Finally Caught a Break(through)!
Quoted: 1359 Post(s)
Liked 1,658 Times
Planned on taking a Saturday ride on the old 12-speed yesterday. Checked the tire pressure and the rear was down to 80psi. So I pumped it back up to 95psi and as I went to disengage the pump from the valve stem I saw the innertube poking out through the sidewall. So I deflated the tube and took another bike. Later that day I bought new tires and mounted them today.
Usually I don't detect sidewall breaches until there is a catstrophic blowout miles from home.
Likes For BobbyG:
Quoted: 1063 Post(s)
Liked 771 Times
That is one BIG slice.
my SOP --
1) go for ride
2) back home bike gets flipped or put in stand
3) clean rims and check tires for glass, cuts, sand-spurs .... also clean bike
4) results in no tire surprises awaiting : r.e.- tire condition OK but must still check pressure for slow leak
my SOP --
1) go for ride
Likes For OldTryGuy:
Bikes: Trek Marlin 6 29r - Scattanti road bike w carbon fork - Trek 6500 - Univega Alpina 503 - Specialized Sworks M4 made in USA
Quoted: 90 Post(s)
Liked 103 Times
I have been fortunate to have not experienced sidewall damage like that . I would assume that tire is beyond repair???
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Nice one!
I caught a gouge like that a month or two ago. At work, of course, I noticed the tube poking out of the tire. I (carefully) rode the 9 miles home without incident, and then the tire went in the bin.
Quoted: 811 Post(s)
Liked 1,946 Times
I'm glad you found the key issue with your tire.
Likes For CAT7RDR:
Likes For Sy Reene:
Liked 1,658 Times
Liked 1,658 Times
Apparently, that was not the case.
