How to make a road bike ride smoother?
Quoted: 1857 Post(s)
Liked 664 Times
Other tires worth considering: Panasonic Pasela. Made by the same company that makes the Compass tires - supple but not as supple, much cheaper, very strong and robust, and often true to size. It's a nice all-rounder, unless you will have significant mud and snow.
Likes For Road Fan:
Quoted: 1743 Post(s)
Liked 1,281 Times
This year I replaced my Mavic clinchers and 25 tires with Mavic USTs and 25 tires. Much smoother.
Likes For bruce19:
Quoted: 550 Post(s)
Liked 325 Times
Hi to everyone,
I just purchased a like new Specialized 10 speed road bike Allez Comp with Sram components for what I consider was a great buy. As some here know I was in the market for a Hybrid but once I looked this one over I had to have it. She's very fast and once it was set it up for me I found the ride is very comfy except for the 700x 23c are terrible on rough roads. Has anyone here ever installed 28c on this style of bike and will they fit? If so what make of tire so I'll know I buy the correct ones. I'm also considering just buying another set of rims to set up just for this and have my 23C as a secondary set but I'm not sure how to measure to get the correct width and correct cassette set up. I'm in no way racing just wanting to set it up for fitness and 20 to 30 mile rides weekend 5 to 10 miles weekdays without losing to much speed. Thanks any info would be appreciated.
2. Run wider tires so you can run lower pressure.
3. Ride better tires that are more supple. I like Continental's GP4000SII as a good balance between ride quality, flat resistance, and longevity (4500 miles up front, then 4500 in back).
There's no reason today to ride 23mm tires now that the fastest tires come in 25, 28, and even 32mm. The lower rolling resistance from 25mm at the same pressure offsets the aerodynamic drag. Jan Heine (who makes supple Compass tires in widths past 40mm) contends that quality tires are no slower up to even 50mm, with pressures below 40 and even 30 psi allowing plush rides on horrid pavement.
https://www.renehersecycles.com/how-...should-i-ride/
For example, you’re a 140 pound rider on a 20 pound bicycle for 160 total. With a 45/55% weight distribution that’s 72 pounds on the front wheel and 88 on the rear. Running 23mm tires shoot for 75 psi front and 90 psi rear.
Higher pressures can be slower, or at least not appreciably faster than more comfortable ones.
Likes For Drew Eckhardt:
Quoted: 550 Post(s)
Liked 325 Times
Thanks for the reply, I've ordered a new set of 700x28c Gatorskin DuraSkin tires. My Allez comp has 23c on it now but appears to have a ton of clearance around the brakes, chain, and seat post so I'm assuming 28c shouldn't be and issue if so I'll return for 25c. I also ordered new gel grip tape, along with some other goodies so I think I'm headed in the right direction! Thanks for the info
The Gatorskins are durable because they have thick carcasses. Stiff carcasses make the ride bumpier. They have higher losses due to hysteresis and take an extra 10-15W to maintain 20 MPH. When I did the math, I discovered I'd be faster riding better tires and changing a flat every five hours on long rides noting I can spend fifteen minutes including a methodical search for embedded debris.
If you're not riding on sharp gravel that might cut your sidewall you want a different tire.
To my surprise, I found that Continental GP4 Seasons and GP4000s didn't flat more outside the rainy season when even Gatorskins picked up tire wire. GP4s got half the life, GP4000s got within 10% of the mileage, so I settled on GP4000s (GP4000SII) after wearing out my first set of 4 seasons.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Hi to everyone,
Likes For 2manybikes:
Quoted: 604 Post(s)
Liked 1,063 Times
You’ll be fine with the Gatorskins, been running them, size 700x 28c, on all my rides for the last 4 years. After a bit of experimenting, 75psi front, 85 psi rear. Really smoothed out the ride, on our not so smooth Wisconsin roads, as a bonus no flats in the past 4 years either.
Tim
Tim
Likes For tkamd73:
Quoted: 1609 Post(s)
Liked 2,590 Times
Carbon stem and seatpost helps also. When going with larger tires it's not always the width that's an issue but the height.
