microSHIFT 8 Speed Down Tube Shifters
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
microSHIFT 8 Speed Down Tube Shifters.
Anyone have experience with these?
All the reviews I've found about the microSHIFT 8-9-10 Speed down tube shifters are 3 to 5 years old.
My concern is what appears to be aluminum mounting screws. Over time those screws need to be re-tightened and I don't get a want fuzzy about aluminum mounting screws. (1st generation Sumtour Cyclone levers for example)
I'm putting together a new bike with NOS 11-30T 8 speed Shimano cassette and a compatible new RD.
I have a NOS set of 8 speed DuraAce levers but I want to try something different ( I want to save them for another build).
verktyg
verktyg
Chas. ;-)
Chas. ;-)
A tiny wrap of teflon pipe tape does wonders.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Likes For nesteel:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Another vote for the economically-priced, nice-looking, and extremely-proven R400 levers. It'll reliably function and last for a billion years, and not (to me) look like re-purposed bar-end shifters.
Likes For RiddleOfSteel:
verktyg
Liked 1,238 Times
Re-pourposed Bar End Shifters
@RiddleOfSteel Thanks for pointing out that they "look like re-purposed bar-end shifters".
Work in progress... The aluminum seatpost is just to hold it in the stand. I have a black seatpost, saddle, FD, brake levers, hoods etc. to go with the "matchy-matchy look.
@nesteel The screws appear to be steel, it's the hex in what look like aluminum caps that concern me fro cosmetic reasons.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Liked 2,024 Times
@verktyg I think if there wasn't that kink from the silver to the black portion (of the left lever), then both levers would match/mirror each other, and then it would look slick and be a viable aesthetic alternative to Shimano and Sunrace. I completely understand the desire to have the black there (I would too!)--your Litton is looking spectacular. The black plays off the lighter blue perfectly, with the silver and tan playing supporting roles. Drillium on the chain ring is a perfect accent. Can't wait to see it complete!
verktyg
Liked 1,238 Times
Ed Litton Frame
As far as the frame is concerned, I'd been stopping by to see Ed Litton since the 1980's when he and Albert Eisentraut were partners in Oakland. He's painted 3 frames for me, aligned a bunch that I couldn't do easily for myself and done several repairs.
We'd talked about him building me a frame for years.
I retired back in January and had a little mad money so I stopped by Ed's shop to check out this frame that I'd seen hanging on the wall. Turns out he'd built it on spec for someone who didn't take it.
The frame had been stored for a while. It was my perfect size so I took it. (56cm C-T, 55cm top tube, 73° head tube, 75° seat tube, 40mm rake with a 100cm wheel base)
This is closer to the actual blue color.
It's built from a blend of Columbus SL and Tange Prestige tubing.
I'm chompin' at the bit to get it finished and ride it.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
I have the 9 speed bar end version of those shifters on my Clem. They are about 3 years old now and I've had no problems. I don't think that bolt is aluminum. If I had to guess I'd say it's satin finished stainless steel.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I have microSHIFT bar ends on 4 bikes, three 9sp and one 10sp. I run them with the rear on the handlebar and the front on the DT so I can use a bar end mirror. Perfectly good quality and I like that they can mount to the DT without any adapter.
https://www.universalcycles.com/shop....php?id=106560
Also, looking at the shifter schematics, shifters are convertible to different speeds if you buy the appropriate index shifter disc. For example 9spd can be converted to 10spd spacing by changing a disc sold separately.
https://www.universalcycles.com/shop....php?id=101689
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
I have the bar-end version of these that I just put on a Miyata. They seem pretty decent, if you're asking about quality.
