Suggestions for stock build like Surly Straggler, only lighter?
Bikes: Surly Crosscheck SS
I own a Crosscheck built as a single speed that I use for my daily/lock up bike.
It's time to get a geared bike I can use on longer rides. My first instinct is to get a Straggler, but on second thought I'd like something with slightly less overlap with my Crosscheck. My budget is up to $3k, so I can afford a bit more than the Straggler. Niceties would be a lighter frame. I want to stick with steel. Rides are daily commutes and weekend 50-75mi choppy pavement and dirt roads.
Any suggestions?
Any suggestions?
These look pretty nice:
Mr Pink | All-City Cycles
I think the complete bike is ~$1900. You could always buy the frameset and build it up youself with nicer wheels.
Or one of these:
Gunnar Cycles USA, CrossHairs for Gravel or ?Cross Riding
Or one of these:
Quoted: 5888 Post(s)
Liked 3,472 Times
I'd be sorely tempted to get the gunnar cross given that the OP wants a versatile steel bike and the $3k budget. You can build a sweet bike on that platform.
Or one of these:
Or one of these:
But, the PF30/BB30 platform is stiffer and lighter. I prefer an English bottom bracket due to the better seals, however if I needed a new road bike tomorrow, I'd get the Mr. Pink. It has a pretty nice build kit for the price, and would be much more versatile/comfortable than a similarly priced allow or carbon road bike. Replacing the bearings every now and then really isn't a big deal.
Don't worry much about a lighter frame. Get one that fits you well and has the brazeons for what you need. Then spend the rest of the cash on a nice set of wheels, where you will see the most difference.
Given your terrain, I would not get a cross bike, personally. Any CX/gravel bike will have a lot of overlap with your CC anyway. Something like an "Endurance" road bike seems like it would be a better fit. Like a Black Mountain Cycles road bike or Gunnar Sport, which both can fit 32+ tires. No need for any fatter tires on choppy pavement and dirt roads.
EDIT: Also, this seems like a great deal, if you fit on either of the sizes:
https://www.rawlandcycles.com/store/...intItemID=3960
I just want something noticeably faster overall than the Crosscheck so that I feel that the limitation of keeping up with a fast-ish group ride has more to do with my own engine rather than the limitations of the bike. If such a plateau exists, I want to make sure the plateau from the new bike (only my 3rd bike purchase in 25 years!) is well above me to allow lots of room for improvement.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
Since you are leaning toward an endurance road bike, might I suggest the Jamis Quest? When I bought mine in 2011, they had one model, now they have expanded to three.
QUEST
QUEST
Many thanks for the suggestions. You're right — I should lean toward a road bike rather than a classic CX bike. Compared to a CX race bike I definitely want a slightly more slack and higher head tube, brifters, lower BB drop, the ability to fit 700x32c tires, and, likely, disc brakes. And in this process, if I can chop off a little weight off the frame in addition to the wheels and components, all the better.
I also second getting more of an endurance road bike, based on your responses. Or, even just a normal sport-type road bike and riding 25 mm tires instead. You can probably get a steel endurance road bike down into the ~19 lb range at your budget, or you could also get a carbon road bike at the same price point and be in the ~16-17 lb range (something like this: Synapse Carbon Ultegra - SYNAPSE CARBON - ENDURANCE ROAD - ROAD - BIKES - 2015). It just depends on the type of riding you are doing most - if you pavement isn't THAT bad, a real road bike on 25's is the way to go for speeds and social/group rides. If you plan to actually ride a fair amount of gravel, definitely get something heavier that can fit fatter tires.
As for 25mm tires, I agree for group rides they are great. But in dirt, I wouldn't do it unless to prove a point--and, yeah, that gets old real fast. I don't live in a world that has a perfect landscape and I want to get out there and get messy and not feel that I have to pushyfoot because of my tires.
OP in NYC has Bike Shops ..
high end super light steel? .. how about a custom Frame .
put all the $ into it and fit adequate stuff and Upgrade as the Bonuses roll in.
Bikes: 80's Schwinn High Plains, Motobecane Ti Cyclocross
Quoted: 108 Post(s)
Liked 30 Times
Save Up to 60% Off Titanium Cyclocross Bicycles | Road Bikes - Motobecane Fantom Cross Team Titanium | Cross Bikes
Last years model though.
Perhaps something like a Trek Domane, Giant Defy, Felt Z75 etc. may be the ticket for you. Or more on the light-touring/steel side, a Raleigh Clubman Disc, or perhaps Salsa Vaya.
But I think you're on the right track going with a road bike (with bigger tire clearance).
Bikes: Lotus Legend (1982), Lotus Excelle Mixte (1984), Lotus Classique (1984)
Your Shopping Cart | Wraith Fabrication
With a 3k budget..I'd get the above + h+son (tb14)/105 wheel set. Whatever groupo you like. Should be under 3k.
Also..I'd consider Soma Double Cross with a nice carbon/cyclocross fork. Should be under $800 for frame + fork..same wheelset as above and whatever groupo you like.
In case the link doesnt work its a Wraith Fabrication 'Paycheck'
