has me giving extra space to other riders on gusty descents,
50mm is good & fast,
But lately have been on the 35mm because the tires are nicer.
woodcraft is offline
Old 05-31-19, 11:00 AM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 8917 Post(s)
Liked 160 Times in 103 Posts
Depends also on your weight.
I am skinny, 140-something pounds, so I like 40ish. If you are heavier, add 10-15mm. If you are ultralight, drop 10mm.
Addiction is all about class.
datlas is offline
Old 05-31-19, 01:57 PM
hubcyclist
Quoted: 209 Post(s)
Liked 24 Times in 17 Posts
I've been kind of sort of looking at more aero wheels than the box section rims I have on my Allez, and if I were to get any I'd probably go 35mm. However, the more I look into this stuff the less it seems like wheels are really as magical as people make them out to be at least as far as the cost vs benefit. If I were a triathlete competing over long distances, I can see how investing in faster wheels would help shave off minutes on a long course. I only occasionally dabble in road races and I can't really think of a time when my equipment cost me any time (when compared to drafting ability and putting down power when it matters), and when I ride solo I ride to power, not speed, so really being a few seconds faster here or there isn't really a big concern. Anyhow, if anyone has any evidence to convince me that I should take a closer look at a wheel upgrade I'm all ears!
hubcyclist is offline
Old 05-31-19, 02:16 PM
khoelsema
I also have 38mm SuperTeam Carbons. I'm a lightweight and get blown around if it is especially windy, but otherwise, they are fine.
khoelsema is offline
Old 05-31-19, 03:01 PM
Noctilux.95
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR
Quoted: 308 Post(s)
Liked 18 Times in 15 Posts
Anywhere from 35-50mm
Noctilux.95 is offline
Old 05-31-19, 08:43 PM
Psychocycles
Quoted: 71 Post(s)
Liked 5 Times in 5 Posts
The difference between the control wheel, Mavic Kysrium (28 mm depth), and the best performing disc/80mm wheels in Hambini's aero testing @ 50 km/h was a whopping 74 watts. However, when you're measuring the difference between a 40-60mm depth wheel, things get a bit fuzzier. Yoeleo C88 wheels @ 50 km/h according to the same tests saved just 2 watts over the same wheel in 50mm depth. TT specialist or Ironman? Yes, those 2 watts may matter. Everyone else? No, the extra weight of the 88 mm depth will outweigh the aero benefits.
My recommendation: Find a wheelset manufacturer that knows what they're doing (plenty of them out there, I'm not tied to any one brand - take your pick Mavic, Reynolds, SwissSide, Zipp, Enve, Bontrager, Yoeleo, Fast Forward - but stay away from Hunt & Flo Cycling) and stick to 40-50 mm depth. My wheelset is 50 mm depth, 1500ish grams, and aero as f....
One mistake I made when I bought my first 50mm depth carbon wheels a couple years ago was to assume that all carbon wheels in 50 mm depth are equal...not so at all. Below is an excerpt from Hambini's aero testing blog with the wheels he and his team have tested so far.
Psychocycles is offline
Old 06-03-19, 07:18 AM
maartendc
maartendc's Avatar
Quoted: 432 Post(s)
Thanks, that is good advice.
I forgot about that blog with their testing data, good find! https://www.hambini.com/blog/post/bi...ne-is-fastest/
I am looking more at the 30 km/h graph if I am honest, lol.
  • -It seems like between a Mavic Ksyrium (28mm) and your run of the mill 40mm wheelset, there is 7 watts difference at 30 kph.
  • -Between a Mavic Ksyrium and the average 50mm wheelset the difference is 11 watts at 30 kph
  • -at 60mm the difference is 12 watts at 30 kph
  • -at 80mm the difference is 14 watts at 30 kph.
So there seems to be a sweet spot around 45-50 mm honestly for 30 kph speed. Diminishing returns after that for the weight penalty. And the behavior in crosswinds. I guess I would be looking into some good 45mm wheels.