Likes For curbtender:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
Anyone who thinks 40+mm tires @ 30-40psi on pavement, have the same rolling/aero resistance (ie., 'are no slower') than 23/25/28mm at approx 90-100psi is delusional or grinding a personal axe or flat lying. Much more of a 'plush' or mushy ride = yes.
Likes For Wildwood:
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
23mm tires at or near 100PSI only FEEL faster when in reality you loose many watts by rolling over imperfections in the pavement (chipseal, cracks, small rocks, etc) than much more supple tires (wider, lower pressure) because there is no force required to lift you and your bike over each small object.
You're correct in a controlled velodrome and narrower tires also do have an aero advantage but beyond that, most people would do best to run the widest possible (given frame and fork and brake caliper limits), 60-120TPI tires with little or no tread on pavement for the best results.
Tim
Tim
Gator skins ride poorly. I put some on my bike last year and regretted it. If you want a long lasting tire that's still supple, try Michelin Power Endurance tires. The tread is very long lasting and the ride quality is good.
Likes For DaveSSS:
You hit the nail on the head! I installed 28's Continental Grand Prix 4-season tires, 60psi front and 70 rear (very smooth riding). I shaved 2 mins off my 10 mile run and gained 2 mph faster on my over all average speed! Also what a difference in the ride, the bumps and imperfections on the road I avoided before because it was jarring my teeth out where no issue what so ever. I purposely hit some bad areas just to see how the bike would take it and of course no issues, thanks to you and the others for the information here. I thought I enjoyed riding before but after my upgrades yesterday I can't wait to hit the road today!!!
Likes For TinyTm:
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
I'm surprised when I see 23 mm these days. I know LBS that don't even carry them anymore, I really think there's no point going smaller than 25.
If you're looking for durable tires in the future, I find the Schwalbe Marathons and the Conti GP 4000 are both more comfortable than the Gatorskins, and about as durable.
Likes For Bill in VA:
You riders that put how much air you put in your tires, should put how much you weigh as well. Make a big difference. Thanks.
George
George
Likes For George:
TinyTm,
I run Schwalbe Kojak 700c 35 at 85 psi They roll very good and don’t beat up your backside. Also you can use gel inserts under a good cork bar tape that will help greatly for your ether end. :}
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
No one had mentioned sprung handlebar stems yet, so I'll just add that. Probably a non-starter, since TinyTim seems pretty happy just with the new tires. Just another option, and I have no experience with them, so it would be an experiment.
Hi to everyone,
Everyone seems to have nailed it. I went from 23 to 25 Schwalbe Ultremo on my Look 566 and was greatly pleased with the improvement in ride comfort. After 10 years I upgraded to my current ride Look 765 that came with 28 mm tubeless. Not sure if it is just the ability to run lower pressure, but these are really smooth.
in my never ending quest for a soft, but fast, ride I have made a few other modifications that have worked quite well. A extra layer of Cinelli cork tape layered over the top portion of the bars. The area I ride on most. I added a Specialized Roubaix seat post. The one with the ugly goose neck but with 15-20 mm of shock absorption. Also a Redshift Sports shock absorption stem. The elastomer inserts absorb up to 20 mm as well. These last two really help to reduce vibration and harsh shocks. When riding I periodically check my tires to see if they have gone soft because the ride is so smooth.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
1. Inflate your tires to an appropriate pressure. I can drop below 70 psi without pinch flats although handling is getting a bit squishy, so I start the week at 80psi front / 90psi rear.
Calculate Rear tire pressure:
Tire Width=20: Pressure(psi) = (0.33 * Rider Weight in lbs) + 63.33
Tire Width=23: Pressure(psi) = (0.33 * Rider Weight in lbs) + 53.33
Tire Width=25: Pressure(psi) = (0.33 * Rider Weight in lbs) + 43.33
Tire Width=28: Pressure(psi) = (0.33 * Rider Weight in lbs) + 33.33
Tire Width=32: Pressure(psi) = (0.17 * Rider Weight in lbs) + 41.67
Tire Width=37: Pressure(psi) = (0.17 * Rider Weight in lbs) + 26.67
Front Pressure = .9*Rear Pressure
Likes For Afdica:
