Domane AL 2 and Carbon Wheels
Hello Bikeforum community I am having some trouble understanding sizes for carbon wheels. When looking at options I see Rim depth sizes of different ranges.
and I just want to make sure I am buying the appropriate size for my bike.
Road Bike: 2018 Domane AL 2
Current Tyres: Bontrager T2, 700x28c
Rims: Bontrager Tubeless Ready
Any suggestions or clarifications is highly appreciated!
Thanks in advance for your time community!
Quoted: 20810 Post(s)
Liked 9,456 Times
Rim depth is a personal preference. In general, deeper rims will have a bit more of an aerodynamic advantage but are more prone to being pushed around in gusty conditions. ~40-50mm is generally considered mid-depth and a good balance.
Thanks for the reply! So all I have to do is make sure the carbon wheels match my current Wheelset? 700C, and the rim depth doesn't have an effect on tires I put on it correct?
Liked 9,456 Times
Correct. That does, however, bring up rim width. Rim width will affect tire width and, to a certain extent, height. This can be an issue if your frame clearances are tight. Widths in the neighborhood of 20mm are becoming more common and I'd probably stay within a few mm of that unless you have specific reason for going wider or narrower.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
What’s your budget? Take a look at Bontrager Aeolus R3 or R5 rim brake wheels. 19.5mm wide inside. There are others but Trek has a good warranty.
oh. Trek dealers if like a year ago should be running a discount on stuff around may. May be 10%.
Quoted: 850 Post(s)
Liked 344 Times
Sorry, does your bike have rim brakes or disc? This is going to significantly affect how wide the rim you choose can be.
Some Guy on the Road
Bikes: Foundry Chilkoot, Trek Domane
Quoted: 43 Post(s)
The Domane AL2 is rim-brake only, and has 8 speed Claris, which limits your selection because the 8 speed hubs have a different width than modern 11 speed
Save the money and look at upgrading the whole bike down the line
Likes For Wittyname:
Quoted: 272 Post(s)
Liked 448 Times
Did not see the 8-speed on the AL2. If it is like my old mountain bike You may be able to shim the 8-speed cassette. I did this when replacing and upgrading from a trashed rear wheel. The splines have to match. I used spacers from and old cassette I disassembled. But best is just ride it and save for something with 10 speed or more cassette.
Likes For noodle soup:
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times
100% can fit an 8spd claris on a 11spd freehub with a freehub spacer. All 8/9/10 spd casettes will fit with this spacer.