This does help put it into perspective... I know that you can save around 30 watts with clip-on aero bars / position at 40 kph. And about 5-10 watts with an aero helmet. So position on the bike is definitely the most important.
If I am being completely honest, I just want to get aero wheels because they look cool on the bike
Old 06-03-19, 07:34 AM
firebird854
Bikes: 2016 Specialized Tarmac Expert
Quoted: 169 Post(s)
Liked 21 Times in 15 Posts
Looking through Hambini's blog post it would appear depths below 50mm don't have worthwhile aero benefits. Also, while they look cool (I just got myself a pair of Aeolus PRO TLR 5s and love the look) they ALSO make a sweet SWOOSH sound!
firebird854 is offline
Old 06-03-19, 07:43 AM
OUGrad05
Quoted: 101 Post(s)
That's a great read.
I would like for someone to figure out at what speed does the lower rolling resistance of a 28mm tire get outweighed by the higher wind resistance of said tire. Does that happen at 20mph? 25mph? 30mph? I don't know the answer. I know I run 28mm GP5000s on my Roubaix and like them, but in the back of my mind I've wondered what the aero vs rolling resistance trade-off is and when you can expect to see it.
OUGrad05 is offline
Old 06-03-19, 08:39 AM
Psychocycles
Quoted: 71 Post(s)
And if you have the $ to back it up, that's a valid enough reason to buy some, in my opinion. If you like your bike, you'll ride it more, and that's ultimately the end goal, right? When I upgraded to my aero bike my wife couldn't understand why I'd spend so much money on another bike when I already have a perfectly functional one, but it ended up with my riding a lot more, and even now, when I look at bikes online, I don't feel any jealousy or upgraditis, because my aero bike is just that good. Used to be I'd be looking at bikes online almost daily, drooling over what options I had ... lol
Old 06-03-19, 09:02 AM
maartendc
maartendc's Avatar
Quoted: 432 Post(s)
Well I would say the rolling resistance is ALWAYS there, no matter what speed. So lower rolling resistance is going to be a constant improvement. Rolling resistance between a slow and fast tire can easily be in the range of 10 watts per tire, or 20 watts for 2 tires. (GP5000 vs Gatorskins for instance).
That being said, the difference between 25mm and 28mm of the same tire is likely 5 watts or less. You can already get a 5 watt difference between 60 PSI and 120PSI on the same tire. Reading Bicyclerollingresistance.com reviews gets you a good feel for the wattages.
The aero benefits are only at higher speeds, and I doubt the difference between a 25mm and a 28mm tire is more than 1-2 watts, if you see how small the differences even are between a 40 mm and 60 mm wheelset... I wouldnt worry about it!
Old 06-03-19, 11:02 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 610 Post(s)
Liked 45 Times in 26 Posts
Go shallow. Deep wheels are so 2010.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 06-03-19, 11:09 AM
PepeM
PepeM's Avatar
Quoted: 2631 Post(s)
Liked 63 Times in 29 Posts
That's why I dropped my 50/60mm Psimet crabon wheels and replaced them with Ambrosio Cronos. Need to keep up with the trends.
PepeM is offline
Old 06-03-19, 02:36 PM
Seattle Forrest
Holy crap, I thought the differences they listed were for the pair, not each! Big difference, thanks for that.
Old 06-04-19, 07:11 AM
OUGrad05
Quoted: 101 Post(s)
Aero differences aren't constant or linear. The difference at 10mph and 20mph isn't 2x, so there is a point where the aero outweigh the rolling resistance savings, I just don't know where that is.
OUGrad05 is offline
Old 06-04-19, 09:41 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Quoted: 610 Post(s)
Nice. But now you're wasting all sorts of effort because of your loss of aero efficiency.
Seriously we hardly ever sell deep carbon anymore. Almost everyone who was on deep carbon has left it. Lighter/shallower wheels are so much nicer to ride. It turns out the same people who were winning races on deep wheels are winning them on shallow wheels as well. Turns out the graphs don't really matter in the real world. *shrug*
