Chain falls off when rolling backwards
Old 12-04-19, 06:34 PM
trek330
Quoted: 24 Post(s)
Liked 5 Times in 4 Posts
Is this normal?I have a triple shimano105 and if I back the bike up(not on it necesarily)like getting off an elevator the chain falls off the little front cog up front.Other than that the gears are well functioning and adjusted.Anything I can do about this?
trek330 is offline
Old 12-05-19, 09:17 AM
HillRider
Quoted: 1547 Post(s)
Liked 365 Times in 289 Posts
Is the chain slack in the "granny" (smallest) chainring? Try having the bike in one of the largest rear cogs when in the granny to keep the chain tighter. A sure cure is a chain watcher that physically keeps the chain from falling off of the smallest chainring. The Third Eye Chain Watcher and N-Gear's Jumpstop both work well and are relatively inexpensive
HillRider is offline
Old 12-05-19, 09:32 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2618 Post(s)
Liked 732 Times in 544 Posts
The mentioned devices are meant to retain the chain during shifting when pedaling forward, not back pedaling. The little tabs/blocks reside on the upper half of the chainrings and back pedaling drop off starts at the ring's bottom half. But Dave does make a good point about the cog/ring combo employed when drop off happens. One more reason why riding in cross over combos is to be avoided. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 12-05-19, 10:04 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2844 Post(s)
Liked 247 Times in 164 Posts
Wouldn't a stiff link or gummed up pulley cause that?
wphamilton is offline
Likes For wphamilton:
Old 12-05-19, 10:15 AM
justsaymint
Quoted: 5 Post(s)
Liked 3 Times in 2 Posts
This. Also poor chain line, very worn chain or very very worn derailer can cause this
justsaymint is offline
Old 12-05-19, 10:29 AM
Trakhak
Quoted: 677 Post(s)
Liked 345 Times in 223 Posts
When I shift from drive to reverse in my car while still rolling forward at 10 mph, bad things happen. What's wrong with the car?
Many if not most derailleur-equipped bikes will drop the chain in one or more gear combinations. Derailleur systems operate by changing the angle of approach of the chain at the point where it meets the sprocket or chainring. That's a controlled process pedaling forward and an uncontrolled process pedaling backward (or rolling the bike backward).
Moral: don't pedal backward and don't roll the bike backward---bikes aren't designed for that.
Trakhak is offline
Old 12-05-19, 12:11 PM
HillRider
Well, yeah, but all four of my 3x10 road bikes will allow indefinite backwards pedaling and rolling the bikes backwards without the chain dropping so it's not a universal problem. However, they in a middle gear and the chain has no slack. I expect the OP's bike is pretty cross chained when this occurs.
Old 12-05-19, 12:18 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1045 Post(s)
Liked 248 Times in 185 Posts
Is rolling backward a common activity for you? To steal an idea from Vaudeville, stop rolling backwards.
But does this happen when you pedal backward? As a diagnostic, this issue may have been useful as it alerted you to poor chainline alignment.
WizardOfBoz is offline
Old 12-05-19, 12:38 PM
Trakhak
Quoted: 677 Post(s)
Originally Posted by HillRider View Post
Agreed. For example, all four of my 3x10 road bikes will allow indefinite backwards pedaling and rolling the bikes backwards without the chain dropping so it's not a universal problem. However, they in a middle gear and the chain has no slack. I expect the OP's bike is pretty cross chained when this occurs.
Edited to clarify that nothing in HillRider's post contradicts anything in my post.
Trakhak is offline
Old 12-05-19, 01:28 PM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Seems like dropping the chains because of cross-chained on the small ring will drop off the outside, between the rings. OP gives me the impression that it's dropped to the inside, which would need a really bad chain-line to happen on the small ring and big cog (ie, not cross-chained).
So I wonder if his DR cage is just out of whack, or the hanger. Bent inwards.
ps, it would be a little silly IMO to insist on picking the bike up every time you want to move it backwards, out of fear of exceeding the design capability.
Old 12-05-19, 04:32 PM
rydabent
Quoted: 2048 Post(s)
Liked 463 Times in 286 Posts
Rolling a bike backwards, or back pedaling a chain, and having it come off is a good that something is wrong. It could be your dropout alignment.
rydabent is online now
Old 12-05-19, 07:25 PM
HillRider
It wasn't intended too as your statements were correct. I was just making the point that the problem isn't universal and that something in the OP's bike configuration is causing his specific problem. I think most of us expect he is badly cross chained or has a major chainline issue.
Old 12-05-19, 08:14 PM
Mad Honk
Quoted: 517 Post(s)
Liked 402 Times in 306 Posts
Maybe I am a bit off topic, but what happens when there is not enough chain wrap up from the rear derailleur to keep the chain in place? If the chain is too slack it may drop off from play in the slack chain. JMHO. MH
Mad Honk is offline
Old 12-06-19, 12:43 AM
Miele Man
Quoted: 1160 Post(s)
Liked 722 Times in 506 Posts
Something somewhere is sticking and possibly sticking just a bit. I'd check the freehub as well as the chain links and the derailleur pulleys.
Cheers
Miele Man is offline
Old 12-06-19, 02:26 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 237 Times in 189 Posts
When you roll a bike backwards it will pull the chain with it from the top, your crank will turn and on the bottom there is nothing guiding the chain. If in the big/big combination it will fall off on my bike and likely yours too. Moreover, when in this combination the pull of the rear derailleur will exacerbate the motion of the chain as it takes up the slack caused by the falling chain. In other words, once it starts falling you won't be able to stop it by moving the bike forward.
zacster is offline
Old 07-26-20, 02:33 PM
trek330
Quoted: 24 Post(s)
For those still interested...An update!!!Despite what some people said about "don't roll backwards" you do many times like backing out of an elevator or store with your bike, and too often I would have to put the chain back on.I went to a number of "professionals" with the problem and none had anything positive to say.After looking at the alignment they doubted that was the problem.Anyway the bike developed a serious gear skipping problem and no adjustment or chain replacement would fix it.I finally insisted my neighborhood mechanic examine the derailleur hangar with the proper tool.It was bent!Alas after straightening the bent derailleur hangar I have perfect shifting and no more chain falling off when rolling backwards or pedaling backwards.Halleluyah!
trek330 is offline
Likes For trek330:
Old 07-26-20, 05:53 PM
HillRider
Originally Posted by trek330 View Post
I finally insisted my neighborhood mechanic examine the derailleur hangar with the proper tool.It was bent! Alas after straightening the bent derailleur hangar I have perfect shifting and no more chain falling off when rolling backwards or pedaling backwards.Halleluyah!
Thanks for the update and I'm happy your problem has been solved. There are posters here who's almost reflexive recommendation to any reported shifting problem is "CHECK THE REAR DERAILLEUR HANGER ALIGNMENT!" They will be gratified to hear that their advice actually solved a poster's problem.
