Expensive error
Quoted: 1814 Post(s)
Liked 923 Times
Expensive error
I've been the habit of rolling up and strapping a jacket or vest under the seat bag, with a toe strap.
Well, yesterday it was very windy out there, and I rolled the jacket up in too small of a roll.
When it came loose, it wound up in the cluster and derailleur.
The damage: jacket trashed, RD trashed, wheel slightly out of true, rubber left in 30'+ skid.
The aftermath: was able to break off remains of the cage, shorten the chain, and single-speed the remaining 40 miles of the ride. It was cold, so I needed the remains of the jacket. Now the bike is in the shop- $$.
Live and learn, right?
Ouch. Glad you're safe -- the rest is only stuff.
Council of the Elders
Bikes: 1990 Schwinn Crosscut, 5 Lemonds
As soon as you started the story I knew more or less what was coming. Glad you are okay other than $.
Quoted: 41 Post(s)
Liked 8 Times
Stuff sack. I got one of those a while back. When I shed clothes or want to carry extra (just in case), it all goes into the stuff sack. Stuff sack is wedged between the tool bag and bottom of saddle and is secured around the seat post with a boot lace. Not especially pretty, but it works. Get a stuff sack at a camping/hiking outfitter.
Sorry for your loss, and glad you are OK. I had something similar happen when a plastic bag blew across my path and got itself engaged in the rear brake and derailleur. Each was OK, but the wheel did need to be trued.
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
I shiver when I see someone stashing jacketson their bikes. We had a rider die on a descent when his jacket came loose and got caught in his rear wheel.
Ride your Ride!!
Ride your Ride!!
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Bit of a bugger to say the least! The nearest to that I've done is to have a terry-cloth I'd been using to mop my brow, fall from the rear-pocket of my jersey and jam itself in the rear-wheel between the brake and the tyre, causing the wheel to stop dead, bringing me to a skidding stop, I was able to stay in control, but the skid ruined an almost-new tyre (wore a hole right through the casing!) (sorry - no pics!)
- Wil
- Wil
Bikes: Rixe track bicycle, 1986 Schwinn Paramount, 1988 Schwinn Tempo, 1985 Schwinn Tempo, 1972 Raleigh SuperCourse
Sorry to hear of the damage it caused! Great job Macgyvering your bike to be able to finish your ride!
Quoted: 1020 Post(s)
Liked 463 Times
Sorry to hear about your incident. At least you are out only money and did not suffer any injuries.
I have seen people stuff all kinds of things inside a used tennis balls "can."
Then they put the can in one of the water bottle holders.
Liked 6 Times
I know it doesn't seem this way now, but you were very lucky.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
Dang, that is a long way on a single-speed. Taxi, please.
My cheap windbreaker jacket/vest has a back pocket that the entire jacket can be crammed into then zipped shut with an elastic waistband & metal clasps.
I used to run the elastic through the saddle rails and cinch the entire thing above my saddlebag, then velcro the metal clasps to the saddle rails.
But the last time, the elastic had enough give that the pouch bounced down and got jammed between the rear tire and saddlebag.
I wondered why it got harder to ride, then my buddies let me know at a stop.
No damage to the jacket, some Shout in the laundry to remove the black marks and grease.
Since then, I carry a lightweight drawstring backpack on those days when I know I will want to shed a layer of clothes mid-ride. Less hassle than other solutions and not noticeable on the cool weather days when I do the multiple-layer thing.
Never carry stuff that can come loose. Similar to Jppe, without fatality, I saw similar incident. A lady on a charity ride had her jacket around her waist when it got caught in Her rear spokes. Yanked it off, locked the back wheel, and threw her off head first. It roadrashed her face and I think broke her arm and several fingers.
I have a seat bag the is expandable, so I can fit the jacket inside that, then make it smaller if I want to put it on, or visa versa. Or I put the jacket in a jersey pocket. Good thing you where able to keep it up, time to upgrade the RD. And make sure to have the bike shop check the alignment of the dropout, and replace the hanger(if it's that type).
Liked 923 Times
Thanks for the sympathy and suggestions.
Ouch for the worser outcomes than I had.
I like the stuffsack idea, and a thinner jacket that fits in a jersey pocket better is also a candidate.
Part of what I liked about strapping it on is that hi-vis yellow would still show from the back.
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,990 Times
Very waterproof.
Very windproof.
Breathable fabric.
Pit-zips.
Velcroed cuffs.
Two way waterproof zipper.
Works with an accessory rain hood.
They've upgraded it recently to an EX version to include a front pocket (which I don't want), so you can probably find it at significant discount too.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Good job on the single speed conversion.
Here's a copy of my post from another jacket thread. This jacket takes up half of a jersey pocket if it's rolled up.
I like my Pearl Izumi PRO Barrier Lite jacket.
It packs up extremely small. I can wear it at the beginning or end of a ride when it's cold, and easily stuff it into a jersey pocket. I'll bring it on a ride "just in case I need it".
It's not perfect. The very thin fabric is quite wind resistant. I'd actually like it to breathe a little more, but unzipping usually works for me. It's somewhat water resistant, drops bead up, but eventually can get through if the rain is heavy. It's fairly noisy when flapping at high speeds.
I wear it with a jersey and more base layers into the winter.
The rolled up size:
Very thin but strong fabric:
The rolled up size:
Quoted: 663 Post(s)
Liked 496 Times
Similar experience but with less catastrophic consequences. I had some gear on top of the rear rack held down with elastic cord. The metal hook came undone and was sucked down into the drive side spokes with the result that those spokes were deeply scored by the hook. The immediate result was a lot of noise but days later, while cleaning the bike I noticed the spoke damage. I replaced 16 spokes but I'm much more careful about carrying gear. I'm also more careful about inspecting the frame and drive train during cleaning.
Liked 923 Times
The rolled up size:
The rolled up size:
Liked 923 Times
I got the bike back from the shop. Kind of pains me to have someone else do it, but sometimes you have to get over yourself.
they don't make 9sp ultegra RD anymore, so a mtn bike RD was proposed, but I got a used one on ebay.
So:
rear derailleur ~$50
rear hub bearings
new cassette
new chain
new chainring bolts
wheels trued- ~$300
new jacket- ~$100
(thanks rm -rf)
But also:
bandages, physical therapy $0
lost skin, dental bills $0
No riding this weekend, so the test ride will have to wait, but I'm expecting some increased speed with those new bearings!
Quoted: 258 Post(s)
Liked 291 Times
Ouch.
I have a clamp on my rear rack to hold a rolled up jacket. But I'm going to double-check myself to make sure that I learn from your lesson.
https://www.racktime.com/product.php?xn=30
Old Fart In Training
Quoted: 12 Post(s)
Liked 22 Times
My personal Motorcycle rules I apply to my bicycle.
Never strap anything to the bike.
All Items INSIDE mounted closed bags.
simple.
Now I will go check my mounts,,,,thanks for the heads up OP
simple.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Glad you weren't hurt more than just a few areas of road rash. I carry a rolled up rain jacket on days where I might get caught in the rain or if it's cold and windy. I use two long shoelaces to tie the roll together and use the excess to tie the roll to my aerobars (on the top side) or my handlebar. I don't have that much room between by saddlebag and the rear wheel so it never gets tied behind me. Putting it in front of me allows me to always see the jacket and it's easier to get to if I need it.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Bikes: 2012 Trek DS 8.5 all weather hybrid, 2008 LeMond Poprad cyclocross, 1992 Cannondale R500 roadbike
Have you thought about a CamelBack? They can carry a lot more than water.
