ultegra vs tiagra cassette
Are you guys able to notice a big difference between say a tiagra 9 speed cassette and an ultegra cassette with the same ratios?
Bikes: 2010 Tarmac SL, 2013 Fairdale Weekender, 2013 Fairdale Coaster, 1995 Specialized M2 Pro, 1972 Schwinn Heavy Duty, 2014 Surley Long Haul Trucker
Quicker shifting, and better ability to find the right gear. Less separation between gears.
Riding like its 1990
Tiagra will feel like a boat anchor, you'll have fewer gear inches for identical gears, and it'll rattle and jump like crazy.
Not really, I can't imagine a "feelable" difference.
I use SRAM cassette with my Ultegra setup and it's super quiet and shifts silky smooth.
Primate
Bikes: Concorde Columbus SL, Rocky Mountain Edge, Sparta stadfiets
Liked 5 Times
The Tiagra one has cooties, which can cause the frame to warp.
And they don't last quite as long as Ultegra because of a softer alloy.
Bikes: Look 555 & Cannondale CAAD 9 1
Tiagra is like Viagra, If it last longer than four hours-you should probably call someone.
Bikes: 2006 Cannondale CAAD8
no noticable difference although tiagra cassettes are probably harder to find. 105 cassettes are cheap and easily found too.
Bikes: 1994 Proctor Townsend Reynolds 753, TT S3 True North, Kona Major Jake, Kona Honky Tonk, Marinoni Puima, Cannondale BBU
Faster this, smoother that - yeah, maybe. One thing you *will* notice is the Ultegra cassette is going to last much, much longer.
Cycling Skier
Bikes: 2019 Moots Vamoots DR, 2008 Pedal Force ZX3, 2006 Jamis Eclipse, 1997 Marin Indian Fire Trail
That said, they'll both shift fine. And if your budget isn't compatible with Ultegra-level pricing, Tiagra or 105 work great as substitutes (as do the aforementioned SRAM cassettes, which are well-made and work seamlessly with Shimano drivetrains).
Quoted: 539 Post(s)
Liked 44 Times
I have Tiagra and Dura-Ace, and while Dura-Ace shifts much *smoother*, I do not believe there's any difference in the actual time it takes to shift.
If you have any doubts I would go with 10 speed 105. I assume you're talking about new components - Sora and Tiagra are 9 speed, and 105 and up are 10 speed. In other words, Tiagra and Ultegra shifters and related components aren't compatible.
Bikes: cannondale caad 8 custom
i have had both. ultegra 9 speed cassettes are still available. the main difference is that about half of the larger cogs on the ultegra cassette are on alloy carriers, lighter and a little stiffer.
if you want a 12-27, then you have to go ultegra or dura ace in 9 speed
